Scratch Build – In Progress DAN A4-SFX: The smallest gaming case in the world
Discussion in 'Project Logs' started by dondan, 12 Sep 2014.
  1. dondan
    dondan What's a Dremel?
    7 Sep 2014
    Introduction
    The A4-SFX case is a one-man project with the goal of creating the smallest case possible while still using high-end standardized components, such as Core i7 processors and powerful full-length GPUs such as the GeForce GTX 980 Ti.
    The result is a unique product that is much smaller than all competing cases. This case is perfect for SFF (Small Form Factor) enthusiasts, those who need a highly portable system, developers who require a case with a smaller footprint due to limited desk space, and gamers who want a high-end PC experience in their living room.
    How it works
    A number of creative ideas were needed to create the case. Using a PCIe extender allowed for the most prominent design feature of this case, which is the location of the GPU behind the motherboard. The A4-SFX will come with the highest quality PCIe extender on the market, made by 3M, which allows for PCIe Gen3 and Gen4 support.
    The case allows for easy mounting of either SFX or SFX-L power supplies. The PSU is located in the front of the chassis.
    Depending on the size of the PSU, up to two 2.5” HDDs or SSDs can be mounted in the drive bay. This drive bay could potentially be mounted with rubber spacers to reduce vibration. A third drive can be mounted behind the front cover.
    Every component is able to cool itself by getting fresh air directly from the outside. Hot air in the case will move to the top and then outside without the need of an extra fan. This principle works perfect and results in an amazing cooling efficiency compare to other cases.
    Specification
    Case Dimensions (H x W x D): 200 x 112 x 317mm, 7.25L
    Overall Dimensions: 205 x 112 x 327mm (including feet and rear protrusions)
    Weight: 1,25 Kg
    Graphic cards support: Dual-Slot up to 295mm length
    Motherboard support: Mini-ITX
    Power Supply support: SFX, SFX-L
    Drives: 3 x 2.5" HDD/SSD
    Front ports: 1 x USB 3.0 (internal 20pin plug)
    Power button: Premium-grade button
    Material: 1.5mm aluminum, brushed exterior
    Sidepanels: Easily clippable with Lian Li Push Pin technology
    Colors: Anodized black or silver exterior, matte black painted interior
    Risercard: Includes the 3M Twin Axial 300mm riser cable
    PCIe Gen3+ support, Link: 3M product page
    Gallery
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    News
    30.08.2015 DAN Cases is online: www.dan-cases.com
    08.07.2015 Professional pictures of the A4-SFX were made. Many thanks to Torsten Paris!
    05.2015 Prototype from Lian Li arrived
    FAQ
    When will this be released? How can I buy one?
    End 2015 on Indiegogo or Kickstarter. For Europe I plan to sell the case through a distributor.
    How much will it cost?
    Around $200-230 + shipping + tax (depending on where you are located)
    It is possible to get the case with dust filters?
    No they are not included, but I will try to make them buyable with Demiflex.
    Why does it only have one USB 3.0 port on the front?
    After much discussion, I have decided that one port is enough for most users as having more ports on such a small case will hurt the aesthetics of the case.
    Where do you ship?
    Worldwide
    Does the case includes a manual?
    Yes, every case includes a manual paper in two languages (German & English).
    How do you ensure that the backside of the GPU does not make contact with the metal motherboard tray and SFX PSU?
    The motherboard tray and PSU will have a non-conductive shield attached in order to ensure that the back of the GPU does not come into contact with bare metal.
  2. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Awesome!!!
    Really nice proto!
  3. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Nice idea!
    Any particular point to using oversized text, though? Seems albeit like you're trying too hard to fill up the space. No offense intended, of course.
  4. Sanjaya
    Sanjaya Minimodder
    4 Sep 2013
    your GPUs gonna suffocate to death unless you WC it. i wanted to achieve same kinda goal, but i use full ATX smallest system. but never use your gc in front or back of the mobo, coz even the backplate gets too damn hot.
    n in SFX PSU gonna the cooling for the PSU?
    Hopefully waiting for some good results :)
  5. Sanjaya
    Sanjaya Minimodder
    4 Sep 2013
    n dun forget HD audio
  6. David
    7 Apr 2009
    Intriguing - looking forward to this!
  7. dondan
    7 Sep 2014
    @jrs77: 2500k@default + Gtx 670@default in Bechmark (Prime+3DMark) CPU: 63°C and GPU: 82°C
    @siliconfanatic: thanks for that info i resized the text.
    @sanaya: In the defauklt version it is better to use a blower style gpu like nvidia or amd reference and than you will have very nice temperatures. Because the gpu fan is in the airtunnel of the 2x92mm fans. For the SFX version, i will flip the gpu.
  8. Sanjaya
    Sanjaya Minimodder
    4 Sep 2013
    yeah blower style gpus are ok, what m saying is unless you flip it it will over heat, even if you flip it it will still heat the mobo. even the backside of a GC gets damn hot when it's at full load
  9. Cheapskate
    13 May 2007
    Sweeet!
    I bet there's room for a radiator in there still.:naughty:
  10. dondan
    7 Sep 2014
    Delete
  11. dondan
    7 Sep 2014
    Big update in the first post.
  12. The_Frag_Man
    The_Frag_Man What's a Dremel?
    20 Dec 2009
    Very nice design. I'll try to keep an eye out for the crowd-funding. The only thing I don't like really is there's only 1 front USB and not 2.
  13. dondan
    7 Sep 2014
    Its done :)
    I put everything together and it works :).
    Here are two early shots of the case with parts. It is very late so I will make better pictures tomorrow and some professional pictures next week.
  14. Arboreal
    21 Jan 2011
    Dondan, that is brilliant! So please for you to be able to see your hard work pay off and become a reality.
    I have been lurking over on Hardforums for a while, and have watched your project and Kimera's Nova develop over the months.
    Great work, a very ambitious goal, to produce such a small ITX case that has so much horsepower in it.
    I will be watching with interest, this is true SFF at its best :thumb:
  15. Shirty
    18 Apr 1982
    Very nice, it's always good to see persistence and patience pay off :thumb:
    I'm sure this will generate some sales too once it hits production. It's not quite for me however, I prefer slightly meatier CPU cooling so will continue to use ITX cases with chunky AIO support for now.
    Good luck with the rest of your journey!
  16. dondan
    7 Sep 2014
    Here are some new pictures that I made today, while I did the tests for the different CPU coolers I have.
    LP53 headsink vs. L9i Headsink
    LP53 heatsink with Noctua A9x14 FAN. I could not mount the Noctua FAN with the LP53 anti vibrations rubbers, because the default 92mm FAN use a 80mm mountpoins. So I mount it with four cable ties.
  17. Cheapskate
    13 May 2007
    Awesome and small. Usually those two don't go together.
  18. Guest-56605
    Guest-56605 Guest
    I like it :thumb: :D
  19. David
    7 Apr 2009
    That looks fantastic!
    I'd love to see the cooling performance once you're done.
  20. The_Frag_Man
    20 Dec 2009
    How does it fare with the drop test?
