Scratch Build – Complete L3pipe - Bit-tech Scratch Build Of The Year 2015
Discussion in 'Project Logs' started by l3p, 23 Nov 2014.
  1. l3p
    l3p www.^.nl
    1 Nov 2010
    > Final photos here <
    I hope you enjoy :)
    After several deskbuilds, lots of UV green and upgrade of my own desk it's time for something else :)
    I also resigned from Red Harbinger, hopefully I can spend 100% on my passion again .. modding and liquidcooling!
    Click for final shoot
    This might become one of my most challenging projects ..
    A casemod ... without a case.
    First packages already came in.
    Wish me goodluck! :)
    Hardware:
    Intel i7 5930K
    Asus X99 Deluxe
    LG 34U95-P 34″ 3440×1440
    Custom Parvum Systems frame
    Nvidia Geforce Reference GTX980 2X
    Nvidia 2-Way SLI Bridge
    Corsair Dominator Platinum 64GB DDR4 2400Mhz Octo-kit!
    Corsair Dominator Platinum Light Bar Upgrade Kit 4X
    Corsair Force Series™ LX 512GB 2X
    Corsair HXi Series HX1000i
    Corsair White sleeved Cable Kit
    Corsair Vengeance K70 RGB
    Corsair Vengeance M65 RGB
    Corsair Vengeance MM200
    Corsair Commander Mini
    Corsair Link Lighting Node
    Corsair SP120 LED White 10X
    Bitspower Fittings
    Bitspower Reservoirs
    Bitspower Pumptops
    Bitspower Flowsensors
    EKWB Cpu Block
    EKWB GPU Blocks
    EKWB Backplates
    EKWB Radiators
    EKWB Pumps
    EKWB Liquid
    Nanoxia PETG
    Made possible by:
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
  2. Cheapskate
    13 May 2007
    You crazy!:lol:
    Will this be done with soldered pipe, Or are you going with heavier plastic? I don't see being able to move a rig made of 12mm pexi tube. Have you ever built something with Lego so massive it fell apart?
  3. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    This sounds nuts, and quite the challenge!
  4. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    i am so following this :)
  5. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Subbing early, this is gonna be a helluva ride!
  6. Waynio
    Waynio Relaxing
    20 Aug 2009
    Freestyle modding, l3p, sounds interesting. :clap::dremel:
  7. TheMadDutchDude
    23 Aug 2013
    Subbed. This is going to be epic!! :D
  8. Derick
    Derick Senpai Studios
    26 May 2012
    Subbed :)
  9. RooiDuiwel
    RooiDuiwel What's a Dremel?
    20 Sep 2009
    this is going to be epic
    a true l3p design as usual
  10. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Good luck Peter! And don't forget to have fun as well!
  11. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    'Obligatory where is the modding post'
    But it's l3p so nevermind, can't wait to see what you'll make of this :)
  12. l3p
    l3p www.^.nl
    1 Nov 2010
    Just regular acrylic or PETG 12/10mm :)
    I did do a small test in the past with Bitspower C47's, they can hold 5-10kg. The Bitspower Enhance fittings are a bit stonger.
    And totally true about the lego part, that's why I was addicted to LEGO Technic :dremel:
    Thanks guys, enjoy the ride :thumb:
    These are the things I like to do most, no worries about the fun :D
    :thumb:
  13. siliconfanatic
    10 Sep 2012
    I think cheaps was speaking of just how much the acrylic can withstand. No doubt it's very strong tension and torsion wise. But just how rigid is it?
  14. l3p
    l3p www.^.nl
    1 Nov 2010
    I will test the acrylic some more the coming days :)
    (There is a possibility I will be using 12/10 PETG though which is almost unbreakable)
    First unpack this amazing package from Bitspower.
    This will hopefully be forming the construction :)
    Unpacking by candlelight.
    If you walk away he only needs 30 seconds to inspect and take ownership.
    Again thanks a lot Vincent for the cooperation!
  15. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    I think you need some more fittings.
  16. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    LOL! I wonder how much money is in that pile.
  17. Cheapskate
    13 May 2007
    The case is already at 40 pounds, and you only have fittings.:lol:
  18. imersa
    imersa Parvum Princess
    9 Apr 2009
    very very good, very very nice :)
  19. RooiDuiwel
    20 Sep 2009
    Bitspower prawn
    L3p prawn
    who needs redtube prawn
    :p :D
    this is going to be an awesome ride
  20. The_Crapman
    5 Dec 2011
    Holy Mary mother of Mod! Genius idea, looking forward to seeing if you can pull it off.
