Case Mod - In Progress HEX GEAR: Project ODYSSEY by Zoyadog
Discussion in 'Project Logs' started by Zoyadog, 19 Dec 2014.
  1. Zoyadog
    Zoyadog What's a Dremel?
    28 Jan 2014
    Welcome to my second worklog here of my new project Odyssey! :clap:
    This is a very special build to me, as I participate as a beta tester on the HEX-GEAR R40. The case has very good quality and unique design. I'm so excited to get my hands on it!
    Hans Peder Sahl “p0Pe” & Nate George “E22″ has made this incredible case and I thank them for this opportunity. :D
    Check out the website they made! http://www.hex-gear.com/
    The case (original in white) will have a white outside and dark inside, with light blue accent pack for the hexagons. The hardware and watercooling will feature black, chromed and crystal blue.
    Hardware: (as far as I know)
    CPU: Intel i7 5820k
    MOBO: GIGABYTE X99M Gaming 5 mATX
    GPU: GIGABYTE GTX 970 G1 Gaming 4GB
    RAM: Kingston 16GB (4x4GB) DDR4 3000MHz CL15 XMP Predator
    PSU: (to be decided)
    SSD: (to be decided)
    Watercooling: (as far as I know)
    MIPS IceForce HF
    Bitspower Water Tank Multi-Z 250
    Primochill Revolver Fittings
    Alphacool VPP655 with EK D5 X-top Clear Acrylic
    Thank you!
  2. Zoyadog
    28 Jan 2014
    Let's start this work log with an unboxing!
    Hmm what is this?
    I'd say assembling this case was lots of fun!
    There we have it!
    Radiator and fan mounting, 360 in the top and 240 in the bottom. The best part with this case is that you can switch around the panels and make it how you like it. There is also possibilities to go with rATX if you want. :)
    To be continued...
  3. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Nice,you got a white one then?
    Mine is black.
  4. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    In, because I love cats. And p0pe. :D
  5. Jeffinslaw
    Jeffinslaw What's a Dremel?
    26 Jun 2014
    Will have to follow this one!
    -Jeffinslaw
  6. Zoyadog
    28 Jan 2014
    Yeah. Love the black one :) Good luck with the build :dremel:
    Who doesnt? :D
    Im glad for that! :)
  7. montymole
    montymole Rigid Tubist
    24 May 2010
    looking forward to seeing this unfold my log will be done in one post on Tuesday great case great people who designed it :)
  8. saxovtsmike
    saxovtsmike Minimodder
    12 Aug 2008
    Another one, subbed too
    Where can I apply for a beta test ?
    Thx for the info that it can be assembled as inverted atx too.
    Pure awsomenes
  9. Zoyadog
    28 Jan 2014
    Great! :thumb:
    The designers chose 5 beta testers for this project, but there wont be long until you can buy it :)
    There will be some kind of extras you can get on the website to make it inverted atx :)
  10. ciobanulx
    ciobanulx Modder / Watercooler
    24 Jul 2014
    Subbed! Looking forward to this :D
    The case looks really nice in white :)
  11. Combatus
    16 Feb 2009
    There's definitely something cool about 'building' your PC case as well as your system - fond memories of Parvum and Mountain mods and hopefully Hex Gear soon too! Looking forward to getting my mitts on an R40 for review :)
  12. Zoyadog
    28 Jan 2014
    I agree with you! Especially when you can chose how to plan the case. :thumb:
    Hi everyone!
    I hope you all had a great holiday and a happy new years eve. Since everyone has been taking some break from work Ive been waiting most of the time for parts to arrive. Now everyone is back at work, and me back at school but atleast I can start building soon!
    I figured out I would to something with the case today so I spray painted to motherboard tray and sanded the attached panel to it. I think there will be a good contrast with the black tray. I chose to go with glossy black to fit the finish of the white powder coat.
    The black plexi panels are soon going to be replaced by frosted light blue instead :) Cant wait for that to arrive!
    The small panel needs some more sanding, I just removed the coat to get a small overview of it.
    I still haven't decided if I should put the PSU in the top or not. Hmm.. :rolleyes:
    Will do another update soon, I heard that my radiators are arriving tomorrow! :)
  13. montymole
    24 May 2010
    It is a tough decision on the PSU I went for the top way myself but it was not without a day or so deciding :)
  14. Zoyadog
    28 Jan 2014
    Yeah think ill have to try it out with the hardware and see whats the best. Also with the pump and radiators to make it look good and effective :) I think yours fitted well in the top!
  15. Ygd3n
    Ygd3n What's a Dremel?
    21 Jan 2012
    This is gonna be awesome!
  16. montymole
    24 May 2010
    Yes I thought the top was best just with the whole lay out going inverted, looking forward to seeing this unfold :)
  17. snef
    snef What's a Dremel?
    18 May 2014
    im in, really like the dark inside, a very good contrast
    cant wait to see it with hardware
  18. Zoyadog
    28 Jan 2014
    Thanks :clap:
    Ive been thinking and the top will suit me as well, with standard matx layout :)
    Im glad you like it snef :)
    Update, I thought I was going to upload some photos last week but some of the stuff didnt arrive in time. New radiators and a motherboard i picked up today!
    Radiators: EK PE 360 and 240
    Motherboard: Gigabyte GA-X99M-Gaming 3
    I thank Gigabyte so much for this motherboard, great mATX board for X99. With this one I will use an i7 5820k. :D
    With Noctua Redux 120mm PWM
    I also think i should go with this PSU, Fractal Design Newton 1000w because the matte-finish together with the radiators couldnt have been better :)
    The motherboard! :clap:
    Quick view with the MIPS Iceforce :) Thats all for today.
    My next goal is to work with the motherboard. The red color doesnt match my color scheme, so it will be silver instead. The red details are made out of metal, so it shouldnt be that hard. :thumb:
  19. F3nixMods
    F3nixMods What's a Dremel?
    24 Jun 2014
    Looking great and love that cpu block.
  20. Zoyadog
    28 Jan 2014
    Thanks :) I like it also, very much. Its a bit too small for the socket, but whatever :D
