Case Mod - In Progress [EK-Vulture]-------Gold Wings--------
Discussion in 'Project Logs' started by snef, 7 Feb 2015.
  1. snef
    snef What's a Dremel?
    18 May 2014
    First, I would like to say thanks to EKWB, Asus and Darkside for their support to this project
    and for sure thanks to Gdesmo and Hanoverfist for their help for paint and gold plating
    I named this one Gold Wings
    the theme of this one is ancient Egypt
    I choose this theme for color first
    I will not make hieroglyphs everywhere,
    the color theme will be white and gold
    I know, white, but this one will be special
    with a special paint job from the paint magician Hanoverfist
    I very excited to do this build, specially because working on a limited edition case,
    and I very honored to be in same list as 10 of the best Modder who will mod this case
    I will use this one for my business, photoshop, flexsign and all other software to do industrial vinyl cutting and printing
    ok parts list
    Hardware
    CPU: Intel i5-4690k:
    MB: Asus Maximus VII Impact
    Ram: 8Gb (2 x 4)Dominator GT:
    GPU: Asus GTX 970 Strix
    Case: EK Vulture
    Power Supply: EVGA SuperNOVA 750 G2
    SSD: 1 x Plextor 256GB M.2 M6e
    Cooling
    Cpu: EK-FB ASUS M6I - Nickel (gold Plated)
    GPU: EK-FC970 GTX Strix - Nickel (gold Plated)
    Backplate: EK-FC970 GTX Strix Backplate - white
    EK-FC Terminal - Plexi
    Ram: EK-RAM Monarch X2 - Nickel (gold Plated)
    TOP Plexi - RAM Monarch X2 Clean CSQ
    Pump: EK-D5 PWM Motor
    pump top: EK-XTOP D5 - White Acetal
    EK-D5 Cover Kit - white
    radiator: EK-CoolStream PE 360
    fan: EK-Vardar F3-120 (1850rpm)
    EK-HDC Fitting 12mm G1/4 - Gold
    EK-Ekoolant Pastel WHITE
    Mayhems Aurora Booster Gold
    res: EK X3 250 with White cap
    Modding
    Gold Plating: gold plating on all block and fittings
    Case will have a very special paint job by Hanoverfist, more detail soon :twisted:
    Sleeving: Not sure at this time if I will do it or order from Ensourced.net
    Lightning: Darkside led, led strips, and led in block
    a lots of gold screw and bolts from pro bolts USA
    and some vinyl stickers by myself
    some photos of Motherboard, Ram and GPU
    i just received one box From EK with a lot of water cooling gear
    photos
    and the Case
    the EK-Vulture
    now , case go into modding session
  2. Arboreal
    21 Jan 2011
    Amazing! 3 EK Vulture builds all on the go at the same time.
    Gentlemen, start you Dremels! :dremel:
  3. montymole
    montymole Rigid Tubist
    24 May 2010
    So happy to see this case where it should be :)
  4. Akira749
    Akira749 What's a Dremel?
    12 Jun 2014
    Subbed my friend!
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    A lot of stock photo's?????
    Way too many project logs that start out like this.
  6. Bartacus
    Bartacus Minimodder
    30 Oct 2014
  7. snef
    18 May 2014
    Thanks
    How you start yours?
  8. onevoicewild
    onevoicewild What's a Dremel?
    20 Dec 2014
    Nice bag of goodies! Do your magic!
  9. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    Looking forward to this, snef. +sub :)
  10. Zoyadog
    Zoyadog What's a Dremel?
    28 Jan 2014
    Yay, looking forward to this new project Snef :D
  11. snef
    18 May 2014
    Thanks Everyone
    hope you will like it
    cant wait to see paint job and block gold plated
  12. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    To be fair it is in the forum rules that a log is only a log once there have been actual progress pictures posted, rather than just concept pics and/or photos of the gear. Often that means the logs starts when the first bit of modding gets going.
    In other news, wow now EK decides to offer gold fittings... Bit late but alright then. Always love seeing how your builds turn out Snef, will definitely be watching with keen eyes.
  13. snef
    18 May 2014
    Little Update
    start working on Cable for Gold Wings
    and used Darkside Cablecombs, I really like them
    and installed Waterblock on Maximus VII Impact for test fit,
    last time you see these block in nickel finish, next photo shoot, the will be gold plated
  14. snef
    18 May 2014
    UPDATE:
    Gdesmo sent me some photos of my water block GOLD plated
    im in love.......I just love the results
    Thanks Gdesmo for your help on these, just spectacular
    im so excited, cant wait to build it
    list of parts
    EK-FC970 GTX Strix Nickel
    EK-FB ASUS M6I Nickel
    EK-RAM Monarch X2 Nickel
    EK-D5 Cover Kit Nickel
    EK-AF Angled 90° G1/4 Nickel
    EK-AF Angled 2×45° Nickel
    all plated gold
    do you like "GOLD"?
  15. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Dat gold plating job! :jawdrop: So he plates the entire blocks, even the innards, that's interesting. I would have thought that would negatively impact the temps, if only a little.
  16. montymole
    24 May 2010
    :jawdrop: Just lost for words right now
  17. Maki role
    9 Jan 2012
    It's like a few microns thick, there'll be no difference.
  18. Cheapskate
    13 May 2007
    You plated the rotaries? Do they still rotate and stuff? The anodized compression fittings will look babyshit brown next to those.:worried:
    One of 50. None of the other Vulture builders can brag about that. It's like Eddy gave you his personal copy.
  19. montymole
    24 May 2010
    I must admit I am worried about the compression's up against this bling
    The 01/50 that is just like getting a piece of real treasure :)
  20. MathModding
    MathModding What's a Dremel?
    23 May 2014
    Wow, very nice jobb my friend ;-)
    Good luck!
