Case Mod - In Progress Cosmos II : Project Metal Gear - Twin loop almost done (I7 4790k/Crossfire r9 290)
Discussion in 'Project Logs' started by Geno, 14 Apr 2015.
  1. Geno
    Geno What's a Dremel?
    3 Mar 2015
    Hi Everyone,
    My name is Anthony and I'm a 24 years old French guy :) . I'm here to present you my second case mod.
    By creating this new mod, I didn't want to start again on a clean look. I needed a subject that I appreciate, to gave me the inspiration and something new.
    Why Project Metal Gear ? Because I'm a big fan of Metal Gear Solid by Hideo Kojima and I wanted to do the honour to this mythical saga to be part of my project.
    This mod will be esthetic as much as powerful, to play/stream, make some photo or video editing and 3D modeling.
    - Cooler Master Cosmos II √
    - Intel Core I7 4790K √
    - Msi z97 Gaming 7 √
    - Crossfire Sapphire r9 290 4go √
    - Akasa Venom Power 1000w gold √
    - Seagate Barracuda 7200rds 1To √
    - Samsung SSD 540 evo 120Go √
    - Pump Swiftech MCP35x : 2/2 √
    - Res Phobya balancer 250mm : 2/2 √
    - Waterblock Heatkiller GPU X-3 : 2/2 √
    - Waterblock CPU Watercool Heatkiller IV Pro √
    - Radiator XSPC RS 360mm : 2/2 √
    - Radiator EX 360mm √
    - Radiator Swiftech MCR220-QP √
    - Stainless steel tubes 8/10mm √
    - TFC fittings √
    Some pictures of the components :
    The beautiful z97 Motherboard by MSI
    I7 4790K :thumb:
    The pump Swiftech Mcp35x
    XSPC RS360 :
    Swiftech MCR220 :
    I'm not a great photographer, but I will do my best for your eyes ! :)
    Time to work !
    Drill... again, and again, and again, and again. Results ?
    A ton of rivets :clap:
    Cutting of the embarrassing things :
    There is a lot of space after this emptying !
    Now, it's time to fill all of these holes. Creation of the first mount of front radiator :
    The result is really good, I'll just have to paint it.
    After that, I decided to make a mobo tray to remplace the other, which covers only half of the length.
    Little test :
    The rest is coming soon :rock:
    edit : Spoiler on the pics of my first build doesn't work, how can I fix that ? Thank you :)
  2. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    Subbed, great start dude. GLHF! :)
  3. Geno
    3 Mar 2015
    Thank you ! :)
  4. Hukkel
    Hukkel James' minion
    20 Dec 2012
    I love MGS so count me in!
  5. Geno
    3 Mar 2015
    Hello ! Welcome on board :) I'm glad to meet another fan :rock:
    Today some vinyl wrap :)
    3M Series 1080 Grey Mat Metal
  6. Geno
    3 Mar 2015
    Hello guys ! :)
    Order received from Evonik.de :
    A massive acrylic plate of 15mm in thickness :D
    Some drilling, tapping and integration tests :
    :blush:
  7. GregEl
    GregEl What's a Dremel?
    24 Jan 2015
    That is a very nice acrylic piece! Interesting build, keep it up! What red fans are those? NZXT painted red?
  8. Geno
    3 Mar 2015
    Thank you ! No those are Arctic Cooling F12 painted in red :)
  9. Mark011
    Mark011 Minimodder
    18 Jan 2015
    subbed
  10. Geno
    3 Mar 2015
    Hi ! Welcome here :)
    Update !
    The twins.
    Block Watercool Heatkiller x3.
    Start tubbing with temporary fittings.
    That's beautiful :lol:
    It fits perfectly :D
    I think there is a problem !
  11. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Great job on that. Subbed.
  12. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    As a huge MGS fan count me in! Subbed
    Отправлено с моего iPad используя Tapatalk
  13. GregEl
    24 Jan 2015
    There is a modding solution that would work for that. Deepen the spot the second rotary fitting screws so that it is further "inside" the acrylic.
  14. Geno
    3 Mar 2015
    Oh, that's a nice idea :) But for this time I found another solution, because the Cosmos have a psu mount who can be removed.
    New PSU mount :dremel:
    Perfect !
    :rock:
  15. Cheapskate
    13 May 2007
    You could have tapped G1/4 directly into the plex too. ;)
    Looks good so far. If you drill any more in the plexi, keep it cool with water. The cuts will come out much cleaner, and you won't have any crazing/cracking problems in the future.
  16. Geno
    3 Mar 2015
    You are right, but I worried about damage it. Thank you for the tips, next time I will use water, but the result is good without too.
    Because I have lowered the PSU, I had to cut the back of the case :
    Now I have to reseal this hole with a small aluminium sheet of 15mm with Epoxy.
    Almost done, needs a lot of sanding.
  17. Geno
    3 Mar 2015
    Hello guys ! It's been a while, sorry for that. I didn't have time to give news of the progress :eek:
    Parcel from my partner Docmicro.com and Allcity for the paint spray
    Holes and holes :D
    Installation of reservoirs for the twin loop
    Cutting a mount for 240mm radiator
    First door wraped with 3M vinyl
    And I decided to not use acrylic tubes, and to go with something harder, like Stainless steel :clap:
    After that, I received my order from Aquatuning :blush:
    Tops Aquacomputer :rock:
    Finish result with 3m vinyl
    Flying pumps :D
    First try of polishing, Before and after :
    After 15 hours of hard work :yawn:
    Stay tuned !
  18. Hukkel
    20 Dec 2012
    Nice work on the stainless pipes and polishing! I like where this is going.
  19. Geno
    3 Mar 2015
    Hello !
    Thank you ! :blush:
    Custom HDD mount :
    Foxhound Key chain :blush:
    And I received a new PSU to replace the Akasa Venom Power
    This rubber is excellent for vibrations !
  20. Geno
    3 Mar 2015
    Hello !
    I made a mount for the XSPC EX 360
    And there is an aluminium sheet, with that I made my EX 360 cover
    Result :
