Scratch Build – In Progress The Cell : update 11/12/15 FALLOUT 4 !!
Discussion in 'Project Logs' started by Sassanou, 14 Jun 2015.
  1. Sassanou
    Sassanou What's a Dremel?
    3 Sep 2011
    Hi !
    Well, today I want to share with you the start of my first scratch build of my life.
    I use to do modding for years now but this kind of modding is a real challenge for me because I always find it very difficult to do.
    But here we go !
    So, the goal here is to do something different from my other mods, something new but with the same spirit I love : modernity, class, high-end looking, and so on.
    Unusually for me, this time I will also do a REAL worklog with photos of all the steps as you can see how I work on this project.
    But hey, quit talking and go to the work !
    (some sponsors are coming, but we will see that later ^^)
  2. Sassanou
    3 Sep 2011
    So, I started to buy two aluminum plate 4mm thick !
    After that, it was time to do some plans on it for the futur cuts.
    I decided to do some drill holes and cut some aluminum tubes : those tubes will assemble the 2 aluminum plates and this will be the "center" of the chassis.
    Well, that's all for the moment, you will see the progress monday or tuesday ;)
    So see ya !
  3. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Good luck Mathieu!
  4. Arcis Modz
    Arcis Modz What's a Dremel?
    31 May 2015
    good luck bro.. with your skills. i know this will be a piece of cake. :)
  5. Sassanou
    3 Sep 2011
    Thanks guys !
    First plate done !
    4mm, it's very thick o_O
  6. Sassanou
    3 Sep 2011
    Second plate done : I'm cutting threaded rod to "fix" the 2 part.
    This part will be middle of the chassis :)
  7. Ocelot
    Ocelot Minimodder
    4 Apr 2013
    Looks interesting. Neat work.
  8. Cheapskate
    13 May 2007
    A promising start. I'm sure you will make something awesome here.:D-You've done it before.
  9. _TechPuppet_
    _TechPuppet_ What's a Dremel?
    1 Feb 2015
    Like what you've done so far, can't wait to see what you do next.
  10. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    You have got my interest.
  11. Sassanou
    3 Sep 2011
    Thanks !
    Thank you ! But I find that scratch build is a "little bit" difficult to do than a Mod ^^
    Thanks _TechPuppet_ ;)
    Thanks to you too !
    Well, still in progress... I have to do this twice !
    Next time, I'll show you the result but with better photos (come back little Canon ^^)
  12. Sassanou
    3 Sep 2011
    Well, that's enough for today ^^
  13. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Salut le Frenchie,
    Cela fait un petit moment que je suis tes mods.
    Enfin un scratchbuild! ;)
    Arrête moi si je me trompe, mais c'est une sorte de lame où tout sera intégré?
    Quelle est l'épaisseur?
    Ca me rappelle mon projet que je viens de terminer... http://forums.bit-tech.net/showthread.php?t=280510
    Bien entendu, les finitions ne sont pas du tout à ton niveau!!!:waah:
    Following you!
    CHUSS :hip:
  14. Sassanou
    3 Sep 2011
    Hello !
    Et merci ;)
    Donc en fait non, il ne sera pas comme le tien, ce que tu vois la n'est que le châssis, rien de plus, le reste arrive ^^ ;)
    And here is the work of the day.
    This two plates will be the front and the rear of the "case".
    I Just need to file a little bit, make some holes, do some new cuts and bend some parts ^^
  15. Sassanou
    3 Sep 2011
    Well, here is a "preview" of the look of the case but still need to do a LOT of work with this front and rear (hide the screws, slip in two the two plates, etc) :)
  16. storm-83
    storm-83 Minimodder
    7 Nov 2014
    Looking good!
    Will be looking forward to how you will be connecting the front and rear plates.
    Nice to see you finally do a scratch build :thumb:
  17. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    This is looking pretty impressive for a first scratch build!! Subbed!
  18. Dr. Coin
    13 Sep 2013
    I like the ends.
  19. Sassanou
    3 Sep 2011
    Thanks to you guys !! :)
    Hard day work : no time to take good photos, it will be for tomorrow !!
    Well, yersteday I wasn't satisfied with the look of the case (too tall, not rather long) and today I decided to change this. So I cutted 3cm at the bottom and 3cm at the top. I also stretched out the frame with new sections of tube.
    Last thing, I cutted in half the front and rear pannel to add some design.
    Voila ;)
  20. Hukkel
    20 Dec 2012
    You can start working for In-win ;)
    Vetalar likes this.
