Case Mod - In Progress MODBOX 360
Discussion in 'Project Logs' started by darknessblade, 5 Nov 2015.
  1. darknessblade
    darknessblade What's a Dremel?
    23 May 2014
    Hello guys,
    this is my 2nd mod on bit-tech.
    this time i am modding a broken Xbox360 case to hold a m-itx motherboard/full PC
    as i go building it i will upload more photo's of the case,.
    things you need/i used
    A ssf psu
    a mitx motherboard+CPU
    2.5" HDD
    a xbox 360
    a xbox 360 HDD case (if you dont have one)
    a laptop dvd drive (optional)
    power-button/letds (recycleble from a old case)
    a 3d printer (optional) for parts/others.
    since i used a old mitx PC i had all this in the case (except for the xbox 360)
    (for easier reading i did post the 1st 4 post for the build log [sorry for tripple posting])
    greetings darknessblade
    *looked at some other FAILED casemod atempts to get a pc inside a xbox case, most of them needed a lot of cutting to do, reforming the entire case.*
    my project features a bare minimum of cutting the case, keeping the full original design.
    (as you can see in my pictures, i only need to do a bare minimum of cutting)
    step 1, get your xbox 360 (FAT)
    if you have a xbox and its broken take it completely apart.
    keep the fans, for the rest clean out the entire casing.
    step 2
    get your mini-PC.
    find a mitx PC with a ssf PSU.
    step 3.
    fit all the parts in the case to look if you have to do some cutting.
    step 4
    design a motherboard spacer for the mitx motherboard.
    step 5
    3D print the motherboard tray/riser
    step 6
    mount the spacer/tray to the MB:
    step 7
    design the power-shield, to fit in the leds/buttons
    also use a motherboard/psu spacer if necicary to prevent static overflow.
  2. darknessblade
    23 May 2014
    build log PT2
  3. darknessblade
    23 May 2014
    build log pt 3
  4. darknessblade
    23 May 2014
    build log pt 4
  5. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Looking forward to seeing this as It's something I want to do at some point
  6. uerseya
    uerseya Covered in rock wool
    25 Aug 2008
    Pic's aren't showing ?
  7. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
    My first mod was an xbox 360 conversion, looking forward to see your take on it as there are a lot of areas I would have changed my plans
  8. darknessblade
    23 May 2014
    *updated*
    added pictures.
    future plans:
    adding gameport (located in the memor-card location)
    cutting away the parts that are to small.
    adding a sff dvd-drive (have a ide-version)
    HDD (located in the place of the hdd spot of the original xbox, [did not have a xbox HDD]
  9. uerseya
    25 Aug 2008
    Cheers & good luck with the build :thumb:
