Scratch Build – In Progress PROJECT "LEGACY"
Discussion in 'Project Logs' started by MKsoft, 1 Feb 2016.
  1. MKsoft
    MKsoft What's a Dremel?
    7 Mar 2011
    Hi everyone. Welcome to my project "LEGACY".
    As you might guess from the title of the project is the subject of TRON Legacy.
    A huge THANK YOU to the sponsors who support this project:
    Model:
  2. MKsoft
    7 Mar 2011
    The project based on case Core X9.
  3. MKsoft
    7 Mar 2011
    Motherboard: MSI B85M-G43
    Video: MSI GTX 960 2GD5T
    Memory: AVEXIR - DDR3 Core Series - Quad Channel Kit
    Power Supply: Thermaltake Toughpower DPS G 1050W
  4. MKsoft
    7 Mar 2011
    Completed design cooling the graphics card.
    Dismantle the nominal cooling system
    Installed on the CNC machine to measure the heights of chips.
    Full cover water block.
    Picked up piece of plexiglas
    Milling form
    Tapping
    Сopper heatsink
    Rubber spacer
    Nozzle
    Assembly
    Finally testing
  5. MKsoft
    7 Mar 2011
    Design cooling the CPU for LGA 1150.
    Make Waterblock for CPU.
    Milling of copper heat sink
    Milling brass spacer
    Plated with rhodium and gold. This is result.
    Picked up two pieces of plexiglas
    Glued together
    Milling form
    Result
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    :jawdrop:
    Go on... please do.
  7. MKsoft
    7 Mar 2011
    Marks the bottom
    Cut the bottom of case
  8. MKsoft
    7 Mar 2011
    Milling parts on the case.
    Cut a piece of the case cover
    Parts after painting. Powder coating.
  9. MKsoft
    7 Mar 2011
    It's time to front.
    Rack access.
    The basis of the front panel.
    So, the process of creating the front panel.
    Milling.
    Holes nuts.
    Undercoat...
    Caulking...
    Painting...
  10. MKsoft
    7 Mar 2011
    Creating a light disk.
    Light details
    Polish details
    Filling
    PCBs
    Assembled front panel
  11. MKsoft
    7 Mar 2011
    Pacific P1 Black D5 Pump
    3x Pacific T22 Reservoir
    And many different fittings.
    Commander FT
  12. MKsoft
    7 Mar 2011
    Byke time.
    Sliced workpiece from plexiglas
    glued
    Milling optical fiber
    filled epoxy block
    pulled out of shape
    Milling byke
    Сold enamel in the processing good material for a long time ... In this case there is no practical value shall only to impart the required form.
    small video light byke
  13. hero1
    hero1 Minimodder
    18 Oct 2013
    Whoa :jawdrop:
    This is going to be epic:rock:
  14. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Very impressive work. :clap:
  15. stealth80
    stealth80 Minimodder
    1 Feb 2015
  16. MKsoft
    7 Mar 2011
    It`s the cooler time...
    Install coolers
    install radiator and sleeving
    Completely assembled bottom of the case
    top inset
    assembled top panel
    Install coolers
    Completely assembled top of the case
    Painted and assembled of the case
  17. MKsoft
    7 Mar 2011
    Mount motherboard
    the motherboard on the site with CPU waterblock
    Panel mount video on the site
    Fix the power supply
    sleeving
    Distributing water
    with pomp
    and together
    reservoirs
    The Wave
    Build and sleeving
  18. uerseya
    uerseya Covered in rock wool
    25 Aug 2008
    Sorry that last batch or two of photos are way too large and not all of them even load.
    Please RESIZE them thanks !
    Otherwise excellent interesting build, carry on with the quality work :thumb:
  19. MKsoft
    7 Mar 2011
    Temperature Sensors
    And small video.
    PCB top light
    Cubieboard
    I set the card to play two video streams. The front panel and the side window.
    SSD
    Mount SSD
    Continie sleeving
    UV led strip
    set the grid
    laid pipes
    Ending sleeving
    Electroluminescent Panel
    Test the light
    Left and Right panels
    Stickers
    And small video of filling
  20. RooiDuiwel
    RooiDuiwel What's a Dremel?
    20 Sep 2009
    please resize images
    loving what has been done but taking ages to load the page :(
