Thermaltake Magma Core - Thermaltake UK Modding Trophy powered by Scan
Discussion in 'Project Logs' started by F3nixMods, 9 Feb 2016.
  1. F3nixMods
    F3nixMods What's a Dremel?
    24 Jun 2014
    First of all I would like to thank Bit-Tech, Thermaltake and Scan for the opportunity given.
    It's a great pleasure and honour to be part of this competition, I will surely do my best not to disappoint.
    The main idea behind this mod is already completely formed in my head, a bit of planning has already gone into it but for the ones that know me, know how much I like to let the mod evolve along the way, freestyling surely won't harm :naughty: lol
    Without wanting to reveal too much I leave you a picture and a name, let your imagination flow and mod on!!!
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Very interesting, looking forward to seeing what you do, good luck! :thumb:
  3. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Subbed! Interesting name and pic. It has piqued my interest for sure.
  4. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    Have fun, i am following this :)
    Can´t wait to see the outcome!!
  5. F3nixMods
    24 Jun 2014
    Thank you all. Many more pictures soon...
  6. F3nixMods
    24 Jun 2014
    Some of the stuff ;)
    Right, time to show off some of the goodies that I received for the mod.
    Brace yourselves for some awesomeness!!!
    TT Ring RGB Fans - 120 and 140mm
    HyperX Savage 240Gb SSD
    Thermaltake VGA Water Block for ASUS STRIX-GTX 970
    Smart DPS G Series Power Supply 750W
    2x 240 Thermaltake LCS Cooling Kits
    C1000 Red Coolant
    And the Core X31
    HyperX Fury 8GB DDR4 Ram
    Enjoy the pictures. Modding has started but not much to show for it now. Soon...
    Mod on!!!​
  7. CanFo
    CanFo What's a Dremel?
    3 May 2015
    Wonderful shots!
  8. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Good luck man :)
  9. F3nixMods
    24 Jun 2014
    Thanks guys :thumb:
  10. F3nixMods
    24 Jun 2014
    More hardware
    The rest of the hardware arrived, time to show you more awesome stuff
    Group picture :lol:
    Intel Core I5 6600K Unlocked
    Thermaltake Lumi Color 256C
    Asus Maximus VIII Hero Alpha
    Asus Strix 970 OC Edition
    Fittings, fittings and more fitting... love the look of these soldiers :thumb:
    The modding has started and I will share some pictures very soon, there will be no laser or CNC cutting, all will be done manually
    Mod on, will be back soon...​
  11. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    Come on Marco, on with the build sir! :)
  12. F3nixMods
    24 Jun 2014
    Pics tonight mate ;)
  13. F3nixMods
    24 Jun 2014
    Let the modding start
    Right, so it's about time I start showing what I've been working on.
    As stated before I will only be using tools I have at home and will not laser or CNC cut any parts, lately it seems that it became a big deal if the parts are done manually or not as such lets jump aboard and demonstrate what can be achieved...
    I will not be using the drive bays as such that was one of the first things to be removed, what was the front of the core x31 will now be the bottom of the case and even though that it will barely be seen I know what's there and my OCD tells me that it has to look as stock as possible
    Yeah, why rotate the motherboard tray when you can rotate the whole case??? :D
    Starting with some 2mm alu
    Ready to sand and paint, hopefully will tie up nicely with the rest of the case
    Primed...
    Satin black and matt lacquer...
    Yeah, happy with the result... :dremel:
    Moving on to the bottom shroud, this will hide the some of the water cooling tubing that I don't want to be on display. 2.5mm alu for this...
    Had to create some additional access to that bottom shroud, may even have to cut a bit more but will leave it like this until it comes to assembling the whole thing, will know for sure then. :dremel:
    5mm frosted clear acrylic. Will be lit by the fabulous RGB ring fans and should diffuse the light nicely...
    M3 threaded acrylic inserts
    Decided that the SSD will be going right in the middle of the bottom shroud, am going for a sort of levitation look to it but that won't be seen till at a later stage
    Cut, file, sand and result...
    The PSU will also receive a makeover but for now just removing some stickers
    Doing some mini shrouds that will cover the fans that I don't want to be visible...
    JB Weld, best epoxy for metal
    http://i1296.photobucket.com/albums/ag11/redeagleslb/Magma Core Pics/24_zpsil1clt6w.jpg
    Will come back to this later as it takes around 24hrs to fully cure
    Moving on to fan grills. Brushed finish and PU lacquer on the cards
    Will be back soon with some more...
    Mod on!!! :thumb:
  14. Vault-Tec
    30 Aug 2015
    :D
    Great work dude loving some of the stuff here !
  15. Phame
    17 Sep 2012
    :thumb: Looking great dude, I personally don't see the problem with using machines like a Laser/CNC to bring a design to life. Each to there own I suppose.
  16. F3nixMods
    24 Jun 2014
    Lol. Could see someone doing this even before I posted the picture. Thanks mate
    Fully agree, some of the work that needs to go into making it more of a 3d part can be quite overwhelming when not resourcing to laser/cnc machines. Had to be said though as it seems to be the new in thing, so much noise over making parts manually when in reality it's just time consuming. Nevertheless, this one is "true modder"'s style :thumb:
  17. Hukkel
    20 Dec 2012
    I like the SSD mount a lot. Keep up the good work.
  18. F3nixMods
    24 Jun 2014
    Thanks mate. Will be working further on that tomorrow
  19. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    That moose face, LOL! :D Build is looking good!
  20. F3nixMods
    24 Jun 2014
    Thanks mate. Guess this will become the build's feature; THE MOOSE!!! lol :duh:
