TrashCan wayward (I should only be a trash can) Prolog: On a cold rainy Sunday afternoon Mr. NameAlwaysInUse decided, in the Bavarian capital, it was the perfect day for getting a new bathroom waste bin - ONLINE! So he scoured the vast worlds of the Amazon’s, fought with leopards, tigers and alligators, as his eyes suddenly grazed the Authentics Lunar. It was small, well-formed and had a shiny white paint. So he had found him, the holy grail of waste bins. But how could he bring it home in one piece? After all, he was surrounded by many wild animals! NameAlwaysInUse opted then for a courier of the Amazon’s Logistics fleet. Will said Grail arrive home on time, and more importantly, unharmed? Finally, three days later, Mr. NameAlwaysInUse’s door rang, he ran to the intercom, was it Amazon’s Logistics? The speaker crackled: "I have an express delivery for you ''! NameAlwaysInUse opened the door and took the package, but it was heavier than expected. Wrong package?, he wondered. Distressed he opened the package and took the contents carefully from its packaging. To his surprise, there was no mistake, but why was it so heavy? After a short investigation, he found that it had to be due to the thick-walled ABS! But when NameAlwaysInUse took a closer look at the holy bin , suddenly he realized that maybe he could come up with a better use for it other than storing trash. This is how the story of the small trash can begun. Case: Base: Authentics Lunar 6L Bottom: 3D SLS Nylon print MB Tray: 3mm Aluminium laser cutted Middleplate: 3mm Aluminium laser cutted Cap: 3mm Aluminium laser cutted Framework: Maker Beam Kit 200mm Riser: 380mm A-Type by Li-Heat Hardware: CPU: Intel i7-6700k MB: MSI Z170I Gaming Pro RAM: 16GB Crucial Ballistix Elite DDR4 GPU: Sapphire R9 Nano NT: SilverStone SFX Series ST45SF-G Cables: Silverstone Short Cable Set SST-PP05 SSD: SanDisk X400 512GB Cooling: CPU: Bitspower Summit EF Brass Nickel GPU: EKWB R9 Nano incl. Backplate Pump: Bitspower DDC Plus and Bitspower Magic Cube AGB: Swifttech MCRES Micro V2 Radiator: Bitspower Leviathan Xtreme 480 Fans: 8x Noiseblocker eLoop 120mm, 1x Noiseblocker eLoop 140mm Fittings: Bitspower Matte Black Tube: Bitspower Crystal Link 12mm Ice Red Liquid: AquaComputer DP Ultra Thermal Compound: Cooler Master MasterGel Maker Nano MonitoringAquaero 6LT incl. Kühler Lighting:AquaComputer Farbwerk Tools Multifunctiontools: Dremel 8200 incl. Parallel- and Circlecutter Deburring: SANPRO tube deburring
Here is the small trash can Let's go First we need a small hole for the Dremel Tool Destroying the Can! Around the world Now we need our best friend... Sandpaper! And my small dragon Gesendet von iPhone mit Tapatalk
Looking forward to seeing the trash-can case! (one proud to be a trash can and not pretending to be something else *cough*youknowwhoyouare*cough*) Subscribed!
If I see one of these done properly I will doff my cap to you. Nice to see it's getting some proper hardware too. BTW your bottom isn't working (the pic).
if you like this concept then check out the IronTurnip by Cheapskate, its along the same lines. just using junk, pretty cool.
Iron Turnip is quite different and more complex. I think "NameAlwaysInUse" is going to create something like the new Mac Pro and probably he takes inspiration by the Lunar project by Bouly based on the same trashcan.
First the Iron Turnip is much bigger Second Bouly copied the Lunar Project Third aircooling is quiet easy in this... Problem is the watercooling and this is why i created the log @Vault i know. Not uploaded yet 4x MakerBeam 20 cm 4x 25mm MakerBeam screws 12x nuts 12x 6mm MakerBeam screws 1x MB Tray 1x PSU cover First screw the Cover directly on the PSU Then the MakerBeams for the Tray with 2x 6mm screws. Now the Mb spacer incl. 4x 6mm screws If the dxf is cutted properly the mainboard fits. Short cable. Screw mainboard on the two MakerBeam Bottom fitting. Now you recognize that the cap isn't closing, because the MB ATX cable is to thick
Unless I missed something this will be water-cooled externally? (or you could've invented particle shrinker and will reduce the size of Leviathan 480mm )
I heard my name thrown about... Internal! WC internally! Even if you have to get a 2nd trash can and the assembly looks like a chubby.
The can will be on my tv Wall and the rad IN the wall why a second can Gesendet von iPhone mit Tapatalk
