Case Mod - In Progress FURY - bitfenix prodigy casemod -Completed 24/09
Discussion in 'Project Logs' started by MooZ91, 15 Jul 2016.
  1. MooZ91
    MooZ91 What's a Dremel?
    6 Jul 2012
    After sketching for some time, i finally decided to build my next case mod with a military theme, and mixed with some crazy ideas. This is the first time i build a colorful project, but rgb lights provide a nice touch. Watercooling is also involved, and more.
    The case is a bitfenix prodigy black, itx support, very good from my opinion.
    Disassembled the case, i started to cut around.
    Also, the bays for PSU and mobo were removed too. I thought in a new position to show off better.
  2. MooZ91
    6 Jul 2012
    Meanwhile i built two test panels, to check space and support. This also let me to remove the itx mobo limitation of the case, allowing to use a mini-atx too.
    Once everything was checked and tested, the final version of panels were made.
    The mobo base works as removable bay, fixed by two screws.
  3. MooZ91
    6 Jul 2012
    This is how it looks now
    The SSD is fixed from the rear panel, i drill the holes, then cut a little more hiding from surface.
    Checking the mount holes for the psu with the bracket, then installed.
  4. MooZ91
    6 Jul 2012
    Left cover (vcard cover)
  5. Cheapskate
    13 May 2007
    Looks neat. :D
    Style is more scifi than military. You confuse my tiny brain.
  6. MooZ91
    6 Jul 2012
    hahaha, that's what i mean with "crazy ideas" :D
  7. MooZ91
    6 Jul 2012
    Psu cover
  8. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Looking guuuuuuuuuuuwd.
  9. Vault-Tec
    30 Aug 2015
  10. MooZ91
    6 Jul 2012
    Thanks guys!
    Painting panels, airbrushing some and adding other details.
    Making a new fan for intake airflow.
    Now with the fan controller installed, this is how it should look like
  11. Vault-Tec
    30 Aug 2015
    Wow that's awesome. I really wasn't expecting it to look like that !
  12. MooZ91
    6 Jul 2012
    And there is more to come :D
    Meanwhile the Power button and usb3.0 ports
  13. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    always a fan of your work, Mooz :thumb:
  14. MooZ91
    6 Jul 2012
    :D :D thanks!
    Two reservoirs for top...
    Ran a few hours for leak test and passed.
    The main reservoir located on top, will connect the different stages of the water cooling, preventing extra hosepipe and as support for the things on top. Divided in two parts, the first one was machining to make the channels, and the other one as closure.
    Place other parts together.
    The process is resume in this video, check it :naughty:
    https://www.youtube.com/watch?v=CqT1D9zFRQc
  15. MooZ91
    6 Jul 2012
  16. MooZ91
    6 Jul 2012
    Found this screws from a aio watercooling, so i disassembled them and modify a little, to install a better ones.
    The mobo cover...
  17. Tymofar
    Tymofar What's a Dremel?
    20 Aug 2016
    i like what i see, nice work.
    You are using tons of acrylic ;D
    The only thing i dont like is the Mobo cover, but this is a matter of taste.
    I personally like the electronics.
  18. MooZ91
    6 Jul 2012
    Is the best material to work with. About the cover, yes is a matter of taste. In any case, can be removed anytime :D
    Finally, the pilot. Modeled with polymer clay and then airbrushed.
  19. Vault-Tec
    30 Aug 2015
    Amazing ! I hate motherboards they're so god damn ugly.
  20. MooZ91
    6 Jul 2012
    hahah, thanks!
    Finally is completed. Check the video and the photos :D
    Final photos!!
    RGB in action!! All the case change with them. Check the liquid coolant how react to diferent colors too :D
    Blue-Red-Green-Purple interaction
