Reply
Thread Tools View Mode
Old 18th Nov 2016, 09:13   #1
stealth80
Supermodder
stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.
Temporal Snow (Complete 30/11/16)
Completed Rig:
HI again!
                     So that time has come where me and the better half have come to realise that living with a Thermaltake X9 is fantastic if you live in a mansion!. However, living in a normal home it really is annoying. As much as I love the build, the case, the looks and the time I put into it, I just get annoyed at the fact I can't sit against my desk properly, can't get my knees beneath it either. It also restricts what desk we buy so to that end its gonna be getting stripped out  and one of the loops is going into my new build!
Step aside Thermaltake X9:
and into the ring the INWIN
303!
I've been thinking of doing this for a while now and I was going to use the Thermaltake View 21, but they aren't planning a white edition and I really don't want to spray another PC case in November/December (in the house, white speckles everywhere!). The case is obviously much much smaller than the X9 so I will be dropping down to one loop for the GPU, CPU and Mobo VRMS. The basic stuff in the PC is getting transferred over, however I can only fit one of the Mayhems Havocs in the case, which will be in the bottom (very snug!). So my new shopping list (all ordered tonight) is:
INWIN 303 White Edition - https://www.scan.co.uk/products/in-w...x-usb-30-white
Crucial MX300 525GB - https://www.scan.co.uk/products/525g...3k-iops-retail
Alphacool XT45 360mm Crossflow (cosmetic reasons) - https://www.scan.co.uk/products/alph...3-thread-black
Braided Sata Cable - https://www.scan.co.uk/products/cabl...cable-30cm-red
EKWB 204mm Res tube - https://www.overclockers.co.uk/ek-wa...wc-9am-ek.html
EKWB White res cap - https://www.overclockers.co.uk/ek-wa...wc-835-ek.html
So that lot will be added to the current:
Intel i7 4790k
32gb Kingston Hyper Fury X
Asus RoG Z97 Ranger
Samsung 256GB XP941 m.2 SSD
Seagate Barracuda 1TB HDD
Palit 1080 Gamerock Premium with EK Block and Backplate
Fractal Design Newton R3 1000w (overkill, but it was white for the X9 build and I had SLI)
EK Supremecy
1x Mayhems 360mm Havoc (the other + the Alphacool UT 60 240mm will remain in the X9)
1x EK DDC 140 X-res/pump combo - will spray the bottom housing white
First I got to work on stripping the old PC out, I wasn't very happy doing it, but it was required, and since I work nights I figured I may as well get it done now, leaving tomorrow evening to flush the old radiator.
First Rad out:
GPU and second rad out:
Rad back in and not much else:
Everything "safely" stored
Well I'm glad I did this today, I figure It was a matter of hours before my PC died. I raised an issue on the forums, with the retailer I purchased it from and EK themselves about the fact my water block for my 1080 was leaking internally. All 3 answer were it will be fine and won't affect performance only cosmetics. EK did recommend splitting the block and cleaning it and try re-seating which I did around 5 days ago. Well today its started spreading:
its slowly worked it's way passed the main seal, so hopefully I will be getting this exchanged as it aint even 5 weeks old yet.
Anyway the block was accepted for RMA yesterday, thanks overclockers. Last night I got to grips with the pump res. I don't know yet if I want to spray the inside of the case, however on Iced Blood I always felt I could of done more with the pump/res's to make them fit the theme a little better. So I got to work spraying the pump housing and after a couple of nights I have it somewhere I would like:
At this point I felt a little "meh", but once I assembled the reservoir (may not fit with my current plan, could end up being a 240mm + the res or 360mm + the old 105mm res) and new res cap with the fittings I felt a lot happier!
Case, SSD and radiator arrived first so I got a little work done inside the case, will spray the radiator tonight. Didn't bother with unboxing photos cause lets be honest, unless it's a titan no one cares
Little bit of early hours spraying to get the flow radiator to correct colour
and the finished product
just doing a little work on the cable management now, still got to fit the PSU so there is plenty left!
I have no idea why those blocks are showing up brown in the pictures! they aren't by the eye haha
__________________
Project Temporal Snow - http://forums.bit-tech.net/showthread.php?t=314299 - In Progress
Temporal Snow Ryzen Refresh https://forums.bit-tech.net/showthread.php?t=323038
Ryzen 1700 @ 4.0 GHZ - Gigabyte AX370 Aorus Gaming 5 - 16GB GSkill Trident RGB 3200 MHZ - Palit 1080 GTX Gamerock Premium - Samsung XP941 256GB - Crucial MX300 525GB - Fractal Design R3 Newton 1000w White Edition
stealth80 is offline   Reply With Quote
Old 18th Nov 2016, 21:10   #2
stealth80
Supermodder
Got to work this evening on some tubing, fitted the PSU and fans and also the top radiator:
Now waiting on my EK block to return from RMA before I can fit the 1080
__________________
Old 20th Nov 2016, 17:50   #3
stealth80
Supermodder
Temporarily fitted a tube between the 240 and the CPU block. Changed the top fans to a trio of Thermaltake Riing 12's in red and fitted a Phobya High Density RGB LED strip and controller. Also currently spraying the backplate for the 1080 white as the nickel finish would reflect the LED's onto the tempered glass of the case
__________________
Old 21st Nov 2016, 19:31   #4
23RO_UK
Hasta Maņana
23RO_UK's Avatar
23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan
Looking great fella
I'm currently torn between the InWin 303 and the Phanteks Pro M Midi
I can accomplish a clean build with both no problems, both will easily facilitate a WC loop (at a later date) however the 303 has the GPU support bracket I crave (GPU droop is an eye sore and the weight of a 1070 on a PCI slot is never a good thing) and the Pro M has the single drive bay I require for a Bitfenix Recon...
I shall keep an eye on yours as Black Friday approaches rapidly and hopefully make my mind up in the interim
23RO_UK is offline   Reply With Quote
Old 23rd Nov 2016, 08:14   #5
stealth80
Supermodder
Originally Posted by 23RO_UK View Post
Looking great fella
I was toying with a view 21, really glad I got this now, the tempered glass panel is great and the photos really don't do it justice, I aint done yet though and I will figure out how to photo this with the window on!
__________________
Old 23rd Nov 2016, 08:16   #6
stealth80
Supermodder
23/11/16 - MORE PAINTING!!!
SoundBlaster Z painted to match the scheme and the PCI bracket straightened ready for vertical mounting against the back of the case
The 1080 I/O plate (was silver would looked bad amongst the black 303 pci blanks)
and the EK Backplate:
Got something arriving to customise the backplate a little
__________________
Old 26th Nov 2016, 13:48   #7
stealth80
Supermodder
m.2 plate arrived and it was defo worth the wait!
Available here if anyone is wanting one, they appear quite rare at the moment:
http://www.coldzero.eu/364-m2-covers
__________________
Old 28th Nov 2016, 17:35   #8
stealth80
Supermodder
Ok got some good news today, my water block is being replaced and has already shipped! Also my LCD display has arrived!
First thing, get the fans started, so I got to work with the primer, the black was making the theme darker than I wanted:
and I tested the LCD on my MacBook, showing the reason why I need an LCD in the first place!
Got the fans finished and tidied up the PCI brackets around the rear of the lower radiator and got the LCD mounted in the surround.
__________________
Old 30th Nov 2016, 15:12   #9
stealth80
Supermodder
water block arrived (thanks Overclockers.co.uk amazing customer service) and backplate finished up, now installing the GPU and adding the final tubing!
__________________
Old 30th Nov 2016, 15:43   #10
Cown
Supermodder
Cown's Avatar
Cown has yet to learn the way of the Dremel
Looking good
Love the white colorscheme, great job so far
__________________
Finished Projects:
ROG Meets Lian Li - Picade - Mr. Wallmount - Milk on the Wall WIP: The Iron suit project
Facebook page:
Cownbuilds
Cown is offline   Reply With Quote
Old 30th Nov 2016, 19:32   #11
stealth80
Supermodder
Originally Posted by Cown View Post
Looking good
thanks!
__________________
Old 30th Nov 2016, 19:32   #12
stealth80
Supermodder
ok so I got everything sorted today, the block arrived yesterday, but I had serious Man Flu and slept only 40 mins before my night shift!
So today I could finish it up, especially as the back plate was finalised!
Good Load temps, this was with GTA 5 benchmark running
Fans turned out good
Only eye sore left is the keyboard, hopefully be moving onto an Asus Claymore (the whole reason for the 5 inch LCD)
__________________
Old 6th Dec 2016, 20:03   #13
stealth80
Supermodder
Surprise MOTM Nomination for November, Thanks!
http://www.bit-tech.net/modding/mod-...vemeber-2016/1
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
