Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 6th Jan 2017, 10:04   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
HDMI 2.1 introduces 8K60, 4K120, and 'dynamic HDR' support
Variable refresh rate for games, too.
http://www.bit-tech.net/news/hardwar...new-features/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 6th Jan 2017, 10:26   #2
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
So if a good chunk of the new capabilities are down to the cable, rather than just back-end, will there be any distinguishing factors between the older ones and newer? USB was quite good about this by making the connector interiors blue, made telling the difference really easy between older devices and cables (since not everything was made fatter).
It's just one of those little quality of life improvements that makes buying replacements or sorting out the ones from the inevitable cable bag a little easier.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: I Need Healing!, Parvum Argentum, Tower Level 10
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is online now   Reply With Quote
Old 6th Jan 2017, 11:59   #3
B1GBUD
More Biddy Bang Bang than Sean Paul
B1GBUD's Avatar
B1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming Saiyan
Dynamic High Dynamic Range?
__________________
Teh unofficial Bit-Tech proof reader and understander of all the necessary hashtags
B1GBUD is online now   Reply With Quote
Old 6th Jan 2017, 12:10   #4
Mister_Tad
Moderator
Modaretor
Moderator
Mister_Tad's Avatar
Mister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming Saiyan
I'm waiting for the next version before I upgrade - HDHDRHD
__________________
Dell XPS15 9560 | i7-7700HQ | 32GB DDR4 | GTX1050 | 1TB NVMe | 97WHr | 4K IGZO Touch | Philips 328P 32" 4K | W10 Pro
HP Microserver G8 | Xeon E3-1265Lv2 | 16GB DDR3 12800E | 120GB 840 EVO | HP P222 512MB FBWC | 4x 4TB WD Red | W2016 Std
Mister_Tad is online now   Reply With Quote
Old 6th Jan 2017, 12:13   #5
Anfield
Mod Master
Anfield's Avatar
Anfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming Saiyan
Moreover, the new HDMI 2.1 standard brings support for dynamic HDR metadata, enabling content makers to control levels of color, contrast and brightness on a frame-by-frame basis.
The important part here is that dynamic HDR will not require the new 48G cable to handle video in up to 4Kp60 resolution and thus manufacturers may add support for dynamic HDR even using a firmware update. That is not going to work for a lot of existing equipment because display pipelines work differently and many TVs are incapable of anything beyond HDR10. Moreover, recorded media (i.e., Ultra HD Blu-ray) does not currently support dynamic HDR (and when the next-gen standard emerges, it will bring a lot of other features, including a new content protection algorithm), which means that two primary sources for dynamic HDR content will be games and streaming media (which is an interesting thing, given the focus of AMD’s recently announced FreeSync 2 technology). It is also noteworthy that HDMI Forum does not currently mention particular HDR implementations, but only says that the HDMI 2.1 standard will support a variety of them.
http://www.anandtech.com/show/11003/...0-48gbps-cable
__________________
R7 1800X, ASRock X370 Taichi, 2x8GB Corsair Vengeance 3000 DDR4, ASUS Strix 1080TI OC, 512GB Samsung 950 Pro, 4TB WD Black, EVGA T2 1KW, Lian Li PC-O9WX, EK Supremacy Evo, EK-XRES 140 DDC 3.2, EK-CoolStream PE 360, Ducky Shine 6 (Brown Switches), Logitech G402, AOC U3477PQU (34" 21:9 ftw)
Anfield is offline   Reply With Quote
Old 6th Jan 2017, 12:23   #6
Corky42
What did walle eat for breakfast?
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
With FreeSync, Adaptive Sync, and now Game Mode VRR Nvidia's GSync is looking increasingly redundant, that's assuming Adaptive Sync and Game Mode VRR are just different names for what's essentially FreeSync.
Corky42 is online now   Reply With Quote
Old 6th Jan 2017, 15:43   #7
DbD
Supermodder
DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.
If it is basically freesync then that will eventually be a huge boost for that format when the consoles support it. Although that might be 5 years off being as they just refreshed them all.
DbD is offline   Reply With Quote
Reply
Tags
48g, 4k120, 8k60, dynamic hdr, dynamichighdynamicrange, game mode vrr, hdmi, hdmi 2.0b, hdmi 2.1, hdmi forum, hdr, high dynamic range, robert blanchard, variable refresh rate
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
