Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 20th Apr 2017, 23:54   #1
Sentinel-R1
Morse Monkey
Sentinel-R1's Avatar
Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.
GPU sag - what are my options?
So with the impending arrival of my 1.3kg 1080 Ti Strix, I'm thinking about the saggage:
11:25 onwards - https://www.youtube.com/watch?v=50Alj8iizz0
I'm looking around for a solution but there seems to be really limited options available in the UK. MNPCTech do a lovely CNC machined brace for ~$45 plus shipping to the UK; however, there's seems to be few other options other than crappy perspex clones of the MNPCTech offering through eBay.
I'm not too concerned for the longevity of the motherboard's PCI-E socket as I'll likely upgrade before any long lasting damage is realised; however, the GPU I expect to get quite a few years from. Plus.... aesthetics.....
One other option I've explored is using carbon fibre rod or tube, from kite flying hobby shops, cut to size and used as a prop. It'll be under a tenner and would suit the build but not 'mounted' and secured as is my preference.
Anyone bother to brace their heavy cards or am I just being too particular? If so, what solution did you opt for?
__________________
6700K @ 4.7GHz | EVGA Z170 FTW | Asus ROG Strix 1080Ti OC @ 2012Mhz/12GHz | 16GB Corsair DDR4-3000
256GB Samsung 960 EVO NVMe | 500GB Samsung 850 EVO | 256GB Samsung 840 Pro | 3TB Western Digital Red
Corsair Carbide Air 540 | NZXT Kraken X62 | 3x Corsair HD120 RGB | 3x Corsair HD140 RGB | MNPCTech GPU Brace
Asus ROG Swift PG279Q 1440P@165Hz | Corsair K70 Mech | Roccat Kone XTD+ | Bose Cinemate 2.1 | Steelseries Siberia
Sentinel-R1 is offline   Reply With Quote
Old 21st Apr 2017, 00:40   #2
The_Crapman
Don't phone it's just for fun.
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
My gpu block is solid copper and I've mounted it vertically, so needed something to prop it up. I fashioned some pillars from aluminium angle strips. It's in this here thread near the bottom
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 21st Apr 2017, 01:16   #3
Sentinel-R1
Morse Monkey
That's a nice solution and similar to the idea I had with carbon tubing, which I can profile to fit the contour of the gpu.
__________________
Old 21st Apr 2017, 13:20   #4
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.
If still interested in MNPCTECH GPU SUPPORT, contact Mady via https://mnpctech.com/contact-us.html
Let her know about this post, and she can do promotional deal for you, to help save on shipping
__________________
My GPU support brackets We Ship International Orders!
mnpctech is offline   Reply With Quote
Old 21st Apr 2017, 16:36   #5
Sentinel-R1
Morse Monkey
I shall do just that! That's very kind of you, thanks very much! When I receive it, I'll return the favour and post up some pictures.
Edit: Email sent to Mady.
__________________
Old 21st Apr 2017, 18:10   #6
Sentinel-R1
Morse Monkey
For those interested, all ordered! Great discount too. Thanks MNPCTech.
Looking forward to it arriving.
__________________
Old 22nd Apr 2017, 01:21   #7
The_Crapman
Oooo that's nice. I'd seen something similar somewhere recently, but it was bigger and more triangular. Can't for the life of me think where. Possibly a custom mod somewhere here.
__________________
Old 26th Apr 2017, 15:41   #8
mnpctech
bit-tech sponsor
mnpctech's Avatar
Awesome! Thank you Sentinal
*currently busy finalizing my design for a vertical GPU bracket, so we can swing into production soon. This is the stage 1 prototype for mnpctech.
__________________
Old 26th Apr 2017, 16:03   #9
Otis1337
aka - Ripp3r
Otis1337's Avatar
Otis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming Saiyan
sweet jesus, thats looks nice, opens up so meany possibility's .
__________________
Haswell killer - Long live x58
GTX 1080 FE::Xeon X5650 Hex @ 4Ghz::H110i GT::Asus P6T SE x58::Patriot Tri DDR3 12GB
CoolerMaster 850W RealPower::Phanteks Enthoo EVOLV::Sammy F3 1TB::OCZ SSD 2x120GB::Asus Xonar - HyperX Cloud
Otis1337 is offline   Reply With Quote
Old 27th Apr 2017, 13:24   #10
Sentinel-R1
Morse Monkey
GPU bracket arrived in 4 working days from MNPCTech - excellent service!!!!!
Thanks and will post up some pics later on tonight when I'm home.
It's beautifully machined....
__________________
Old 27th Apr 2017, 13:42   #11
Yadda
Vegan Sandwich
Yadda's Avatar
Yadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming Saiyan
That bracket's a neat idea.
The main reason I have my case in "desktop" orientation is to give my graphics card an easier time.
__________________
Lost a Duff, gained a Charlie.
i5 4690k @ 4.6GHz / ASRock Z97m OC Formula mATX / 2x8GB Crucial Tactical DDR3 @ 2200MHz C10 / EVGA GTX 780 @ 1200/6400MHz / BX100 250GB SSD / Seagate 2TB SSHD / Nepton 240m AIO / EVGA 600B PSU / Corsair Carbide Air 240 / Win10 Home / 1080p monitor / Logitech MOMO wheel
Yadda is offline   Reply With Quote
Old 27th Apr 2017, 19:21   #12
Sentinel-R1
Morse Monkey
Thanks MNPCTech It solved the sag issue very nicely indeed!
Excuse the phone pics but my DSLR is still in the shop:
__________________
Old 28th Apr 2017, 13:59   #13
mrMonkeyChunks
EVGA Cheesecake
mrMonkeyChunks's Avatar
mrMonkeyChunks is a Super Spamming SaiyanmrMonkeyChunks is a Super Spamming SaiyanmrMonkeyChunks is a Super Spamming SaiyanmrMonkeyChunks is a Super Spamming SaiyanmrMonkeyChunks is a Super Spamming SaiyanmrMonkeyChunks is a Super Spamming SaiyanmrMonkeyChunks is a Super Spamming SaiyanmrMonkeyChunks is a Super Spamming SaiyanmrMonkeyChunks is a Super Spamming SaiyanmrMonkeyChunks is a Super Spamming SaiyanmrMonkeyChunks is a Super Spamming Saiyan
Might have to pick up one of these as well, my 980Ti Classified weighs the equivalent of a small car with its waterblock and my current acrylic tubing solution is not the most attractive option.
__________________
Parvum 2.0 i7 4790k | G1.Sniper M5 | 16GB DDR3 2400mhz RAM | EVGA 980ti Classy | 3TB | 240GB SSD | 500GB SSD x2 | Corsair 850W |
Cooling: 2x 240 Rads, MCP350 Pump, EK CPU & GPU Blocks
Ducky Shine 3 | Logitech G900 | Dell 29"
mrMonkeyChunks is offline   Reply With Quote
Old 1st May 2017, 15:21   #14
mnpctech
bit-tech sponsor
mnpctech's Avatar
PERFECT!, Thanks again Sentinel-R!
Surething, just contact Mady, include full name, address and phone via https://mnpctech.com/contact-us.html
__________________
Reply
Tags
fix gpu sag, mnpctech support arm
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
