RSS
Reply
Thread Tools View Mode
Old 7th Jan 2004, 11:27   #121
legoman666
Beat to fit, paint to match.
legoman666's Avatar
legoman666 will become famous soon enough
I installed the new button and worked on some more of the wiring... no picture tho because my mother took the camera into work for for a bit... I guess you'll just have to take my word for it that it looks really nice.
legoman666 is offline   Reply With Quote
Old 7th Jan 2004, 16:03   #122
DeViLSpArK
Minimodder
DeViLSpArK's Avatar
DeViLSpArK is on a distinguished road
Good work but the switches in the front looks not so great
but happy modding
__________________
Avance: 65,2541%
Visit: Casemodder
DeViLSpArK is offline   Reply With Quote
Old 8th Jan 2004, 23:14   #123
legoman666
legoman666's Avatar
Got my camera back today, heres the pics i promised...
Old 8th Jan 2004, 23:54   #124
[WP@]WOLVERINE
Supermodder
[WP@]WOLVERINE's Avatar
[WP@]WOLVERINE is on a distinguished road
Simply amazing!!!
A work of art!
__________________
Intel i7 965 EE | 3gb Corsair DDR3 1600mhz | Asus P6T Deluxe OC Palm ed | Dual Asus ENGTX280 1gb Top ed@Sli | Corsair HX1000 | SB X-Fi Fatality | 5.1tb storage+300Gb Velociraptor | Lian Li pc201 | Samsung T240+931BF | Ms Natural 4000 | Logitech G5 | Logitech Z-5450.
[WP@]WOLVERINE is offline   Reply With Quote
Old 9th Jan 2004, 00:40   #125
leber
Multimodder
leber is on a distinguished road
wow great case, I really like the stain you picked.
leber is offline   Reply With Quote
Old 9th Jan 2004, 01:44   #126
A13n0rma1
Wannabe
A13n0rma1's Avatar
A13n0rma1 is on a distinguished road
Wow. Master of wood and case, I salute you!
__________________
XP-m 2400+@ 2.4 GHz | Abit NF7-S v2.0 | 512mbDDR400 | AIW 9600 Pro | Hercules Fortissimo 7.1
A13n0rma1 is offline   Reply With Quote
Old 9th Jan 2004, 05:21   #127
glennd_05
Multimodder
glennd_05's Avatar
glennd_05 is on a distinguished road
thats a sweet case "cover" man. I just read the whole thread. My dad is a finish carpenter so i can really appreciate the true beauty of wood, its just beautiful. I like the color the Linseed oil gave it
-glenn
__________________
Project: Burning Full Tower
"Computers are useless. They can only give you answers."
-Pablo Picasso.
glennd_05 is offline   Reply With Quote
Old 9th Jan 2004, 06:47   #128
Tech-Daddy
Hypermodder
Tech-Daddy's Avatar
Tech-Daddy is on a distinguished road
I read from begining to now... done a great job on the wood, bro!
Excellent patience!
IMHO, I feel that the SPST switches almost look like "splinters" jutting out of the front of the case. They break the continuity of what is otherwise, a splendid example of creativity and vision!
Now, I have never made a wood case, and I have never made a fan bus or a bay bus, so I cant be as forthcoming on the whole "advice/part numbers" suggestion, but I can browse like crazy in Mouser, or I have a serious electronics warehouse here in Dallas that I can browse thru their stocks and if I find something that would work, I'll pic it and post it up.
However first and foremost... you have done an excellent job on this case. And if the switches are a part of your vision, tell me to STFU and just sit back and enjoy the ride!
Tech-Daddy is offline   Reply With Quote
Old 23rd Jan 2004, 11:41   #129
legoman666
legoman666's Avatar
Last update (sorta)!!!
I completed the case and everything is installed in it!
Only two problems, my reset button seems to be fried, which is no big problem but does need to be fixed sometime...
and the other problem is with the fan switches. They are supposed to switch the ground on the fans between 0V and 5V, thus changing the fan's voltage from 12V to 7V. But when i have all the fans at 12V and switch one to 7V, the psu makes an odd noise, but the fan does go to 7V. But then when i switch 2 fans to 7V, it works for about 3 seconds and then the psu shuts off. (I tested all of this before I put the system in) Now this really confuses me and Ill make a diagram of the wiring and post it later.
Pictures:
um... yeah, my mother has the camera at work again, I'll have it back at 4:15PM today (its 6:41AM now) so until then.....
Old 23rd Jan 2004, 17:23   #130
tm36usa
I *am* a Dremel
tm36usa's Avatar
tm36usa is an unknown quantity at this point
it sounds like there might be a short with ur fan switches if the psu auto offs after about 3 seconds. Mabey you should check ur wiring. I will take a look at the diagram when u get it posted and see where you might have gone wrong. Nice Job!
__________________
Project Double Helix
01110100011011010011001100110110011101010111001101 100001
tm36usa is offline   Reply With Quote
Old 23rd Jan 2004, 17:47   #131
Gnemelf
Supermodder
Gnemelf's Avatar
Gnemelf is on a distinguished road
thats super nice I love seeing woodwork intigrated into pc's.. Cause that was my original job :P working with wood... fun stuffs.
Very nice work too
Gnemelf is offline   Reply With Quote
Old 23rd Jan 2004, 22:32   #132
legoman666
legoman666's Avatar
Here are the pics and wiring diagram as promised. If anyone wants a shot from a particular side or angle, let me know and ill see what I can do.
Theres the wiring diagram, if you need anything explained, just ask.
Comments welcome!
Old 24th Jan 2004, 04:42   #133
maeterlinck
Supermodder
maeterlinck's Avatar
maeterlinck is on a distinguished road
Hey! Well done - it looks dead good! I'd be tempted to agree with other people in that the toggle switches on the front don't match the general 'look' of the case - but this can be a mod for later!
One thing though - tidy your cable inside!
re: Circuit diagram, if that's what you've done then all should work. However, I'd guess that something is shorting across or a switch is faulty. Continuity check everything (with the power off).
HTH
maeterlinck is offline   Reply With Quote
Old 24th Jan 2004, 22:07   #134
legoman666
legoman666's Avatar
boink
Old 24th Jan 2004, 22:24   #135
Tech-Daddy
Hypermodder
Tech-Daddy's Avatar
Nice pics!
Super nice case!
Sleeve those power cables and get that yellow, red and black attack out of there!
Old 24th Jan 2004, 22:27   #136
my58vw
Plexi Expert
my58vw's Avatar
my58vw is on a distinguished road
Needs some lighting... looks great. I wish I could do wood like.
good job
__________________
Total Mod (n) :: Project Divergence and Convergence...
Project Divergence The Ultimate Premod First Place PC Club CM3 Case Modding Contest
Project Convergence Bit-Tech's next great Plexi Mod - Handcrafted Modified Art in Action
PC's :: Designed on a Mac... 12 inch powerbook running sketchup 5...
my58vw is offline   Reply With Quote
Old 24th Jan 2004, 23:02   #137
legoman666
legoman666's Avatar
good job
actually, ive installed a blue CC since i took the pics.
Old 24th Jan 2004, 23:14   #138
Incorpirate
Supermodder
Incorpirate's Avatar
Incorpirate is an unknown quantity at this point
coolio we want new pics then
__________________
[font=Garmond]
[incorpirate]
[Project C2 in the making.]
[/font]
My first mod
Incorpirate is offline   Reply With Quote
Old 24th Jan 2004, 23:21   #139
legoman666
legoman666's Avatar
coming right up...
Old 24th Jan 2004, 23:26   #140
legoman666
legoman666's Avatar
kinda blurry...
i need another for the bottom of the case..., i have a UV CC and a white CC, but they dont match the theme of the other lights...
edit: it appears i exceeded my bandwidth.... i didnt even know i had a bandwidth limitation.... so the pics should go back up soon...
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
