Reply
Thread Tools View Mode
Old 31st Oct 2003, 16:26   #1
Mr. Red
Multimodder
Mr. Red's Avatar
Mr. Red has yet to learn the way of the Dremel
Project: Deja - Wooden Lugable
HOWDY!
Ok, so here goes my first attempt at MODs. My goal here is to build a reasonably portable PC for gaming at Lan-Parties. It also wouldn't hurt to have something that makes people say "COOL" when they walk by!
To keep cost down I am going to use whatever I have lying around first. That means that the case will be built of wood and it has to hold a full size MB, HD, and Keyboard.
So lets begin....
Part 1: What am I getting myself into?
Part 2: Or should I say Take 2??
. Part 2 Continued.....
Part 3: And If I solder this to that.....
Part 4: Sound, looks, and.... WHAT THE?
Part 5: Now what
. Part 5 Continued.....
Part 6: Better late than never.....
Part 7 - A more colorful tale......
Part 8: Look at all the pretty colors......
Part 9: A Picture is Worth a Thousand Words......
Part 10: Here we go again....
Part 11: The Key here is......
I have already done quite a bit of work on the project, but haven't had any way to post pics till now (thanks 486hawk), so I am gonna do a recap of what have done so far. I must also warn that I am a picture freak. I spend as much time taking pics of my mods as I do working on the mods. If it looks like it is getting outta hand, please let me know.
First I layed out my hardware:
MSI KT3 Ultra MB, ASUS 300W PS, Regular PS2 KB, and Seagate 40GB HD.
I mounted the HD using L brackets and I glued on some stand-offs. My screws were too long, so I used nuts as stand-offs.
Next I decided to get a bit more creative. I decided that the keyboard should match the rest of the case as much as possible.
I didn't mesure correctly and had to "fix" my mistake by shaving off part of the KB.
Next I started working on the sides. I cut as much wood out of the sides as I could for air-flow.
Now the placement test
Its a close fit, but I was satisfied. Did some testing that night and the system kept crashing. After messing around with it a bit, found that changing the AGP card made the system stable again. Looks like I need to get another video card.
I will post more pics later!
Mr. Red is offline   Reply With Quote
Old 31st Oct 2003, 16:37   #2
pranks7er
mange tout
pranks7er's Avatar
pranks7er has yet to learn the way of the Dremel
kool looks like and old BBC computer
pranks7er is offline   Reply With Quote
Old 31st Oct 2003, 16:42   #3
ReFredzRate
Relix Headshot!!
ReFredzRate has yet to learn the way of the Dremel
yeah... dare to make a difference I like it.. where'd you get the idea actually? And errr... will it have casehandles? ^_^
ReFredzRate is offline   Reply With Quote
Old 31st Oct 2003, 16:57   #4
STellY
Supermodder
STellY has yet to learn the way of the Dremel
Re: Project: Deja - Wooden Lugable (part1)
i wouldnt give up that quick... go through ur MB manual and see if there are any jumpers, settings, etc. that arent how they are supposed to be...
and your project looks pretty good... keep up the work im interested in seeing how it finishes up
STellY is offline   Reply With Quote
Old 31st Oct 2003, 17:03   #5
ZapWizard
Enter the Mod Matrix
ZapWizard's Avatar
ZapWizard can run CrysisZapWizard can run CrysisZapWizard can run CrysisZapWizard can run CrysisZapWizard can run CrysisZapWizard can run CrysisZapWizard can run CrysisZapWizard can run CrysisZapWizard can run Crysis
Mr. Red is another one of my friends I trapped into modding.
I think you should get a AGP 8X motherboard rather then a new graphics card.
ZapWizard is offline   Reply With Quote
Old 31st Oct 2003, 18:14   #6
jezmck
I Mod, Therefore I Own
jezmck's Avatar
jezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyan
anyone else getting red crosses?
jezmck is offline   Reply With Quote
Old 31st Oct 2003, 19:31   #7
Mr. Red
Multimodder
Mr. Red's Avatar
Not familiar with those, you got a pic? Most people tell me it looks like an Apple 2.
I am a moblie guy by trade, so I kinda tried for that look. I was originally going to base the design off of the notebook that was used in Congo, but I didn't like the look after I found the pics of it. As far as the casehandles, I got a handle on it right now. I will post an update as soon as I get the pics ready.
The video card in those pics is a Creative 4x AGP card that someone gave me. They were having problems with it. The thing was getting REALLY hot, so I tried replacing the heatsink with a better one. No luck aparently, so I am putting it aside for now. I think it is too big for what I want anyway.
Old 31st Oct 2003, 19:47   #8
Mr. Red
Multimodder
Mr. Red's Avatar
I got a cheap KOGI 14" LCD screen from best buy to use as the display. It's definitely not the best on the market, but nothing came close to the price. They asked me if I wanted a warranty.. I declined……
I tested it after I took it all apart. Not the greatest pic, but it survived!!
Old 31st Oct 2003, 19:54   #9
Eaglespirit
Minimodder
Eaglespirit has yet to learn the way of the Dremel
how much did that display cost? Me want one!
__________________
Be with your friends and family as much as you can.
I lost my father on my and his happiest day
Eaglespirit is offline   Reply With Quote
Old 31st Oct 2003, 19:56   #10
complexprocess
Supermodder
complexprocess's Avatar
complexprocess has yet to learn the way of the Dremel
LOL!
Awesome work so far, I can't wait to see how it progresses.
__________________
Nothing but the process...
complexprocess is offline   Reply With Quote
Old 31st Oct 2003, 20:03   #11
Mr. Red
Multimodder
Mr. Red's Avatar
I got it for $180 US. It was the display model.
Here is a better pic of it running!
Jazzle,
I am using space from the same place as 486Hawk. (I think you had the same problem with his post) I will look into it, but I am not sure there is much I can do.
Is anyone else having problems?
Old 31st Oct 2003, 22:14   #12
Mr. Red
Multimodder
Mr. Red's Avatar
Part2: Or should I say Take 2??
So I got a new Video Card:
Then I said what the hell, since I am spending money....
Got some speakers and took them apart.
I also got a smaller power supply at 250w:
This will alow me now to make the case smaller, so that means I get to rebuild!! Back to the cutting board...
Checked placement again.
Finished cutting the sides.
Tacked on side peices using small nails from a power staple gun!
Next I reinforced the sides with glue. This will also prevent light from escaping through cracks if I decide to light up the inside, which is in the plans right now.
To keep the keyboard covered, I have to recut the holes in a new board since the other one is too short now.
Cutting two more braces for the lid. Opps did I say to much?
Old 31st Oct 2003, 22:37   #13
bard
Modding isn't what it used to be
bard's Avatar
bard has yet to learn the way of the Dremel
This is very cool. Sort of like one of those ancient computers. But couldn't you have made it even smaller by having the hardware (mobo, gfx) mounted vertical behind the TFT?
Anyway, very cool. What kind of finish are you going to have on it?
bard is offline   Reply With Quote
Old 31st Oct 2003, 23:03   #14
CharlieCat
Supermodder
CharlieCat's Avatar
CharlieCat has yet to learn the way of the Dremel
I like it a lot integrating the keyboard is very neat.
You've shown some top woodworking skills there mate
It really does look like a BBC Master comp though...they were real big over here in the UK schools.
How sturdy is the construction ?
Only thing I might have changed would have been to make the keyboard section fold down or slide out to make the unit smaller when not in use.
Cheers, CC
CharlieCat is offline   Reply With Quote
Old 31st Oct 2003, 23:05   #15
legoman666
Beat to fit, paint to match.
legoman666's Avatar
legoman666 has yet to learn the way of the Dremellegoman666 has yet to learn the way of the Dremel
looking good but i dont like the choice of wood, use something that doesnt look cheap (no offense)
check out my case i'm making out of cherry: http://forums.bit-tech.net/showthrea...threadid=38878
legoman666 is offline   Reply With Quote
Old 31st Oct 2003, 23:06   #16
Mr. Red
Multimodder
Mr. Red's Avatar
hmmm, maybe, but I think I am too far along now. Not sure what I am going to do to the outside yet. Both Zap and 486Hawk said I couldnt paint it, so I am thinking either stain it or get Zap to help me replace the wood with plexi! You know, since it is his fault I am doing this in the first place! ^_^
Old 31st Oct 2003, 23:30   #17
Mr. Red
Multimodder
Mr. Red's Avatar
Hey CharlieCat,
Thanks for the pic. See what you mean. That will change a bit. Proably looking more like the Apple2 when the screen is attached. Construction is pretty stable. I havent done any drop tests, but I have carried it around without anything breaking yet. I am a bit worried though. The wood is only 1/4 inches thick.
[QUOTE]Originally posted by legoman666
[B]looking good but i dont like the choice of wood, use something that doesnt look cheap (no offense)
QUOTE]
None taken, the wood was what I had, so no cost. I would really like to do the plexy thing, but I am not sure yet. I kinda like the wooden look; however, you are right, in some spots it looks very bad.
*bows down* I am not worthy of looking at your post! VERY nice.
Old 1st Nov 2003, 00:04   #18
Mr. Red
Multimodder
Mr. Red's Avatar
Another placement test. WOW perfect fit! And I didn't measure it either!
Cutting holes for the speakers.
Speaker one done!
Now to cut the cover for the display. Used a dremel to start the cut and finished with a jig saw. I like the result...
Next I tacked the monitor frame to the speakers. Just ignore the extra cut on the right speaker hole. Uh, don't know how that got there!
Reinforced the back and glued everything down.
What it is going to look like.
Redoing the KB cut-out. This time I used the dremel/jig saw combo and it turned out a LOT smoother.
Screwed the KB in place.
Put everything in place and pretended what it would look like done.
Finally I mounted a couple of cabinet hinges I got from the Home Depot. Dont know why, but I liked the big bulky look of them.
OK, OK, so it's not as small as I would like it to be..... But I still think it is looking good!
More later...
Old 1st Nov 2003, 00:16   #19
Yo-DUH_87
Who you calling tiny?
Yo-DUH_87's Avatar
Yo-DUH_87 has yet to learn the way of the Dremel
Looking very nice there, I like it
How are you planning to finish the wood, are you going to use stain or something along those lines?
__________________
Yo-DUH_87
If it works, fix it until it's broke!
Then, after it's broke, add duct tape!
Affordable Web and Picture Hosting
<+Da_BaCoN> doubt leads to fear. fear leads to anger. anger leads to hate. hate leads to the dark side and thus, cool lightning powers!
Yo-DUH_87 is offline   Reply With Quote
Old 1st Nov 2003, 01:02   #20
Lovah
Apple and Canon fanboy
Lovah's Avatar
Lovah should be considered for presidentLovah should be considered for presidentLovah should be considered for presidentLovah should be considered for presidentLovah should be considered for presidentLovah should be considered for presidentLovah should be considered for presidentLovah should be considered for presidentLovah should be considered for presidentLovah should be considered for presidentLovah should be considered for president
??? 180$ ??
I only payed 200€ , for a brand New , 17" Acer AL718 LCD ...
Oh well,
Looking very good though !! I love the wood-look around the keyboard !
I really like the warmth that wood give's... keep the wood-look.. don't paint it or something.... maybe some oil to protect it though.
Nice Job !! , looks like one of them first laptops !
=L
__________________
Canon 5D + Grip | Canon 5D mkII
EF 17-40mm F4 L | EF 35mm F1.4 L | EF 24-70mm F2.8 L | EF 50mm F1.4 | EF 85mm F1.8 | EF 135mm F2.0 L
Manfrotto 190ProB + 486RC2 | Canon 430EX + OC-E2
MacBook Pro 15" 2.2ghz | iMac 27" i7 | iPad 2 16GB WIFI
Lovah is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
