Guide How To: Make a cheap (69c) molex pin remover.
Discussion in 'Modding' started by thw01f, 20 Dec 2003.
  1. thw01f
    thw01f What's a Dremel?
    13 Sep 2003
    edited 31/10/06, pics updated
    This is a pic guide on how to make and use a molex pin remover using a 3.5mm MONO from your local electronics store.
    This tool only fits female molexs only, but if you can't get the male ones out with a screwdriver, don't look any further.
    First up: get 1 of
    then cut the tip off with side cutters or whatever takes you fancy. The remaining guts should then slide out the inside of the plug.
    You then have
    align the tool like
    push in and give it a jiggle as you pull slightly on the wire
    who's your daddy
    go for broke remembering where the wires came from
    then do your stuff, braided sleeving, heatshrink, fluoro, plain, wiring cut to length, joins, whatever.
    then just pop the pins back in when your finished.
    the pins should still have the tabs slightly stickin out but check to make sure.
    this is the best way to remove them.
    if you bend them permanently with a screwdriver or something they can break off when you bend em back
    here's an one I finished ealier
    cheers,
    thw01f
  2. Bildonia
    Bildonia What's a Dremel?
    29 Nov 2003
    wow...nice work...i might try that sometime...how did ya figure that one out??
    BTW...santa IS bringing me a DVD burner
  3. thw01f
    13 Sep 2003
    too much time.
    DVD burner. you lucky b...............
  4. x3r0
    x3r0 What's a Dremel?
    29 Oct 2003
    weee
    /me goes down to dick smiths
    saw this guide on ocau
  5. Thunder_return
    Thunder_return What's a Dremel?
    8 Jun 2003
    Nice guide, I might try it today, I got plenty of time ,since I am sick and home alone..
    Thanks!
  6. KRASH
    KRASH What's a Dremel?
    27 Oct 2003
    That is a slick solution to an age old problem! I will have to try that. thanks for the tip.
  7. Thunder_return
    8 Jun 2003
    I did try this thing but I had wrong sort of plug :grr:
    I tryed something else, I used a mini-screwdriver.
    The metal in the molex was so thin that I was able to bend the pins in and pull the cable out and when putting it back I just bended the pins out and pulled them in.
    I did that on every molex and after 2 or 3 hours I had sleved
    my psu cables :clap:
    I will post some pics on that in my log later.
    Merry Christmas!
  8. Atomic
    Atomic Gerwaff
    6 May 2002
    Very useful!
    nice one.
  9. skyrex
    skyrex What's a Dremel?
    22 Dec 2003
    you would only need something just a wee bit longer for the male molex plug wouldnt you? or is it the diam. of the plug thats the prob??
  10. Fatboy
    Fatboy Bored
    8 Oct 2001
    Can it remove both male and female? it might be ok as there only a slightly bit larger diameter wise.
  11. thw01f
    13 Sep 2003
    the male plugs are smaller in dia and the tabs are deeper than the female pins.
    Here's a tip for male pins from Xplicit at http://www.creativemods.com/forums
    "For the male side, take your male molex to the hardware store and ask for a roll pin that will fit and work in exactly the same manner."
  12. [t0rc]
    [t0rc] What's a Dremel?
    28 Nov 2003
    nice tool. Comes in handy a lot. thnx
  13. Petrov
    Petrov What's a Dremel?
    24 Dec 2003
    I was about to becmoe mad with the molex connectors! Thx allot... :rock:
  14. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Good guide, but exactly what size phono plug is that?
    1/8"?
  15. jake^the^cake
    jake^the^cake What's a Dremel?
    1 Oct 2002
    standard 3.5mm zap, read the post :p
  16. Fraggster
    Fraggster What's a Dremel?
    30 Dec 2003
    hrmm this might work better than the exacto-knife :clap:
  17. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    hmm, i tried this and i guss the pins were slightly larger than the jack..ended up raping my molex and bending the tabs
    ....ill stick it my jewellers screwdrivers :)
  18. raxxo
    raxxo What's a Dremel?
    24 Jan 2003
    WHEEE!!! Santa brought me a DVD-Burner too... mee sooo haaaappyyyyy :D
  19. popa
    popa What's a Dremel?
    6 Mar 2002
    use the little red coffee stirer straws
  20. ZapWizard
    19 Sep 2002
    I tired this today, it works wonders on about half of my molex connectors, the others I had seem to have a block inside.
    (In which case I use a screwdriver)
    Anyone got a good way to remove the square modex connectors inside a motherboard power connector?
    I have done it with a tiny screw driver, but is smashes many of the connectors.
