Thread Tools | View Mode |
#1 |
Minimodder
Polishing A Harddrive (Images Fixed)
SiL3nT-Hard Drive Polishing Alrite step one , raid the old mans shed to find. *Cut and polish Compund *Sumkind of Wax *Rags Step One , Remove all stickers . If thier is any sticky stuff left use mineral turps or sugar soap to remove . Apply Cutting Compund , to remove grime and tiny scrathes . Apply with a rag . Okay Load your dremel up with the polishing pad and go over the Hardrive in long smooth lines not circles . ![]() How I set my hobby tool up (no its not a dremels , does everything a dremel does) . ![]() Alrite lets get sum wax polish , apply it by hand by dapping it on . Let it dry for 5 minutes , buff it off by hand by making little circles . ![]() Alrite it should be looking like this , Apply wax once and remove by buffing . ![]() Okay , your done your Harddrive should be looking like this Smile. ![]() ![]() ![]() ![]() ![]() SEXI! ![]() Pretty simple to do but very pleasing . Please let me know what you think !
__________________
"Im a voice that goes unheard" Msn : sil3nt__@hotmail.com Last edited by Sil3nT; 26th Jan 2005 at 18:13. Reason: Fixing Images |
#2 |
Custom User Title:
Very Nice, i've done this to a HDD before, but i didn't get as result as good as that, maybe i'll have to look into a different type of compound/wax since i used some cheapy stuff that looked like it was made in the 1920's.
__________________
Kemp yourself silly: www.rosskemp.co.uk
#3 |
Minimodder
it looks like a mirror
but will the shake harm the HDD?
__________________
Illusion never changed into something real. |
#4 |
Custom User Title:
I think the hard drive itself produces more vibration than a soft polishing attachment for a small-drill/dremel like that.
__________________
#5 |
Modder
is the top of that drive alu or steel? if its steel do you think it would work for alu too?
#6 |
Multimodder
very nice! at first glance i didnt even notice hdd!
#7 | |
Multimodder
__________________
MSI K9N SLI V2 AMD A64 X2 5200+ @3.29 Ghz OCZ PLATINUM 4-4-4-14 Gf 8800GT @ 710/1010 |
| NOTPENTIUM |
| View Public Profile |
| Find More Posts by NOTPENTIUM |
#8 |
Multimodder
Heh nice, might look mad with my custom built perpsex case.
#9 |
Minimodder
Let me know how it all works out dude . Good luck with your modding .
__________________
"Im a voice that goes unheard" Msn : sil3nt__@hotmail.com |
#10 |
weeee!
VERY NICE! I might do this with one of my drives.
#11 |
Modder
I followed your guide, I used it on certain parts of my case, it works very well.
#12 |
Boom baby!
Very nice!
Just a small caution though : Some hard drives have breather holes on the top cover, care should be taken when polishing these!
__________________
God is a trap. God is the answer when we don't know the answer. That means, when your brain is not enough big, when you don't understand, you go, "Ah, it's God, it's God." - Philippe Starck nothing to see here, move along... |
#13 | |
I -am- demotivation.
__________________
#14 |
yeah and if you take the cover off you can polish the discs inside at the same time!!
seriously though this will be l33t for my hd before i build up the courage to window her
#15 |
Minimodder
There is a reason why the air is sterile/100% clean when then produce HDDs...
Opening the disc, is not good at all, usually when people open them, they crash not long after... I would never remove the cover on any of my discs (if i wanted to use it again afterwards that is) |
#17 |
Pointless.
Looks very slick! Does the HDD corrode? I mean does it stay shiny?
#18 | |
Bored
__________________
>[DFI LAN-PArty UT NF4 Ultra-D]-[Athlon64 3200+ Winchester]-[1Gb Corsair pc3200]-[Vapochill Micro]-[Powercolor ATI Radeon X800XL 256Mb]-[Chieftec DX-01-YL With 6 Fans]< Pug- "The spirit of modding is unleashing your creativity in the pursuit of individuality." Current Project: Unnamed Chieftec Dragon Mod |
#19 |
Minimodder
If the drive has holes in the top plate, that is no worse then taking the top completely off is it?
#20 | |
Bored
__________________
| Tags |
guide ![]() |
| Thread Tools | |
| View Mode | |
