#1 |
Supermodder
How to test network connection ???
Hi ,
Just wanna ask all the geeks in bit-tech.net How to test network connection between two pc using the ping command in Windows (dos). Pc1 AMD Athlon 1600+ | Abit KT7A | 256Mb Sdram | Global Win TAK-68 | IBM Desktar 40.0Gb 7200rpm 60GXP | Yamaha 2100E 16/10/40 | Creative 52x |ATI Redeon VE 64Mb | Creative Vibra 128 | Dlink 538 TX 10/100 | Englight 415W Pc2 P2 233MhZ | E-Pox (un-known model) | 128Mb RAM | Maxtor 3.2 5400rpm | D-Link 538 TX 10/100 | S3 Virge | Pc1 network cable is 10Metre and Pc2 is 5Metre connected to Lantech 8 port Switch. BTW pc 1 is running Win2K and Pc 2 is Win98 Thanks |
#2 |
Nobody but us chickens
If I understand correctly you just want to ping another box, if so drop down to dos and type ping x.x.x.x the x.x.x.x is the ip of the other machine. The IP can be found on win9x/me by going to run and typing winipcfg. In NT/2k/XP drop down to a command box by typing cmd in a run box, then type ipconfig /all. If you have a modem on any of this boxes the details of that will be displayed first.
Hope that helps
__________________
A police recruit was asked during the exam, "What would you do if you had to arrest your own mother?" He said, "Call for backup." "you could have it all, my empire of dirt, I will let you down, I will make you hurt" |
#3 |
Ultramodder
yep thats right.
say that ; PC1 has IP = 192.168.0.1 PC2 has IP = 192.168.0.2 just drop to a dos prompt, or command box and just type "ping 192.168.0.1" and if they can see each other it will report something like this; Reply from 192.168.0.1; bytes=32 time=<10ms TTL=255 this information isnt really important, its just states that the network is resonding faster than 10ms. If there is a fault somewhere it will report ; Request Timed Out. This will mean the PC are not communicating, usally down to incorrectly configured firewall software. |
#4 |
Banned
Firewall software? the guy didnt mention anything about firewall software. You ned to make sure also that you are using the correct network cables, for a normal switch/hub between the PC's you need to use a standard CAT5 twisted pair network cable, and NOT a x-over cable (which is only used to connect multiple switches/hubs together OR to connect two PC's directly without any hubs/switches)
Also you need to make sure that the IP addresses are in the same ranger, using a compatible subnet maks also. For example, say PC 1 has an IP address of 192.168.0.1 and a subnet of 255.255.255.0, and PC2 has an IP address of 192.169 .0.2 and the same subnet of 255.255.255.0, then they wont see each other. All this may seem confusing but when you get your head around it then it will be a breeze. I know as I'm pretty network orientated from my job. Hope that helps.:cool: |
#5 |
Ultramodder
true, but why would he need such a restrictive sub-net
255.0.0.0 would be a lot easy as this doent lock him down so much |
#6 |
Banned
Hey I'm just trying to make things clear incase he has set the subnet mask to that range, some people may do so. Just covering all bases. Just a guy trying to help out. Sounds like you know some networking too though
![]() Just one thing, whats that picture of a laptop on your sig for? Do you have one? I've got 2 at home, great for just lying in bed when you cant be arsed to get to your PC
#7 |
netmask 255.255.255.0 will be just fine, unless he has over 255 pcs on the network. If he does then he shouldn't really be asking this type of question.
__________________
#8 |
Ultramodder
lets not argue, for fear of confusing him.
I would agree on setting the PCs up like this PC1 ; IP : 192.168.0.1 SUB : 255.255.255.0 PC2 ; IP : 192.168.0.2 SUB : 255.255.255.0 That should work fine |
#9 | |
inter arma silent leges
Moderator
__________________
"Flying is simple; push on the stick and the houses become bigger, pull back on the stick and houses become smaller, unless you keep pulling in which case the houses will become bigger again..." |
#10 |
Ultramodder
thanks fly, under your wing my network knowledge grows daily.
** BLLLLLARRRRRRGGGGGGG fetch a bucket ** |
#11 |
Banned
So Cypher MY suggestion of the subnet... you thank FLY for the knowledge???
Also your future rig.... PC133 ram??? and a celery cpu??? you obviously aint looking for a speedy machine!:rofl: Ack! |
#12 |
Ultramodder
well in theory either IP would have done, so its not such a bit issue.
I thanked fly coz i see him as a mentor for houning my networking skillz, i hardly know anything. Nad the future Rig, whats wrong with a Celeron, the core and everything is basically a P3. Anyway, you shouldnt really be posting comments like that into the networking thread, we are supposed to help this person, not argue or anything. Last comment : what i build is my business, not everyone has enuff money for a dogz bollox system, im not a heavy gamer, more a grpahical person. |
#13 |
Banned
"Nad the future Rig, whats wrong with a Celeron, the core and everything is basically a P3. "
I thought we weren't supposed to talk about that in the networking section It's just I remember a thread earlier that i seen about you thinking of starting a lan gaming company... And looking at your profile you're a PC engineer, us engineers always want to have the fastest units. Just thought you might of been a gamer as you're in a counter strike clan. Last edited by woppysittank; 27th Feb 2002 at 16:17. |
#14 |
Supermodder
Thanks
LOL but anyway thanks for all the replies .......
get to understand you guys explained but just need to know more about "sub mask" whats it function for? Oh yeah I also wanna ask what books do you recomand? |
#15 |
Supermodder
Oh yeah i seen those weird words below peoples name...
__CyPHeR__ how did you change them? sorry to ask questions not about networking stuff here
#16 |
Banned
Microsoft networking essentials is a very good book for understanding how networks run, to explain subnet masks is kinda like teaching the meaning of life if you know what I mean
#17 | |||
Ultramodder
Rights im gunna try to ansa all the questions in one post
--------------------------- Quote:
When i get around to it, you can unlock these procesors upto 2Ghz with watercooling. Oh and CS, you can run that on a Celeron 400 and still get 100 Frames, its only a 16bit game so a 2Ghz C will play no faster than a 1Ghz PC when you hit the 100FPS buffer. Rght personally i think this thread should be closed, as the original question has now been ansaed and this is now turning in to a hardware conversation. Thanks to everyone for keeping this thread a happy place
#18 |
Moderator
If you want to test the network connection for throughput you can uses SiSandra , it has a network testing tool as well as many others.
here is a website all about Windows networking. The guy is a bit of a guru but is German so his english isn't that hot and he has a weird sense of humour, nevertheless he is very informed! You will notice that I have changed my post about the network settings, 192.168.1.1 instead of 192.168.0.1 .
__________________
#19 |
Supermodder
LOL
__Cypher__ hard ware conversation...... Thanks alot m8 for answering all my questions I see 250 hmmm wonder when i can reach that point. hehe...woppysittank i just dun realy like micro$oft porducts ![]() bringging lots of headace.....
#20 |
If you really want to learn about networking, get a good *nux book. Why? , well *nixs were designed to be networked from day 1 unlike windows which had bits bolted on later on.I learnt more reading about linux networking than I did about networking at uni.
__________________
| Tags |
| network |
| Thread Tools | |
