Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 29th Mar 2004, 21:57   #1
Hitman
Ultramodder
Hitman's Avatar
Hitman has yet to learn the way of the DremelHitman has yet to learn the way of the Dremel
Shuttle SB51G & 2.4 Ghz P4 or Shuttle SN41G2 & XP1800+ (or better)
Im wanna build a Shuttle for use as a spare machine to backup files to, MP3 player (running 4am Music Console with a touch screen), my DVD player, and as a PVR.
I have two options though:
First a Shuttle SB51G with a 2.4 Ghz P4.
And secondly a Shuttle SN41G2 and something like a XP1800+ (or if I do run it as a PVR, then something like a XP2500+).
What do you guys think would be the best option?
Also, as the SB51G hasn't got onboard TV out, it means Id have to get the TV out addon card for it, or use a graphics card with tv out. But I will also have a PCI capture card in there. So would there be room for both the capture card, and the GFX card/tv out addon?
And which has the quieter PSU and HSF?
Hitman is offline   Reply With Quote
Old 30th Mar 2004, 17:43   #2
DaSuperFly
Ultramodder
DaSuperFly's Avatar
DaSuperFly has yet to learn the way of the Dremel
The TV-out add-on goes in the AGP slot i believe so you could fit a PCI capture card as well.
Either option of shuttle would work well but you'll have to change the rear fan if you want to use it as some form of HTPC.
DaSuperFly is offline   Reply With Quote
Old 30th Mar 2004, 20:15   #3
Hitman
Ultramodder
Hitman's Avatar
Okay
Apparently they use the same HSF and PSU, so they sound the same.
In the end, I guess its down to price.
Old 5th Jun 2004, 17:37   #4
Mr.Nonflex
Multimodder
Mr.Nonflex's Avatar
Mr.Nonflex has yet to learn the way of the Dremel
I would go for the amd option, as a p4 is overkill for your uses, and as you said your selfe the p4 option has no tv-out. Adding those cards gonna cost you. I would only go for the intel if it was your main rig.
__________________
What is impossibility but a challenge
Mr.Nonflex is offline   Reply With Quote
Old 7th Jun 2004, 12:30   #5
Penrhos
Supermodder
Penrhos has yet to learn the way of the Dremel
go for the SN41 then get the www.mythtv.org pre-built iso for nvidia chipsets and the correct PVR card and away you go
__________________
1)Shuttle SN85G4, A64-XP3000+, 2*256M PC3200, 160G Maxtor Sata,Pioneer 108, 9800Pro, XP-SP2.(18880 3dmark2001se)
2)Asus A7N8X Dlx, XP2800+, 2*512M PC2700, 2*120G sata - JBOD, 1*200G pata, Pioneer 108, 52X CDRW, 9800Pro, XP-SP2.(15,650 3dmark2001se)
3)Soltek Qbic QI3601, 512M PC2100, Pioneer 107, 48X CDRW - FTP and D/l PC
Penrhos is offline   Reply With Quote
Reply
Tags
sff
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
