T0xIc1ty- Scoping Parts+Planning Mods
Discussion in 'Project Logs' started by sickskater6911, 17 May 2004.
  1. sickskater6911
    sickskater6911 What's a Dremel?
    9 Oct 2003
    Specs:
    CASE:
    Infinity Silver Chieftec Dragon-$49.00
    COOLING:
    3x-MGE 80mm Green LED Fan-$10.50 ($3.50 each)
    2x-pcToys 80mm Green UV fan-$7.90 ($3.95 each)
    80mm Stainless Steel Radiation Grill-$1.00
    LIGHTING:
    Sunbeam Dual Green Cold Cathode-$3.50
    PcToys 12" UV Cathode Lights-$2.50
    Neon Maxx UV Paint Green-$3.50
    CABLE MANAGMENT
    Vantec Cable Sleeving Kit UV Green-$9.99
    pcToys 24" Green UV Sensitive ATA/IDE(dual)-$3.95
    pcToys 10" Green UV Sensitive Floppy-$2.95
    MoBo+Processor
    Abit TS-20 Intel 815E Socket 370 mATX MB & PIII 733MHz CPU -$56.00
    TOTAL WITH SHIPPING AND TAX- $190.73
    some how with all the buying location changes and acually ADDING items to the list, i have decreased the total price,
    I upgraded from the Celeron to the PIII cause it was accauly cheaper, and i have the cooler for it and have the memory for the mobo.
    around when ill be starting this project,
    My grandma is the best person in the world and said she would buy me the stuff, after my fourth quarter report card
    so i will be ordering stuff in just under 2 monthes
  2. sickskater6911
    9 Oct 2003
    That is the design for the side im gonna use, the center will be a Green LED fan, with a radioactive grill on it, and the "panels" of the symbol will be UV green acrylic and have modders mesh on it
    the one on the right is the deisgn for the top im gonna use
  3. sickskater6911
    9 Oct 2003
    DOES NEONE KNOW IF THEY MAKE REPLACEABLE TOP PANELS FOR CHIEFTEFS?
    i know the make bezel and side panel but wat about top?
  4. DustinE
    DustinE What's a Dremel?
    20 Apr 2004
    I dont think so.... I wanted an extra one to play with before i worked on my case's mods but i was unable to find another one... you can use sheet metal until you get everything worked out...
  5. sickskater6911
    9 Oct 2003
    here is a very rough idea of the bezel
    i will cut out part of the door, and fill it with either green painted modders mesh OR a window with modders mesh on it, or maybe sumthing else
    the bezel will be lighted up by the fans and maybe by a 4-6" cathode,
    more to come
    STAY TUNED :)
  6. Litecore
    Litecore What's a Dremel?
    21 Sep 2003
    since when did just plain mesh got namned "modders mesh" ? :eyebrow:
  7. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
  8. bleecher
    bleecher What's a Dremel?
    25 Apr 2004
    how gh3y. ive been using mesh from garages or welders for years. i done a similar mod about 2yearsago but both top and bottom of the front bezel. sickskater if u want any advice just ask or pm meh.
  9. Litecore
    21 Sep 2003
    well, i dont mean to be rude or anything like that..
    but bleecher has a great point in what he said :]
    but - so no one gets pissed at me - i was just curious.
    im sure that project of yours will come out great.
    mod on, with or without the modders mesh :thumb:
  10. sickskater6911
    9 Oct 2003
    can u gimme a pic of how urs turned out
  11. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    looking good! :baby:
  12. FILTHY1337
    FILTHY1337 Senior Overclocker
    4 Jan 2004
    hmm thoses prices are pretty low were did u buy those lights and fans ect. I didnt think anyone had prices lower than svc :eeek: good idea mod-on
  13. sKuLLs
    sKuLLs What's a Dremel?
    20 Feb 2004
    You know if you decided to use the design on the left, you could make the O a fan hole for a 120mm fan....
  14. sickskater6911
    9 Oct 2003
    thought about that, but figured it would look awkward and off centerd, and im pretty sure the PSU would get in the way
  15. sickskater6911
    9 Oct 2003
    if neone has a dragon could i get an exact mesurement of the front panel door
  16. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    I think its the mid-tower your talking about? I've got one, but I'm sure you can find the measurements online. Also, there is a sketchup model for the dragon mid-tower (and full-tower) in the Sketchup thread in Mod Guides.
    edit: a few sites confirmed 470 x 205 x 522mm (DxWxH)
  17. sickskater6911
    9 Oct 2003
    i got it from a different oard, butt tahnks of rthe heads up about the sketchup model, i was afraid id have to make it my self
  18. sickskater6911
    9 Oct 2003
    i know the demensions of the whole case i was llooking for just the swing door.
    also where is the mid tower?? i couldnt find it?
