Old 17th Mar 2002, 16:55   #1
Fatboy
Bored
Fatboy's Avatar
Fatboy has yet to learn the way of the Dremel
Need Help
im after a set of decks and a mixer for under £150. I need to know any recommendations.I dont really care how good the mixer is but the decks need to be O.K
Any where online that sells good DJ gear ?
__________________
>[DFI LAN-PArty UT NF4 Ultra-D]-[Athlon64 3200+ Winchester]-[1Gb Corsair pc3200]-[Vapochill Micro]-[Powercolor ATI Radeon X800XL 256Mb]-[Chieftec DX-01-YL With 6 Fans]<
Pug- "The spirit of modding is unleashing your creativity in the pursuit of individuality."
Current Project: Unnamed Chieftec Dragon Mod
Fatboy is offline   Reply With Quote
Old 17th Mar 2002, 17:03   #2
K
528491
K's Avatar
K has yet to learn the way of the DremelK has yet to learn the way of the DremelK has yet to learn the way of the DremelK has yet to learn the way of the DremelK has yet to learn the way of the DremelK has yet to learn the way of the DremelK has yet to learn the way of the DremelK has yet to learn the way of the Dremel
Under 150 squid? Eeeeee you'll be hard pressed to get anythin real decent for that price, it'll be a 'Belt Drive Only' thing... My mixer alone cost 200.
I think you should look local for some second hand stuff really, check the local papers and Yellow Pages etc etc
Anyhoo, I've bought a few bits off these guys before (Stanton Str8 60 Decks and a Numark Mixer) and they were sound with delivery and everythin so you could give em a go.
http://www.djstore.co.uk/
Their cheapest package looks ok actually, I like Numark stuff..... A LOT ... But then I was into Turntablism so you may think different I dunno
http://www.djstore.co.uk/cgi-bin/bro...t1510dm925pack
__________________
K is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
