Thread Tools | View Mode |
#1441 | |
Grease Monkey Undergraduate..
#1442 | |
Anal Modder
I don't know how often you venture over to the [H]ardForum A-C thread, but there is more info over there on what might or might not be in stock. There are also XT pics up as well.
__________________
H20 cooling: Go low and go slow Why can't I just be a mundane and slog it out with the good stuff? disturbed13: If its worth doing. Its worth over doing Project: Feeding Frenzy |
#1443 |
Hammertime
maybe this case is alot cooler then on the pics
#1444 | |
Why not? I own a domain to match.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net 40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8 MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD |
#1445 | |
Anal Modder
__________________
#1446 | |
__________________
#1447 |
Minimodder
Great mod modsquad. One quick question. Are you using a chipset block 'cause I can't find it on any of the pics (I might have missed it though). I'm thinking about using the same CPU bl;ock but can't find a chipset cooler that would match it or at least be similar
#1448 | |
__________________
#1449 | |
Minimodder
they should make one. That would be an awesome looking combo.
#1450 |
Bit-tech's site upgrade set me back. I did get some work done over the weekend and should have a update tomrrow..
#1451 |
Switches & Reservoir Mod
Months and months ago I installed these two rocker switches and a 5mm LED running light to control the case lighting.
![]() As I have done so many times, I changed my mind about the rocker switches. I will be using two toggle switches to control lighting. The hardware for my "vandal-toggle" switch. ![]() The mounting ring for the toggle is from a Bulgin Vandal switch. ![]() Love or hate the look, they are one of a kind. Wiring, nothing special. Wired inline with the 25" Molex extension cables I made up a few weeks ago. ![]() ![]() Please Note: I only purchased and installed one switch, I wanted to see how the built-in LED would look.. ![]() ![]() ![]() I like the look. I will order another switch to finish-off the installation. Up next the reservoir mod. A few pages back, we talked about a RED acrylic cover plate for the Innovatek reservoir. The problem being, cutting a perfect circle that small from acrylic is difficult. I got a hold of Chris at Cutting Edge Case Mods being the generous man he is, he donated two in order to help me finish the case. Using the stock cover as a template, I marked the mounting holes on the new red one. ![]() ![]() I re-installed the two covers on the reservoir using low-profile hexhead bolts. ![]() ![]() I lowered the reservoir down into the case so the red acrylic cover would sit flush with the top of the case. This ended up being EZ. The thickness of the stock reservoir mounting bracket (which I was not using) mounted inside the case plus the thickness of the case itself is "just-about" right. ![]() I also changed-out the stock res. bolts for more of the low-profile type. ![]() The only drawback to a colored reservoir cover like this is it is difficult to see your H20 level. I think the LED in the bottom of the res. will cure that problem. I did not get that far, so we will find out. If not Aqua-Computer is "said" to be ready to release there tubemeter. ![]() It is a liquid level sensor for your reservoir which will be powered by the AquaBus on there Aquaero displays..Pretty cool That's it for this "go-around".. MS Last edited by modsquad; 19th Sep 2008 at 01:26. |
#1452 |
a Self Confessed HP Server Lover!!
thanks for that mate, it looks mint, i will be doing this for mine!!
Phil |
| PHILIP1193 |
| View Public Profile |
| Find More Posts by PHILIP1193 |
#1453 |
Multimodder
whaha nice done with that soft metal ready to tape in on your case
__________________
this sig was too long. and too annoying. |
#1454 | |
#1455 |
Multimodder
No I can't figure out what Pitbull is on either
Needless to say the detail just keeps on coming - this project really is fantastic Just don't take too long or you'll get no use from the investment in parts before the need to upgrade bites you
__________________
---------------------------------------------------- "I keep six honest serving-men, they taught me all I know; their names are What and Why and When, and How and Where and Who" 1s project Xarig AQ SLi |
#1456 |
Wow, great work! That aquatube h2o meter is a sweet idea... hope they get on it soon!
Thing is that you've got the FoM and not the AT, and they use different threads. Not sure whether you actively realized that, but regardless you'd have to pick up an appropriate adaptor. Switch is very different, extremely unique. Well done!
__________________
#1457 |
Hammertime
you just love red
#1458 | |
#1459 |
Modder
The amount of time & money you are throwing into that PC is blowing my mind.
But damn it looks good. |
#1460 | |
__________________
Black Narcissus Soylent Green CopperHead PERFORMANCE-PCs Sidewinder Computer Systems |
| Thread Tools | |
| View Mode | |
