Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 28th Jul 2004, 14:45   #1
N4N01D
Supermodder
N4N01D has yet to learn the way of the Dremel
How to setup a VPN Server & Client - WinXP [NOT 56k Friendly]
Ok, so you want to setup a VPN Server, 1st you have to think what OS, Internet Connection (and method, i.e. router or modem on a pc) and a few other things.
First off this tutorial is for Windows XP only.
The Steps
1)On the computer which you want to be the Server (the one people will dial into) go to the Control Panel as shown below.
2)Go to the Network Connection in the Control Panel, as shown below.
3)Now on the left hand side in the Common Task Box, there is a section “Network Tasks”. Click on this option.
4)This will start the wizard to make the VPN connection (server side) Click Next. As shown below.
5)On the next Page Select the “Set up an advanced connection” and click Next.
6)On this page Select “Accept incoming connections” and click Next.
7)On this page click Next. Don’t worry if it says “Direct Parallel” this wont be used.
8)Select the option “Allow virtual private connections” and click Next once again.
9)Now you are going to need to create an account which will be used for connecting to the server. This is done by clicking the Add button and following step 10.
11)This is the setup for adding the user that will be used to access the VPN.
12)This screen will give the options for the Allocation of IP addresses from the people that are connecting. To do this click on the “Internet Protocol” and click “Properties”.
13)On my network I know that IP addresses over 200 are free, so I have selected the range 192.168.1.201-192.168.1.220. If you are running a DHCP server you can let it specify the addresses. If in doubt specify manually as it can be changed later and click OK and click Next on the Window shown .
14)Now click Finish to Finish the Wizard.
15)If you go back to the “Network Connections” page you can see that there is an icon for “Accept Incoming Connections”.
And that’s the Server Connection all done
Firewall and Router Notes.
The previous bit was the easy bit. First if you are using a Modem and are going to be connecting directly to the computer the modem is on Skip forward a bit. If you are using a Router however this is a different matter, you can do 2 things.
1)Forward the specific ports to the desired Server (Look at the Firewall Section for ports etc.).
2)Set the DMZ(Demilitarized Zone) to the Desired Server. (This means that every connection will be forwarded directly to that PC, which brings me onto the firewall)
Firewall
I use Sygate firewall and here is a tutorial for allowing the correct ports to be allowed and not blocked by the firewall. I’m sure this tutorial could be modified to the certain firewall you are using, if any.
1)Start Sygate and go to the “Advance Rules and Configuration”.
2)Click Add
3)In the General Tab Name the Rule and select “Allow this traffic”
4)Select the Applications Tab
5)Check NTOSKRNL.EXE and TCP/IP Services Application
6)Click OK
7)Click Add
8)In the General Tab Name the Rule and select “Allow this traffic”
9)Select the Ports & Protocols Tab
10)Select TCP in the drop down box
11)Leave the remote box bland, and fill the local box with “135,500,1701,1723” Opening these ports can be dangerous, only open them if you can't get a connection made!
12)Click OK
13)Click Add
14)In the General Tab Name the Rule and select “Allow this traffic”
15)Select the Ports & Protocols Tab
16)Select UDP in the drop down box
17)Leave the remote box bland, and fill the local box with “135,500,1701,1723”
18)Click OK
19)Click Add
20)In the General Tab Name the Rule and select “Allow this traffic”
21)Select the Host Tab
22)Select IP Address and type in your VPN Server address.
23)Click OK
N4N01D is offline   Reply With Quote
Old 28th Jul 2004, 14:45   #2
N4N01D
Supermodder
How to setup a VPN Client
1)Go to the control panel as shown below.
2) Double click on “Network Connections” as shown below.
3) Now on the left hand side in the Common Task Box, there is a section “Network Tasks”. Click on this option.
4) This will start the wizard to make the VPN connection (server side) Click Next. As shown below.
5) Select “Connect to the network at my workplace” and click Next
6)Select “Virtual Private Network Connection” and click Next.
7) Type in a company name for the connection and cluck next.
8)If you need to dial a connection to get internet access please select Automatically dial this initial connection OR just leave it on “Do not dial the initial connection.” And click Next.
9)Now enter the IP address or Hostname of the VPN Server and click Next.
10) Now click Finish.
11) The Connect box will appear where you can enter the details for the username and password which were set for the VPN server. From there click Properties.
12) Click the networking Tab and select the properties of the Internet Protocol TCP/IP.
13) Click Advanced.
14) Untick “Use Default gateway on remote network.” And click OK all the way back to the dialup box. – IF YOU DON’T DO THIS IT MAY CRASH YOUR NETWORK CONNECTION.
15) Now you can dial the connection. Once this has connected you should be linked to the other network, you may not be able to type \\server for example however if you go to Start – Search and select “Computers or People” then “a computer on the network” and type the server name in there you should be able to find it ok.
Old 9th Sep 2004, 14:05   #3
jezmck
____
jezmck's Avatar
jezmck is a hoopy frood who really knows where their towel is.jezmck is a hoopy frood who really knows where their towel is.jezmck is a hoopy frood who really knows where their towel is.jezmck is a hoopy frood who really knows where their towel is.jezmck is a hoopy frood who really knows where their towel is.jezmck is a hoopy frood who really knows where their towel is.jezmck is a hoopy frood who really knows where their towel is.jezmck is a hoopy frood who really knows where their towel is.jezmck is a hoopy frood who really knows where their towel is.jezmck is a hoopy frood who really knows where their towel is.jezmck is a hoopy frood who really knows where their towel is.
nice clear guide. (should be a sticky imo)
will it let me and a friend play lan games though?
we were trying OpenVPN to set up a connection (which works) but were then unable to connect in-game.
any suggestions much appreciated.
__________________
Have you seen The SketchUp Components Collection's latest items?
Interested in a DXF Blueprints Collection? Discuss it here.
jezmck is offline   Reply With Quote
Old 9th Sep 2004, 14:08   #4
mushky
gimme snails
mushky's Avatar
mushky has yet to learn the way of the Dremel
Sweet as. Nice one mate, really useful info there.
mushky is offline   Reply With Quote
Old 9th Sep 2004, 14:32   #5
kitt
Michael Knight
kitt's Avatar
kitt has yet to learn the way of the Dremel
brilliant guide mate
__________________
"Yes Michael...."
KITT
kitt is offline   Reply With Quote
Old 13th Oct 2004, 08:14   #6
N4N01D
Supermodder
you know that you will only get speeds the same as your upload (256kbit in most broadband cases), it should work as basically you are becomming part of the network, do you have any firewalls running or anything, if so you could try turning them off?
Thanks for the feedback, keep it comming
Old 15th Oct 2004, 01:54   #7
hk
Powered By Duracell
hk's Avatar
hk has yet to learn the way of the Dremel
Yep sticky it
__________________
Hamlesh Motah
www.Hamlesh.com - IT Consultancy
hk is offline   Reply With Quote
Old 16th Oct 2004, 15:23   #8
Carbon
Banned
Carbon's Avatar
Carbon has yet to learn the way of the Dremel
Originally Posted by hk
Yep sticky it
Agreed sticky!
Carbon is offline   Reply With Quote
Old 16th Oct 2004, 18:50   #9
Sc0rian
Here comes the farmer
Sc0rian's Avatar
Sc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run Crysis
Yep agree..
Vpn isnt easy for an average person. Sticky would be use I GUESS
__________________
\o/
Sc0rian is offline   Reply With Quote
Old 16th Nov 2004, 16:59   #10
mushky
gimme snails
mushky's Avatar
great post man, thanks
Old 16th Nov 2004, 17:23   #11
Brew
Multimodder
Brew has yet to learn the way of the Dremel
Very nice guide Cant really be any clearer than that.
I thought I would point out that the process in Windows 2000 Pro is nearly identical, and just as 1337 Good for those of us who want to get our pr0...files from a computer at home
__________________
Get Overhauled
Brew is offline   Reply With Quote
Old 1st Dec 2004, 21:09   #12
midou11
Minimodder
midou11 has yet to learn the way of the Dremel
wow that is gonna be very helpfull for people.
midou11 is offline   Reply With Quote
Old 20th Dec 2004, 12:09   #13
Nath
Your appeal has already been filed.
Nath's Avatar
Nath has yet to learn the way of the Dremel
Great guide, will be using this when I get back home.
__________________
om nom nom nom
Nath is offline   Reply With Quote
Old 20th Dec 2004, 17:35   #14
Drivel
Multimodder
Drivel has yet to learn the way of the Dremel
im a lil hazy about this do u need any other hardware ?? cuz i know how to do it with a VPN roghter but not with out does iot stiill work??
__________________
my rig AMD 64 3200 asus k8v SE deluxe 1.5 gb pc 3200 2 40gb westerndigital 7200rpm hdd 1 160gb wd SATA and 2 250 gb sata ATI 9550 (overclocked)
Drivel is offline   Reply With Quote
Old 23rd Dec 2004, 17:52   #15
N4N01D
Supermodder
nope no hardware required (not including a modem for getting the internet connection) - just 2 x Win XP or 2000 systems, ports will need to be forwarded / unblocked tho if your using a router / firewall
HTH
Old 24th Dec 2004, 05:48   #16
Sunny-D
Multimodder
Sunny-D's Avatar
Sunny-D has yet to learn the way of the Dremel
wouldnt the server need 2 nic's? one for the modem, one for the router?
__________________
Eternal Project::|AMD XP 2500+||Abit NF7-S||2x 256mb PC3200 Corsair Value Ram||ATi AiW 9000|
|WD800JB||Seagate 40GB||Lite-On 8x DVD+/-RW 2.4xDL DVD+R|Lite-On 16x DVD-ROM||Win XP||Logitech MX1000|
|Audio equipment::: |5G iPod Video 30GB||Sony MDR-V150 Studio Monitor Headphones|
|JVC MX series 460 watt stereo|[/color]
Laptop::||Apple G3 Powerbook @ 266Mhz||320 MB RAM||4 GB HDD||250 MB Zip Drive<--Currently dead (dog chewed cord)
Sunny-D is offline   Reply With Quote
Old 24th Dec 2004, 13:11   #17
N4N01D
Supermodder
you could use 1 or 2 nics, when i did it for a server i put 2 nics in and dedicated 1 card to VPN and then the other card to internal network access. Then i used sygate firewall and setup rules for each card, but its not essential to have 2 cards, it really depends on your topology tbh
Old 9th Feb 2005, 17:22   #18
Phrozenpenguin
Ultramodder
Phrozenpenguin's Avatar
Phrozenpenguin has yet to learn the way of the Dremel
Thanks for the tutorial, much appreciated :-)
Just a couple of notes i have found:
You can test this on a LAN to check you have authentication correct by changing the IP to the local address of the server.
You have to be careful on the outgoing interent connection as well; some routers don't let PPTP connections through :/
Phrozenpenguin is offline   Reply With Quote
Old 26th May 2005, 04:09   #19
phonon45
Minimodder
phonon45 has yet to learn the way of the Dremel
First off, thanks for posting this. The setup was quick and painless.
Could you explain why you are forwarding all of those ports? If this is a PPTP connection, then it will work to only forward port 1723. I have set up a VPN server in Server 2003 and it works fine with only port 1723 forwarded through the firewall. What am I missing about XP?
phonon45 is offline   Reply With Quote
Old 27th May 2005, 18:44   #20
N4N01D
Supermodder
I was having a few problems with getting sygate to work with this... so i raised a help requests as i have a legal copy and they replied with the above ports that needed to be forwarded, and right enough when i did this it worked. Having 135 could cause some security issues, but if you can run it with 135 closed then go for it, im just saying i needed 135 open for it to work
HTH
Reply
Tags
network
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
