Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 7th Aug 2004, 18:43   #1
SFOD-D LoneWolf
What's a Dremel?? :p
SFOD-D LoneWolf's Avatar
SFOD-D LoneWolf has yet to learn the way of the Dremel
Are these temps OK?
Well, I just installed my WC rig ( TDX Hi-Flo PRO) and here are my temps:
AMD XP 2500+ @ 2,4GHz 1.725V 37-40C
Sapphire ATi Radeon 9800PRO @ XT clocks 42-47C
These temp's are while playing SC: Pandora Tomorrow @ 1280X1024 High details.
Cheers,
Mike
EDIT:
Why do the shadows in SC:PT suck sooooo much?
How do I fix this?
__________________
If it ain't broke, fix it till it is!
I needs me a new PC.
SFOD-D LoneWolf is offline   Reply With Quote
Old 7th Aug 2004, 21:42   #2
Tulatin
The Froggy Poster
Tulatin's Avatar
Tulatin has yet to learn the way of the Dremel
update your drivers, that will fix it.
Tulatin is offline   Reply With Quote
Old 8th Aug 2004, 14:20   #3
SFOD-D LoneWolf
I installed Cats 4.7 and they still suck
Cheers,
Mike
__________________
Old 8th Aug 2004, 14:39   #4
Sc0rian
Here comes the farmer
Sc0rian's Avatar
Sc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run Crysis
Cheers,
Mike
There's 4.9...
http://forums.bit-tech.net/showthrea...&highlight=4.9
__________________
\o/
Sc0rian is offline   Reply With Quote
Reply
Tags
cooling
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
