Hi ya all, Been around looking on this forum for about a year and finally decided to post my project log. I'll cut the crap and come right to the pictures, bunt no can do... They'll be up sometime this afternoon GTZZZZZZZ
I would recommend you start a new thread when you have the pics ready. (and ask a mod to lock then remove this thread) PS - but add a link to it here first
No need for a locky... Here are the pics. I was gonna post them earlier but my internet connection was down. damn you ADSL anyway here are the pics That's all for today GTZZZZZZ
good morning... Dat zijn geen ledjes, maar kinch aansluitingen voor stroom Couldn't resist to do a little pre assembling Added a little pro amd sticker The front testfitted Close up of my modded PSU (480W) I bought 4 of these little led like things that change color every 5 seconds. Very nice lighteffect Thats all for now.. reply reply GTZZZZZZ
Could you show some better pics of the harddisk cage with the fan on? It looks as if the fan is put directly on top of the harddisk. If that's true, the fan will never be able to really blow on top of the harddisk... That way it can't get rid of it's 'wind pressure'.
Hi all Just got back from work and stopped at the brico ( hardware depo ) on the way back. HDD cage : It's an eye cheater There is in fact about 4cm between the bottom of the fan and the HDD PSU : The PSU is a q-tec dual gold 450W ( and not 480 as I said before, my bad ) The green on the fans is uv reactive and gives a nice effect when the blacklight is on. Under the mobo is a white ccfl placed. More pics up tonight of new handles and some more stuff GTZZZZ
Update time!!! Added some handles at the side of frontpanel Because the sides were only screwed and tapped on the ground panel and I didn't wanted to attach the plexi to the side panels I made the construction solid with a rod in a transparant tube. Tomorow no updates because I'm going to the computer fair in Ostend. GTZZZZ
And I thought the HDD and the fan were that tight together. I was wrong, nice job nonetheless! I like the handles on the frontpanel as well, together with the analog gauges, Coolermaster Musketeer I presume?
indeed, musketeer 1 Just got my second 19 inch screen for dual mode Ow, the two holes in the front panel are for the stealthed cd drive and a 4 unit usb port GTZZZ
