Reply
Thread Tools View Mode
Old 26th Jan 2005, 11:45   #81
fivecheebs
Dont panic!
fivecheebs's Avatar
fivecheebs has yet to learn the way of the Dremel
Fantastic work. Are you tempted to CNC a sword blade and an extra column just for the heck of it
Could we have a few details of the cooling loop please? Particularly the resevoir.
__________________
Give Blood If not to save a life then just so you can get out of it on 2 pints in the pub after giving!
fivecheebs is offline   Reply With Quote
Old 26th Jan 2005, 13:50   #82
papeniglio
Supermodder
papeniglio's Avatar
papeniglio has yet to learn the way of the Dremel
Fantastic!!!!
<italian mode>Ma tuo padre il proprietario dei macchinari che usi o hai la grande fortuna di avere un sacco di tempo libero al lavoro????</italian mode>
__________________
Mauro aka PapeNiglio
PocketR2D2 - ETEN M500 | HanSolo - ACER Aspire 5610 | C3PO - Gateway | Anakin - Wife PC+HTPC | ObiWan - File Server+Play PC | Skywalker - Old Play PC
papeniglio is offline   Reply With Quote
Old 26th Jan 2005, 14:21   #83
Dean_j2001
Multimodder
Dean_j2001's Avatar
Dean_j2001 has yet to learn the way of the Dremel
i think im going to have a heart attack this is just absolutely amazing, its T3h seXiness beast!, i wish i had access to a cnc miller, my college won't allow me access to it because i'm in the computing section rather than the engineering section which frankly sucks
anyway nice mod i'm gunna end up walking infront of a bus daydreaming about your mod or something lol
Dean_j2001 is offline   Reply With Quote
Old 26th Jan 2005, 16:37   #84
Jordanis3r
Jigsaw Master
Jordanis3r's Avatar
Jordanis3r has yet to learn the way of the Dremel
nice work - and a nie tooled up workshop
just a quickie tho - throughout my years machining I was always taught that using emery cloth etc is dangerous on a lathe the way you have to polish the pieces - as it can wrap around and cause injury :s
just my tuppence worth :s
besides the safety lecture - keep up the good work!
__________________
As the hours get longer .... the coffee gets stronger
Jordanis3r is offline   Reply With Quote
Old 27th Jan 2005, 20:54   #85
mircea
What's a Dremel?
mircea has yet to learn the way of the Dremel
Originally Posted by G69T
Some pictures about columns working on a CNC milling machine.
Zoom
Zoom
Mill D 24 mm. multicutter used for external columns profile.
Zoom
Zoom Working phase: the columns will have a profile recalling the form of a sword handle.
See You soon... - work in progress.
bye bye
SPECTACULAR!
It' s a very original way of doing modding,but i'm sure that it is also very expensive taking in consideration that i work with a CNC miling machine.Art requires sacrifices!
It's a great job....congratulations!
MIRCEA
mircea is offline   Reply With Quote
Old 29th Jan 2005, 11:43   #86
G69T
CNC Modder
G69T's Avatar
G69T has yet to learn the way of the DremelG69T has yet to learn the way of the Dremel
Best regards to all you...
Originally Posted by Xoddoza
Looking good. As for the weight, who cares
The weight is not so important; it will be some support for mobility and a best position to appreciate it.
__________________
My Modding Spider's Web - Dark Blade - DBRS Project
Dark Blade - Winner of the Bit-Tech and A.C.Ryan Mod of the Year 2006
Dark Blade Sponsored by Ybris Cooling - AMD - ASUSTeK - OCZ Technology - Cooler Master
DBRS Project - Winner of the MoTM of November 2009
G69T is offline   Reply With Quote
Old 29th Jan 2005, 12:09   #87
Franklin
Supermodder
Franklin's Avatar
Franklin has yet to learn the way of the Dremel
I can do only one thing with this project log and that is bookmark it. Amazing
Franklin is offline   Reply With Quote
Old 29th Jan 2005, 12:22   #88
G69T
CNC Modder
G69T's Avatar
I'm working about the tanks. The plant will be composed by 2 separate idraulic circuits. As well as possible, you'll see the idraulic detailes.
__________________
Old 29th Jan 2005, 12:33   #89
G69T
CNC Modder
G69T's Avatar
Originally Posted by papeniglio
Fantastic!!!!
<italian mode> Posso utilizzare le macchine soltanto al termine del normale orario di lavoro, spesso anche di notte
Ciaooo
Originally Posted by mircea
SPECTACULAR!
MIRCEA
Wellcome to the member of the same profession.
__________________
Old 29th Jan 2005, 12:49   #90
G69T
CNC Modder
G69T's Avatar
I'm happy. Stay tuned.
Small update
Fase of working of 2 cylinders in perspex (D.134mm /4mm)
Zoom The cutting of two cylinders H106mm with band saw.
Zoom
Zoom This machine with an abrasive disk will permit us to obtain 2 flat faces of the cylinders.
Zoom
Zoom This workship we obtain pressing and rotating the tube on the abrasive cloth.
Zoom The final result...
bye bye
__________________
Old 29th Jan 2005, 16:44   #91
jaguarking11
Peterbilt-strong
jaguarking11's Avatar
jaguarking11 has yet to learn the way of the Dremel
MINGIA!!!!!!!!!!!!!
LOL j/k
Very nice work. Keep it up.
__________________
Cube PC -done
Hard Lined -Working
Feel free To discuss my projects.
jaguarking11 is offline   Reply With Quote
Old 30th Jan 2005, 23:18   #92
G69T
CNC Modder
G69T's Avatar
Originally Posted by jaguarking11
MINGIA!!!!!!!!!!!!!
LOL j/k
Thanks!
Bye
__________________
Old 30th Jan 2005, 23:22   #93
Thrillseekah
Multimodder
Thrillseekah has yet to learn the way of the Dremel
This is some pro s*** nice man keep it up.
__________________
Project : Thinking of new project
Check out www.dnrhardware.nl Dutch review site.
Thrillseekah is offline   Reply With Quote
Old 30th Jan 2005, 23:35   #94
m3t4tr0n
Minimodder
m3t4tr0n has yet to learn the way of the Dremel
that's really nice work... i'm sure this one will get into bit-tech's hall of fame.
__________________
i don't need a signature
m3t4tr0n is offline   Reply With Quote
Old 31st Jan 2005, 23:37   #95
G69T
CNC Modder
G69T's Avatar
The tanks base project
Zoom
Stay tuned.
__________________
Old 31st Jan 2005, 23:47   #96
Xarig
Multimodder
Xarig's Avatar
Xarig has yet to learn the way of the Dremel
Too many toys, me likey. This forum never ceases to amaze me
__________________
"I keep six honest serving-men, they taught me all I know; their names are What and Why and When, and How and Where and Who"
1s project Xarig AQ SLi
Xarig is offline   Reply With Quote
Old 1st Feb 2005, 02:07   #97
Tanaban
Multimodder
Tanaban has yet to learn the way of the Dremel
Stay tuned.
Uhh that's just sickening... as in so good it hurts. I need to get a job in a place like that.
__________________
Mmmm HP 2335 gooooood
Pre-Shodan
Tanaban is offline   Reply With Quote
Old 1st Feb 2005, 02:33   #98
GigantoR
Supermodder
GigantoR has yet to learn the way of the Dremel
"Where does he get such wonderful toys?" The Joker - Batman (I think I got it right lol)
Hmm, I need to dig around my college and see if they have any of these machines I could use. I do have a friend or 2 in the engineering dept.
GigantoR is offline   Reply With Quote
Old 1st Feb 2005, 10:58   #99
Constructacon
Constructing since 1978
Constructacon's Avatar
Constructacon is definitely a rep cheat.Constructacon is definitely a rep cheat.Constructacon is definitely a rep cheat.Constructacon is definitely a rep cheat.Constructacon is definitely a rep cheat.Constructacon is definitely a rep cheat.Constructacon is definitely a rep cheat.Constructacon is definitely a rep cheat.Constructacon is definitely a rep cheat.Constructacon is definitely a rep cheat.Constructacon is definitely a rep cheat.
This is just tooooooooooo sweet. It makes may tool(toy)shop pale in comparison.
Who wouldn't want to have access to CNC milling?
__________________
Remember - for every silver lining there is a cloud.
"Of course, overclocking doesn't normally involve a tank of acetylene large enough to blow a house off its foundation." - zackbass
MAME Over - Custom built arcade cabinet.
This season's mod - The New Black
Also modded - "Got Milk?"
Constructacon is offline   Reply With Quote
Old 1st Feb 2005, 16:00   #100
KAMIKAZE-FREAK
Supermodder
KAMIKAZE-FREAK's Avatar
KAMIKAZE-FREAK has yet to learn the way of the Dremel
no words can express the yealousness of mine
(wich is a good thing for you )
__________________
please tell me your opinion on Nukeduud
to-do list: mount plexi on sidepanels - small stuff - think some more
also check out Project -=[Unknown][Freak]=-
KAMIKAZE-FREAK is offline   Reply With Quote
Reply
Tags
cnc, g69t, italian modder, milling machine, modding, scratch build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
