#121 |
What's a Dremel?
oh my god
#122 |
Supermodder
Build some extras and sell them
Totally amazing work Subscribed. |
#123 |
Hypermodder
that is one nice looking case
__________________
Project Overhall - Project Log Need your input please ![]() :: A64 3800+ Vencie :: Asus A8n SLI Deluxe :: 2x XFX 6800GT's :: 2GB Samsung DDR Memory :: 2x 200GB Maxtor SATA hdd's :: UFO Mountain Case :: Pioneer 108 :: Sony CRX320E cdrw/dvd :: Tagan 480w ::
#124 | |
CNC Modder
All the alu components will be anodized. The base, you've seen in the picture, is not in contact with the water; on it I'll put the bottom in stainless steel (AISI 316L). Bye Bye
__________________
My Modding Spider's Web - Dark Blade - DBRS Project
Dark Blade - Winner of the Bit-Tech and A.C.Ryan Mod of the Year 2006 Dark Blade Sponsored by Ybris Cooling - AMD - ASUSTeK - OCZ Technology - Cooler Master DBRS Project - Winner of the MoTM of November 2009 |
#125 | |
CNC Modder
__________________
#126 |
Multimodder
Seriously incredible stuff...
__________________
THE MOTHERSHIP: - iWill DP533-S Rev. 1.5 mobo with 2GB Crucial PC2100 DIMMS, timings: 2-5-2-2 - Dual 2.4GHZ 400 FSB XEONS OC'd to 3.2GHZ 533 FSB, stock vcore (1.45) - 8x160GB Maxtor SATA w/ RAIDCore 4852 8 channel PCI-X 133 card - eVGA GeForce 6800 OC'd, timings: 440/1250 - Lian-Li PC-73SLB Silent Full Tower - Zippy/EMACS 700W PSL-6701P-SATA PSU -------------------------------------------------------------------------------------- DEVISE TECHNOLOGIES - www.devise.net |
#127 |
CNC Modder
That's the first fase of workship of the two bottom pieces in AISI 316
![]() Zoom Raw stainless steel ring, ready for CNC work. Some work fases. ![]() Zoom ![]() Zoom ![]() Zoom Only one of the faces was milled. The mill working, obtain the wished part leaving only 0.5 mm. of residual material, that I worked out with a traditional cut-off mill. ![]() Zoom ![]() Zoom The external perimeter surface was worked with abrasive disk. Some images of the first fase result. ![]() ![]() Zoom ![]() Zoom ![]() Zoom See you soon speaking about the 2nd fase. Bye Bye
__________________
#128 |
Multimodder
Gosh! Your work is reaally professional!!
Way to go, pal!
__________________
Project "Doom City" coming soon!! -planned I----------I 50% -parts bought I----------I 0% -done I----------I 10% |
#129 |
Peterbilt-strong
good work man... Very good work. keep it up and dont let us hang im on the edge of my seat.
#130 |
What's a Dremel?
can I ask a question? why is the stock or raw material so thick? is the thick alluminum material easier to work with?
also, I am in AHHHH!!! with the workmanship this project has. |
#131 | |
Multimodder
... and just as beautiful as a marble statue too
#132 | |
Supermodder
Great job so far. i assume that those machines are at ure work?... if so howcome they let you use them for personal use? Snood
__________________
-------------------------------------------- Proud Bit Tech member number 5000 ---- Life is like a sewer..... What you get out of it depends on what you put into it! -------------------------------------------- |
#133 |
Multimodder
Mummy can you buy me some equipment like that man! Pleeeeaaassee.
My hat goes off to you thats some very fine work. I wish my lathe and routers were at that level I'm still using manually controlled ones so it's a lot harder to do that level of work but I will try one day. Looking forward to the next update.
__________________
-Tribal-Li V1000B- Modding In Progress | Reservior finished | [| || || || || || || 80% || |] | Project Log | -Server Box- Part One | Part Two | -HTPC- Modding Paused | [| || || || || || || || |95% ] | Project Log | ..:: Proud CARNALOnline.org Member ::.. |
#134 | |
What's a Dremel?
Are you nuts? This kind of steel is very difficult to mill.You need machine tools made exactly for this type of material because it’s a hard work ANYWAY,nice work! MIRCEA |
#135 |
Multimodder
It sure looks nice, but what did you actually modify with your own hands, everything done by machines, this would be no competition compared to some cases out there made mostly using tools instead of computers and cnc machines.
nice work though, |
#136 | |
Supermodder
__________________
Lian-Li PC-60 ¸.·´¯`¤ Antec TruePower 550W PSU ¸.·´¯`¤ Asus K8N-E Deluxe Mobo ¸.·´¯`¤ Athlon 64 3000+ ¸.·´¯`¤ ATi Radeon 9800Pro 256MB softmodded to 9800XT ¸.·´¯`¤ 2X 512MB Corsair XMS Series DDR400 ¸.·´¯`¤ Western Digital 250GB SATA HDD ¸.·´¯`¤ Maxtor 160GB IDE HDD ¸.·´¯`¤ Sony DRU-710A DVD+/- Burner
#137 | ||
CNC Modder
bye bye,
__________________
#138 |
CNC Modder
Thanks everyone for interesting
Those are the pictures of the 2nd fase of workship of AISI little bottom. In this fase will worked out two threaded holes (3/8" gas). ![]() Zoom The first hole with a twist drill (D 10mm.). ![]() Zoom ![]() Zoom The drilling with a twist drill (D 15mm.). ![]() Zoom Drilling (D. 10 mm.) tangent to the inside circle. ![]() Zoom Tapping 3/8" Gas. ![]() Zoom ![]() Zoom ![]() Zoom The bottom is over! See you soon with the next step. bye bye;
__________________
#139 |
CNC Modder
Some pictures of the firts reservoirs pieces and a assembly test.
![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom ![]() Zoom Finally the ideas become to have a form. bye bye
__________________
#140 |
Multimodder
Absolutely beautiful work.
Makes me wish I had a CNC machine and the skill to use one.
__________________
A8N SLI Prem., X2 3800+, 2GB Corsair PC3200, XFX 7800 GT, Lian Li PCV-2000B Case, Antec True Blue 480watt PSU sleeved, 74 GB WD Raptor HD, 160 GB Maxtor HD, Pioneer A09 DVD Burner, Cendyne 106S Slot Load DVD Drive |
| Tags |
| cnc, g69t, italian modder, milling machine, modding, scratch build |
| Thread Tools | |
| View Mode | |
