RSS
Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 17th Dec 2004, 06:28   #1
Fusen
Supermodder
Fusen is on a distinguished road
Lost wap54g admin panel...
may seem abit odd, but I have lost the address to the admin panel for my WAP54G its default is 198.162.1.1 but I changed it when I first installed it as my router, befdsr41w used the same address and it became confused, then I couldn't remember what ip I set the access point to and so I changed my router to 10.1.1.1 and reset my acess point and then tried 192.168.1.1 but still couldn't get the admin panel. I've also tried things like ipconfig /all to see if it shows the ip of the access point but that just shows my routers ip.
is an odd request lol but can anyone help me locate it?
Fusen is offline   Reply With Quote
Old 17th Dec 2004, 13:58   #2
ConKbot of Doom
Mod Master
ConKbot of Doom's Avatar
ConKbot of Doom is on a distinguished road
You have to have your IP the in the same range as the router. So your IP would have to be 192.168.1.* to access the router. I experienced this at a lan party. Took a while to figure it out too.
__________________
I'm the Redneck Kbot, I leave my christmas lights up all year long.
ConKbot of Doom is offline   Reply With Quote
Old 19th Dec 2004, 15:41   #3
Fusen
Supermodder
my router is at 10.1.1.1
do you know of any programs to brute force ip's so I can scan from a certain number on my network to see if any give a responce
Old 19th Dec 2004, 20:41   #4
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has a spectacular aura aboutFirehed has a spectacular aura aboutFirehed has a spectacular aura about
Why not just hit the reset button on the back of the router? That little tiny thing that needs a paper clip...
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Old 20th Dec 2004, 00:10   #5
wharrad
Hypermodder
wharrad's Avatar
wharrad is on a distinguished road
Yeah, I have experienced the same "problem" (it was more forgetfulness on my part in that instance!)
I seem to remember the reset button didn't help in my case - it might in yours.
To get around it, I downloaded the software from the linksys site. When you install that on a computer connected to your network it searches for all the access points. From there it'll not only tell you the IP, but allow you to change it.
You might need default username: admin and password: password
__________________
Jimmy Carr - "It's easier to get forgiveness than permission"
wharrad is offline   Reply With Quote
Old 20th Dec 2004, 19:02   #6
Fusen
Supermodder
Old 20th Dec 2004, 19:03   #7
Fusen
Supermodder
I still have the CD doesn't matter what pc or laptop I try and use it on it can't find the access point on the network :/
Old 20th Dec 2004, 20:08   #8
mikecx
Modder
mikecx is on a distinguished road
Do an ipconfig and look to see what the gateway is set as. It should be 192.168.1.1 if it's been reset. If it hasn't been properly reset, while the router is on hold the reset button for about 30 seconds. Do an ipconfig /renew. If the gateway still isn't 192.168.1.1 go to http://gatewayaddress. If it's seeing it as the gateway on dhcp and you are getting an ipaddress from it and you still can't get to the control panel you may need to RMA it.
I'm also not sure on the WAP54G but if it does have a wired port you can use, use it. When doing any kind of administration use the wired option if there is one as wireless communication can sometimes cause problems. I know it's different but on the WRT54G when it's reset the wireless is disabled and it must be connected by cable to be changed. If it does pop-up remember the default name/pass is blank/admin.
__________________
Blarg.....
- Black Mage
mikecx is offline   Reply With Quote
Old 20th Dec 2004, 23:14   #9
TheAnimus
Banned
TheAnimus's Avatar
TheAnimus will become famous soon enough
if the MAC address is printed on the unit (all good brands do this) then just add the MAC address to an IP (any IP) in ur ARP table, then that machine will be able to talk to it, via that IP you've just added.
(start -> run -> cmd -> arp -h)
TheAnimus is offline   Reply With Quote
Old 21st Dec 2004, 05:10   #10
Fusen
Supermodder
it just shows the gateway of the router
Old 21st Dec 2004, 05:13   #11
Fusen
Supermodder
I did this from main pc (wired) and laptop (wireless) and setting the ip of my laptop on both times to that mac address of my access point didn't seem to do anything also the command to view is -a and to set a ip is -s, -h didn't return anything
Old 21st Dec 2004, 23:48   #12
Rod10k
Multimodder
Rod10k is on a distinguished road
everyones fav friend...
Nmap
I beleive that that can scan a set range of IP and tell you if it "sees" anything
Rod
Rod10k is offline   Reply With Quote
Old 22nd Dec 2004, 01:07   #13
wharrad
Hypermodder
wharrad's Avatar
Be careful with the software... the one on my CD was different from the new stuff on the web.
__________________
Old 22nd Dec 2004, 16:14   #14
Fusen
Supermodder
Nmap
Rod
using -sP to just ping any hosts doesn't work on internal networks and using the other options like -sT, my router seemed to have stopped it from seeing anything anyway I did a scan on nmap -v -sT -O 10.1.1.1-254 and theres at least 3 pc's online starting at 100 to 103 and it didn't pick any of them up let alone ip's that I don't know
Old 22nd Dec 2004, 16:49   #15
Rod10k
Multimodder
you could try ethereal
It is a packet sniffer but you may well pick up some broadcast packets such as "This is x where can i find y"
Maybe clutching at straws but worth a try I guess
Rod
Old 26th Dec 2004, 02:03   #16
Fusen
Supermodder
gave same results of just telling me the ip of my router
Old 26th Dec 2004, 05:40   #17
padrejones2001
Puppy Love
padrejones2001's Avatar
padrejones2001 is on a distinguished road
Personally, I think Cain and Ble work best for cracking network passwords, however, Nmap works extremely well also, but Cain and Able should work fine. Link
__________________
Teh Signature | Teh Puppy
padrejones2001 is online now   Reply With Quote
Old 26th Dec 2004, 14:00   #18
Fusen
Supermodder
I'm sure that would help if I needed to crack the password ;P
Old 27th Dec 2004, 21:24   #19
Phrozenpenguin
Ultramodder
Phrozenpenguin's Avatar
Phrozenpenguin is on a distinguished road
Think this is the program i have used before.
Put in an IP range and it scans it. Found the stuff on my network, including print servers etc. There are loads of similar IP scanners on google.
Phrozenpenguin is offline   Reply With Quote
Old 27th Dec 2004, 23:22   #20
Fusen
Supermodder
the only guide I can go with is that the ip either starts with 10.x or 192.x so scanning it is gonna take a while
Reply
Tags
network
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
