Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 16th Jan 2005, 07:15   #1
Gumbatron
Multimodder
Gumbatron's Avatar
Gumbatron has yet to learn the way of the Dremel
Ammo Case (First Mod)
Hi all,
Here's my first mod. It's an old Ammo case I bought from Aussie Disposals for $20. This case is ROCK SOLID. Its made from about 3mm Galvanised steel plate .
Internal Hardware is as per my Sig (current System) with 2 X 80mm & 1 X 120mm red LED fans and a 60mm Xeon CPU fan (It's a bit loud but pumps more air than the other fans combined ). Controlling these are 2 Home Made Diode Bus Fan controllers, Which probably can't be seen in these pics since I added it a little later. Full credit to cpemma for the Diode Bus idea.
I was originally going to paint it Army green, but once I stripped off the old paint I thought the Galvanised Iron looked cool.
Neway here are some pics. Hope you like it.
Externals:
There's another one of these handles on the bottom. Which helps cos it weighs almost 20 kgs
Got this Power Plug & Switch off an old external CD Rom Caddy
Internals:
The Black box behind the DVD Rom houses the Fan Speed controllers.
This was my only close call. I didn't take into account the Graphics card when figuring out if everything would fit. The RAM cooler actually rests on the HDD Bay . One more mm closer and I would have been stuffed
DVD Rom:
The eject is via the toggle switch below and the Blue LED is the Activity LED.
Double sided tape is great for stealthing drives
My main tool:
I first tried Drilling and cutting with a Hack Saw. It took about 3 Hours to cut my first hole . So I went and got an angle grinder. Think of it as a Dremel on steroids ( )
Here's my original CPU Fan, until I put my finger in it
Any Questions / Comments would be Great
__________________
Current Rig: 3800, 1024MB Corsair , DFI NF4-UD, 6800GT, 2 X 300GB (Raid 0) in this
Old Rig: trying to keep it short
Projects: Rack-O-Matic 3000; SHED Comp; HEAVY Water (On Hold); Rustic(New)
Gumbatron is offline   Reply With Quote
Old 16th Jan 2005, 07:39   #2
Zephyr
Go V-Boy, Go!
Zephyr's Avatar
Zephyr has yet to learn the way of the Dremel
Looks good, but I would suggest a tad bit more cable organizing inside (I can tell you've done some, but it still looks like a bit could be done) and clean up the cuts a bit.
Also, I think it would look cooler in army green, but that's just imo. Good work though, I like it
Zephyr is offline   Reply With Quote
Old 16th Jan 2005, 08:57   #3
Pelihirmu
Supermodder
Pelihirmu's Avatar
Pelihirmu has yet to learn the way of the Dremel
Looking very cool being your first case mod
I'd put those HDDs down next to the PSU and the 80mm fan blowwing to the HDDs. But nice and heavy mod
Pelihirmu is offline   Reply With Quote
Old 16th Jan 2005, 11:07   #4
Anthony
Multimodder
Anthony's Avatar
Anthony has yet to learn the way of the Dremel
Cool first mod...
__________________
Project "Doom City" coming soon!!
-planned I----------I 50%
-parts bought I----------I 0%
-done I----------I 10%
Anthony is offline   Reply With Quote
Old 16th Jan 2005, 17:46   #5
Gipo
Multimodder
Gipo has yet to learn the way of the Dremel
top dog!
Gipo is offline   Reply With Quote
Old 17th Jan 2005, 08:31   #6
Gumbatron
Multimodder
Gumbatron's Avatar
Thanks for the nice commnets guys.
Here's a pic of the Fan Speed controllers I took 30 seconds ago. As you can see the top of my case also doubles as a coin tray:
Zephyr:
I agree that It needs a little cable work. I have done some since that pic, but I still need to do more.
I was going to (and did) paint it green, but my painting skills are very basic at the moment (I.m practising for my new case ), so it looked shitty . Plus it rained just after I did the final coat and ruined it.
Bah... enough excuses. I like it the way it is. The outside has a really cool texture and is tough as nails. At least I don't have to worry about scratching my beautiful paint job.
Thanks again for the comments
__________________
Old 18th Jun 2006, 21:03   #7
Yotsuba
What's a Dremel?
Yotsuba has yet to learn the way of the Dremel
Awesome looking case. It doesn't need paint, just possibly some clearcoat.
Airbrush something like ARMY or the radiation symbol onto the side.
Yotsuba is offline   Reply With Quote
Old 20th Jun 2006, 23:10   #8
scifi3018
Supermodder
scifi3018's Avatar
scifi3018 has yet to learn the way of the Dremel
Wow, nice log gumbatron. This is the 2/2 of your mods that i have liked a lot. Are there any others lurking somewhere on the forums?
__________________
Holla
scifi3018 is offline   Reply With Quote
Old 22nd Jun 2006, 00:35   #9
Kobalt
Hypermodder
Kobalt's Avatar
Kobalt has yet to learn the way of the Dremel
Nice job, it's got the look
I would've fired a couple of rounds in it first lolll
__________________
WARNING
Modding and picture taking is addictive...and expensive
MY SITE
Photos etc.
MySpace
Kobalt is offline   Reply With Quote
Old 22nd Jun 2006, 00:46   #10
ReD.SkY
What's a Dremel?
ReD.SkY has yet to learn the way of the Dremel
totally awesome dude...
its the uber lan rig
ReD.SkY is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
