#21 | |
![]() Netgear Fast Ethernet Switch FS108
#22 |
Spaceman Spiff
yep i use it also...and its never let me down....
:dude:
__________________
...wordEs...
#23 |
Multimodder
I realy want to thank all of you for helping me with this... the netgear switch is great but I am unable to find it at a decent price so I think I will go with the D-link DSS 8+. I can get it from New Egg for $50...not bad IMO! I May need ya'lls help in the futer when I get it and set up the network!
Thanx Ya'll
__________________
MAY THE MOD GODS BLESS US ALL!!!! |
#24 | |
Multimodder
what it is that if u use tcp/ip to connect to internet through ICS (which i dont recomment as i dont like it at all but if u must )that sort of thing its more efficient to have another protocol installed to share files and stop tcp/ip sharing files....ie install ipx/spx and disable file print sharing on tcp/ip - this is without using a router just using a hub to split the broadband eithernet connection....
__________________
www.TekForums.com Last edited by sk8o; 11th Jun 2002 at 18:17. |
| Tags |
| network |
| Thread Tools | |
