Reply
Thread Tools View Mode
Old 16th Mar 2005, 19:15   #41
(X)TORNADO(X)
Multimodder
(X)TORNADO(X) has yet to learn the way of the Dremel
Wonderful, keep on going...
(X)TORNADO(X) is offline   Reply With Quote
Old 16th Mar 2005, 22:17   #42
jaguarking11
Peterbilt-strong
jaguarking11's Avatar
jaguarking11 has yet to learn the way of the Dremel
I think the lcd looks awsome where it is. And the shape should be kept more or less the same, maybe a lil shaprer angle on the lcd as that would give it a starship cockpit look when closed. Oh im assuming that you are going to have a flip up kind of lcd. But I would sugest making the lcd face up and puting it behind a pice of plexiglass making it show always and when off it would look like the cockpit has been tinted.
Sorry for my rant but you wnated opinions and I offered.
Keep us updated I rather like this project.
__________________
Cube PC -done
Hard Lined -Working
Feel free To discuss my projects.
jaguarking11 is offline   Reply With Quote
Old 16th Mar 2005, 23:45   #43
Bandit_zoraK
Supermodder
Bandit_zoraK's Avatar
Bandit_zoraK has yet to learn the way of the Dremel
No need to apologize- that is exactly the type of input I was looking for so thanks. The lcd is basically the same as a ps1 lcd, but it is el cheapo ebay dvd so I will mount it in the center of the main sloped face, like you said.
I went ahead and fabbed one out of alum, and did kind of a bad job and I don't really like the shape- I will get a pic or two up soon. I think rather that having the sides orthagonal to the top of the case I will flare them out all the way to the edge so it looks a little sleeker than it does now.
Mockup of how it is now:
How I think I will redo it (more diamond shaped like that window on the 1st page of this thread):
Let me know!
__________________
May the be with you, always.
Project: Rogue 5
Bandit_zoraK is offline   Reply With Quote
Old 17th Mar 2005, 00:23   #44
jaguarking11
Peterbilt-strong
Awsome. Just exactly what I had in mind. And I would make the dimond shape as wide as the case itself. Also you may want a riveted look or some hex bolts round the lcd and the edges of the cockpit.
Keep up the gr8 work and keep us updated.
__________________
Cube PC -done
Hard Lined -Working
Old 17th Mar 2005, 01:16   #45
Devil_909
Modder
Devil_909 has yet to learn the way of the Dremel
I really like the new mock up of the LCD holder. Looks much better
Devil_909 is offline   Reply With Quote
Old 17th Mar 2005, 04:44   #46
Bandit_zoraK
Supermodder
Rivets eh? Way ahead of you...
This was the first version I made. Definetly gonna go with the diamond shape next time around. I will probably make it a little shorter and narrower at the front and back as well.
Oh yeah- I discovered tin snips don't make the cleanest cuts on thin sheet aluminum...
__________________
Project: Rogue 5
Old 18th Mar 2005, 21:53   #47
Bandit_zoraK
Supermodder
Right side done
I am still working on the lcd mount for the top, I've got most of the piece cut, just got to fit them together and rivet. I did finish up the right side panel though...
You'll recall this was where we left it...
I kind of got caught up in the modding so I forgot to take process pictures but besides a different window, the process was exactly the same as the other side. So here's some finished shots of the panel. Enjoy?
If you made it through those... I think I came pretty close to what I set out to do....
vs.
As with the left side panel, I've drilled holes for the windows whenever I get those and will probably be using those fancy hex screws (round with the alan wrench socket in the middle) to attach the windows.
Whaddyall think?
__________________
Project: Rogue 5
Old 18th Mar 2005, 21:59   #48
Drackhon
Minimodder
Drackhon has yet to learn the way of the Dremel
Good window with a good paint.
Drackhon!!!!
__________________
-Trinity MOD Processing........-
[Visit]---http://www.hard-concept.net---[Thaks]
[--MODDING WORLD--]
Drackhon is offline   Reply With Quote
Old 19th Mar 2005, 00:48   #49
Bandit_zoraK
Supermodder
Thanks sir, I appreciate it.
__________________
Project: Rogue 5
Old 19th Mar 2005, 02:37   #50
omicron
Baud.
omicron's Avatar
omicron has yet to learn the way of the Dremelomicron has yet to learn the way of the Dremelomicron has yet to learn the way of the Dremelomicron has yet to learn the way of the Dremelomicron has yet to learn the way of the Dremel
Keep up the good work monsieur - I am subscribed.
__________________
omicron is offline   Reply With Quote
Old 24th Mar 2005, 13:21   #51
Bandit_zoraK
Supermodder
I have pretty much finished the lcd mount. It still needs some finishing treatment, but most of the work is done. I went with pretty much the inverse shape as I planned to above, because from a width standpoint, this way makes a lot more sense. The thing stands about 2.5" tall and is about 9.5" deep and about is wide as the case (~7.5").
Expect more in the coming days! And don't forget to comment!
__________________
Project: Rogue 5
Old 25th Mar 2005, 01:47   #52
jaguarking11
Peterbilt-strong
Looks good. Have you thought about framing the edges of the lcd case with aluminum L? And I would use aluminum L all over the case to give it that riveted look.
__________________
Cube PC -done
Hard Lined -Working
Old 25th Mar 2005, 02:29   #53
Maximus
Modder
Maximus has yet to learn the way of the Dremel
Very nice, I like the battle scared paint job very nice looking, and the window is very nice as well. Can't wait to see the finished project. Keep it up.
__________________
AMD Sempron 2.4Ghz | Kt6V MSI MB | 20Gb HDD | Radeon X700 XL 256mb | 512 Mb Ultra memory | A-open tower
Maximus is offline   Reply With Quote
Old 25th Mar 2005, 15:18   #54
Bandit_zoraK
Supermodder
I thought about using that or something else to cover the edges cause they look pretty sloppy, but it is not a 90 angle where the two pieces meet, maybe they make some >90 stuff? I will look around ace today (need to go anyways) and see what they got.
__________________
Project: Rogue 5
Old 25th Mar 2005, 19:38   #55
Pitbull
Multimodder
Pitbull has yet to learn the way of the Dremel
funny looks
__________________
this sig was too long. and too annoying.
Pitbull is offline   Reply With Quote
Old 25th Mar 2005, 21:21   #56
ginx
Multimodder
ginx's Avatar
ginx has yet to learn the way of the Dremel
I'm not a star wars fan myself, but this case is awesome. I you're cutting skills are incredible. The paint scheme is cool too, I like that red and white. Good luck with the rest.
__________________
Chieftec Aluminum Mid-tower Dragon Series :: ABit AN9 FATAL1TY :: AMD Athlon 64 X2 Windsor 3000mhz 2MB L2 Cache :: nVidia GeForce 7800GTX SLI :: 3072MB DDR2 800 PC2 6400 :: Seagate 250GB SATA 3.0GB/s (x2) :: Creative Sound Blaster X-Fi Xtreme Gamer :: Creative GigaWorks S750 7.1 Speakers :: Samsung SyncMaster 226BW 22" Widescreen LCD
ginx is offline   Reply With Quote
Old 25th Mar 2005, 22:27   #57
jaguarking11
Peterbilt-strong
YOu could also buy some aluminum strips and fasen em to the edges and make em look like an l shaped alu pice.
__________________
Cube PC -done
Hard Lined -Working
Old 26th Mar 2005, 00:28   #58
mattthegamer463
Mod Master
mattthegamer463's Avatar
mattthegamer463 has yet to learn the way of the Dremel
looking very cool as normal. keep it up, i want to see this one done!
__________________
Latest Work: Boombox Build
Project PCB- Complete Digital Picture Frame 2.0- Complete
RumbleMouse - Complete Latest Project: TestPC- Complete
Lian-Li PC7: C2D E6600, XFX 8800GTS 640MB, Corsair 2GB PC6400, 320GB Seagate Barracuda, EVGA 680i SLi, OCZ 850W
mattthegamer463 is offline   Reply With Quote
Old 27th Mar 2005, 15:53   #59
Bandit_zoraK
Supermodder
I decided against any other additions to the lcd mount, and I painted it and did the whole battle damage thing on it.
The yellow stripes on the front were done to resemble the yellow stripes on his helmet:
They didn't turn out as well as I had hoped, but it was krylon and the paint kept seeping through the tape, etc, but I am happy with it.
Here you can tell that I mounted a piece of plexi for the window, and used some inside-hex bolts to secure it.
This stuff on the back is unfinished, I basically made up a led chaser ckt and arranged them randomly, with the idea that the somewhat randomness of it is like the computer communicating w/r2 @ high speed (end /swgeek)
Parting shot
Stay tuned. Same mod time, same mod channel.
__________________
Project: Rogue 5
Old 27th Mar 2005, 22:16   #60
dubya01
Multimodder
dubya01's Avatar
dubya01 has yet to learn the way of the Dremel
Friggin awesome - Maybe you could put some tinted acrylic on top of the lcd to make it look more like a cockpit.
__________________
From Berlin | Germany
dubya01 is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
