| View Poll Results: Which fittings is the best one? | |||
| Plug`n Cool |
18 | 22.22% |
| Barb |
50 | 61.73% |
| Compression |
10 | 12.35% |
| Other (please state in thread) |
3 | 3.70% |
| Voters: 81. You may not vote on this poll | |||
Thread Tools |
#1 |
What's a Dremel?
The "best" fittings
Which is the best fitting and/or coupling for PC watercooling?
I`m asking from a preformance and safety point of view, we all hate leaks and I feel they are most likely to accour at the interfaces between block and tube so I wanna pick your brains about it. Another important factor is availability of diffrent tube sizes for your fittings as well the existence of 90 and perhaps 45 degree bends and other things fitting-connected (pun not intended). And please motivate your answers, it makes it more informative. So please have pity on a poor WC-knowledge-defficient nerd such as myself. |
#2 |
Dont panic!
They are all pretty good. My personal preferance is for the plug and cool type (with the o-ring inside) just because there so damn easy and as long as you cut the tubes sraight and route them so there is little torque (advisable with any connection really) theres no chance of them leaking.
__________________
Give Blood If not to save a life then just so you can get out of it on 2 pints in the pub after giving! |
| fivecheebs |
| View Public Profile |
| Find More Posts by fivecheebs |
#3 |
Multimodder
i found i could never get the tubing on plug and cool exactly straight, causing air to leak in, so i changed to barbs
#4 |
Hypermodder
i like barbs simply because they are more versatile than push fittings. I can replace the sizes of the barbs to fit almost any size tubing unlike push fittings on a water block. Plus i feal more secure with barbs than push fittings
__________________
The Longhorn Engineer |
#5 |
I Mod, Therefore I Own
barbs, couldn't really trust anything else
#6 |
Bling!!
Plug and cool. They're just so easy to use and if you've done it properly they won't leak and are very strong. I'm talking abou the AC ones though, I don't know about Swiftech ones etc.
Apparently plug and cool fittings are strong enough that you can lift a rad full of water with them. I've not tried it yet though
#7 |
Supermodder
Zalman type compression fittings all the way. When properly tightened, you will not get the hose off without tearing it.
Otherwise, barbs are my choice (and worm gear clamps just to be sure ).
__________________
Too weird to live, and too rare to die. Q6600 G0 | Asus P5Q Pro | 9800GTX+ | 4GB | Vista Ultimate 64bit | 24"+24" | 765GB | Nokia E71 Black Eee PC1000H | Dell Optiplex GX260 (FTP) | Toshiba Satellite Pro 410CDT (retro ) Facebook, I hasOh man. My iPod Touch got wet in ra1n.
#8 | |
Supermodder
I happen to like both Plug & Cool and compression. Plug and Cool are very easy to use, but the tubing is often hard and very un-bendy. With compressions, Tygon and other soft stuff can be used with little chance of leaking. Granted 99% of Plug & Cool leaking is due to the tube not being pushed in all the way. I HATE barbs!
__________________
Giant Battle Monsters Last edited by Fibbles; 6th Mar 2005 at 01:07. |
#9 |
Multimodder
A compression fitting is a leak waiting to happen . Barbs w/ a good clamp is the only way to go .
2 YRS NO LEAKS !!!! |
#10 | |
Why not? I own a domain to match.
They are very strong when in correctly as Puggy mentioned... I'd be more worried about bending the tube on my rad than the tubing pulling out (and I've acutally done the former, never the latter).
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net 40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8 MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD |
#11 | |
Bling!!
Oh well, nothing was broken after I let it dry out and I made sure they were in correctly when I tried again. Not had any leaks since, it's been nearly a year now. |
#12 |
What's a Dremel?
Hmmm... I`ve heard lots of talk about the strength of Plug`n Cool, but really.
Do you wanna get into a contest of comparing "tensile" or clamp strength? If a Plug`Cool can lift a radiator full of water, how much can a barb with a good worm-drive clip lift? The barb-fittings seems to be winning, but I haven`t been able to find any 90 degree barbfittings, not to mention 45 degree ones. Do they exist? Sure I´ve seen "banjo" barb-fittings but they restrict like you wouldn`t belive. Don`just state what you use, but please consider availability and diffrent types of fitting accesories. |
#13 |
Bling!!
Well if you are going for a 1/2 system then plug and cool isn't an option so barbs would probably be the best. For anything smaller I would use plug and cool.
What kind of system have you got/getting. IF it's a high flow system then I doubt you will find any 90 degree fittings that won't completely kill the flow. |
#14 |
I am the Pumpkin King!
They do make some 90 degree elbows that won't kill flow, but truth be told, if you're running high flow what are you doing routing 90 degree bends?
__________________
Mithril, ongoing... Sponsored by Petra's Tech Shop And Sidewinder Computers FFVII: Fatal Optimization Sponsored by Koolance Found cat. Anyone know how to CONTROL cats? |
| KayinBlack |
| Find More Posts by KayinBlack |
#15 | |
Supermodder
If you like and love barbs, what does my prefering compressions and push fits matter? So how is it a 'leak waiting to happen'? I've been using a combination of both compression and push fits (Plug & Cool) for over a year now with zero problems. If the same applies to you and barbs, I'm happy for ya
__________________
Giant Battle Monsters |
#16 |
I've been able to make smooth tube and zip tie watertight, which means that a lot of this is just personal choice.
Since I run all 1/2", I use barbs, but I have used swifty push fits, Koolance compression (very handy btw) all kinds of stuff. It's all good if you do it like the instructions say to...
__________________
| KayinBlack |
#17 |
Mod Master
Barbs and jubilee clips all the way
#18 | |
Barbs are really the only option for 1/2" and most 3/8", but P&C and compressions are best for the small-bore stuff. Not only because they look better, but a barb will put far more restriction using the same tubing. Note that a 1/2" barb is NOT 1/2" ID nor is any other barb. Plug and cool, on the other hand, is 6mm ID and is meant for 6mm ID tubing, meaning no loss of flow rate from the fittings.
__________________
#19 |
What's a Dremel?
I only posted this to get info for my upcoming project, which is gonna be a
3/8 based loop. Currently I am using custom waterblocks, pneumatik-barb fittings and copper tubes instead of hoses. It´s been my experience, that 90 degree bends generally aren`t to bad on flow rates, besides using a Ehiem 1046 pump, I´ve got redundancy when it comes to flow. I´ve always gotten the advide to not use 90 degree bends, and if it is avoidable I agree that you shouldn`t. But if thechoice is 90-bend or hose-kink, go with the flow i.e. bends. |
#20 | |
...like a geek!
Moderator
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust "There is no Real Life, only Away From Keyboard" --gpw111 "...my wife says I can't have any trolls, cause they argue with the dog and eat the fish" --KayinBlack |
| Thread Tools | |
