RSS
Old 7th Mar 2005, 11:54   #1
WilHarris
Just another nobody
WilHarris's Avatar
WilHarris is on a distinguished road
COOL by Corsair
www.bit-tech.net/review/391
WilHarris is offline   Reply With Quote
Old 7th Mar 2005, 12:16   #2
fev
Corporate Whore
fev's Avatar
fev will become famous soon enough
that's one spicey meatball!
i'd consider it... if i could get it to fit in the shuttle
__________________
I know what I'm doing... do you?
Follow me on Twitter..go on
fev is offline   Reply With Quote
Old 7th Mar 2005, 13:01   #3
L2wis
Hypermodder
L2wis's Avatar
L2wis is on a distinguished road
hummmm i don't really like this set up much. I think there's too much better stuff already on the market that are better. If i was going to opt for water cooling, it wudn't be this kit im afraid.
__________________
Lewis Wells
Get Firefox! | Get Thunderbird! | Join Bit-tech folding@home
L2wis is offline   Reply With Quote
Old 7th Mar 2005, 13:43   #4
KryoNexus
Multimodder
KryoNexus is on a distinguished road
Does anyone else notice this looks exactly like the H20-120 made by Swiftech?
KryoNexus is offline   Reply With Quote
Old 7th Mar 2005, 13:59   #5
fev
Corporate Whore
fev's Avatar
ssssssh don't tell anyone
__________________
Old 7th Mar 2005, 15:43   #6
zr_ox
Whooolapoook
zr_ox's Avatar
zr_ox is on a distinguished road
Its all just rebranded.
Swiftech CPU block
Danger Den HDPE res
Laing Pump
Panaflo Fan¨
What else??
Corsair have thrown some high end components in a box and branded it their own. I hope the non DIY crowd are not fooled by this.
Would be nice to see the Koolance 2 reviewed.
__________________
0ptimizm
:PC under review
zr_ox is offline   Reply With Quote
Old 7th Mar 2005, 16:13   #7
alextwo
alextwo's Avatar
alextwo will become famous soon enough
As someone considering venturing into watercooling, I wouldn't get one. It looks hideous not sexy looking like their mem, not too bad performance wise though.
__________________
flickr
alextwo is offline   Reply With Quote
Old 7th Mar 2005, 16:20   #8
Cheese
Doc
Cheese's Avatar
Cheese is on a distinguished road
It is indeed, this was clear from the off, but I don't see why it matters, I'd hardly expect Corsair to dev. it from stratch or do a very good job if they did, considering their lack of background in the area.
I agree, I'd like to look at a koolance
Cheese is offline   Reply With Quote
Old 7th Mar 2005, 17:11   #9
KryoNexus
Multimodder
true maybe that they are not capable of dev the entire kit on their own. however, i would still prefer to see at least an original waterblock. the kit is an exact copy of the swiftech
Old 7th Mar 2005, 20:11   #10
Lon3R
Minimodder
Lon3R is on a distinguished road
Swiftech CPU block
Danger Den HDPE res
Laing Pump
Panaflo Fan¨
What else??
was just about to say that Looks like the Swiftech Rev. 3 to me
Lon3R is offline   Reply With Quote
Old 7th Mar 2005, 22:56   #11
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has a spectacular aura aboutFirehed has a spectacular aura aboutFirehed has a spectacular aura about
Except it's painted better. 100% guaranteed that corasair and swiftech partnered up for this.
In all fairness I'd have rather seen a block from DD or PF but seeing as I'm not going to be buying one I can't care that much. And Swiftech is really the only (US) company that makes full kits that can be found at most online stores.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Old 7th Mar 2005, 23:13   #12
Hamish
I Mod, Therefore I Own
Hamish is on a distinguished road
except the pump and res are DangerDen and the rad looks like a black ice or similar
Hamish is offline   Reply With Quote
Old 8th Mar 2005, 01:07   #13
Raymus
Multimodder
Raymus is on a distinguished road
Well cant say i wasnt fooled at first read. But after checking the forums... Would have liked to seen a pic of the case with the side panel off. But ive never watercooled so i dont realy know much brand wise. could anyone recomend a good watercooling kit for a Lian Li 65 case? just a mid tower with a 80mm top and back fans and of course one that looks sweet
__________________
Raymus is offline   Reply With Quote
Old 8th Mar 2005, 05:55   #14
Firehed
Firehed's Avatar
No, the new swiftech kits use all of those parts. I got a Rev1 review sample a while back, this is merely Rev3. The block and rad hasn't changed, the pump changed from a 3/8" modded D4 to the new DDC and the FBK (utter crap) changed to the bayres. The rad had always been a black ice pro with those ~12mm pushfit fittings.
The only difference between the Swiftech Rev3's and this are color and packaging, and possibly who you order it from.
/edit - I noticed the COOL doesn't use the pushfits on the rad, but perhaps the Rev3's don't either. From what I could guess people may have screwed up install (by not cutting tubing straight or not adding the stiffeners) and leaked water everywhere. The radbox, too, is the same. Even the clamps on the CPU block. The PCI passthru seems a bit different but as I haven't been keeping up with the swiftech line that much that may have changed as well (another way to eliminate leak points, four potential ones in this case). Those could be Corsair ideas but in essence it is a H2O-120 Rev3 with (imo) a much better color scheme.
__________________
Old 8th Mar 2005, 23:52   #15
Tulatin
The Froggy Poster
Tulatin's Avatar
Tulatin will become famous soon enough
It is the swiftech kit, just with the black versions of their products, a shiny plate for access to the radbox, and a CD on a manual... I really hate that new res tbh.
__________________
Desky
E8400 @ 4.0 1.42v; P5K-E WiFi; 4x1 Kingmax Mars 1066 @ 1129 CAS 5; 2x [TOO CHEAP TO SPONSOR] 4850 @ 675/1050; Enermax Liberty; WCing in a CM690
Tulatin is offline   Reply With Quote
Old 9th Mar 2005, 09:51   #16
Risky
Mod Master
Risky's Avatar
Risky is on a distinguished road
There's nothing sinister here, just Corsair getting a swiftech kit and branding it. Swiftech are happy to sell their kit wholesale kit this as corsair probably have a higher advertising spend and stronger public profile.
The kit will be good given that each of the components are top rate so they're hardly trying to fool anyone. Can't see any reason for criticism
__________________
As a rule watercooling can be simple, affordable and effective... I guess I just like to break the rules.
Risky is offline   Reply With Quote
Old 9th Mar 2005, 23:27   #17
fivecheebs
Dont panic!
fivecheebs's Avatar
fivecheebs is on a distinguished road
I agree, the aesthetics are not particularly too my tastes, and better looking kit can be had for not much more but all in all it looks like a well thought out loop.
__________________
Give Blood If not to save a life then just so you can get out of it on 2 pints in the pub after giving!
fivecheebs is offline   Reply With Quote
Old 6th Apr 2005, 17:54   #18
Pie_uk
here... take a slice of my pie
Pie_uk's Avatar
Pie_uk is on a distinguished road
hey peeps im new so hello. i was wonderin about that i know its made by swift tech but i reckon its a cool kit , how does it compare to asetek hu give you the cpu block vga block and north chip block for 152£ ? performance wise which do u think is better? also does any one know how i can get into the computer buisness? i am 17 and decided i would like to work with pc's etc? were do i start wats a good route to go down? i have got a btec in engineering was thinking about uni but not too sure? how did u the bit tech guys get your jobs? my m8 andy know the guy on here called jamie
Pie_uk is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
