Projekt : :: 40 :: up : 05-27-05 ><(((°> and now - the conclusion -
Discussion in 'Project Logs' started by alonso_bistro, 12 Mar 2005.
  1. alonso_bistro
    alonso_bistro I'm just looking
    19 Feb 2004
    Hello
    Before I can finish Alpha I decided to work on a little project.....
    I've saved the life of a display rack used to show batterys and other products from VARTA.
    (I'll show u the full rack in a future post).
    For now I've just used the bottom part .... a box !!
    This box will be on 4 plexi round (??) ...stol..FOUND in a restaurant that use little flags
    with "MENU EXPRESS" write on them - they are put on the table and use to say
    "EH man i'm hungry and i just have 1 hours for lunch" :D
    and this is the box !!
    On the pics the box looks like to be big but no ! I had to use a micro ATX mobo to fit in.
    Mensurations of the case:
    height : 40 cm
    deep (??) : 14,5 cm
    max width (middle) : 28,5 cm
    min width (top,bottom) : 24 cm
    English metric convertion is for u :D
    same plexi used for Alpha
  2. alonso_bistro
    19 Feb 2004
    DVD + HDD on top , PSU will go bottom.
    back view.
    bad luck.. the PSU doesn't fit for a few mm - i had to do a new box
  3. alonso_bistro
    19 Feb 2004
    don't look at the screws , i took what i have under my hand
    Cut of the support pci card from an old case
    Adjusted as good as possible... maybe the future lateral door. :)
    The DVD's socle.
  4. alonso_bistro
    19 Feb 2004
    now I can read dvd.. lol
    sunshine..ooooh ...
  5. alonso_bistro
    19 Feb 2004
    I started (else) to work on the back..
    bye
  6. Arkuden
    Arkuden mow?
    9 Jul 2004
    that is simply amazing!!! wow! good thing you found that case eh ;) ill be watching this!!
  7. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    inspirational!
  8. aevitas
    aevitas What's a Dremel?
    6 Mar 2005
    That's a very nice case indeed.. you can really do something with it..
    Keep modding dude.. it's starting to look better and better
    GJ :dremel:
  9. irish modder
    irish modder What's a Dremel?
    4 Mar 2005
    another one????? i feel like: :wallbash:
  10. mediacoretex
    mediacoretex What's a Dremel?
    28 Feb 2005
    agreed
  11. Hal
    Hal What's a Dremel?
    1 Feb 2005
    OMG! ****! whenever you start a project... holy crap! you rock sir. i will stand by and watch while my mod looks like crap very shortly... actually, its already been shown up by your few posts! haha. rock on dude.
    i will be watching this one!
  12. Firehed
    15 Feb 2004
    Wow, really exceptional work! I was actually saying what I thought out loud :) Very unique and extremely well made! Keep up the great work :thumb:
  13. blackacidevil
    blackacidevil What's a Dremel?
    26 Aug 2004
    Nice find! Objects not made for being a computer case usually make the best case!
  14. Death Reaper
    Death Reaper What's a Dremel?
    27 Jul 2004
    Nice mod man, simply amazing.
    See if you can find a smaller one about half the size, and then 5 smaller ones about the size of say...surround sound speakers? ;) That would look pimp.
    Regards,
  15. sKuLLs
    sKuLLs What's a Dremel?
    20 Feb 2004
    The concept of re-using something, like you have shown to be quite possible, is one of my favorite mods to watch come together. Although its always nice to see some of the shiny mods........Anyways, just wondering why you chose to mount the hd ontop on the cd drive. I realize there are holes for ventilation above the hd, but I think the heat generated from the cd drive (mostly when its in use) might have certain negative effects on the hard drive.
  16. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    Really nice!
  17. BiG Kahuna
    BiG Kahuna What's a Dremel?
    14 Aug 2004
    truely amazing :eeek: :jawdrop:
    you just keep surprising me with your mods over and over again
    keep up the good work :thumb: :clap: :dremel:
  18. Franklin
    Franklin Minimodder
    24 Oct 2004
    This is another project I will have the keep an eye on. Bookmarked.
  19. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Really, really nice!
  20. unrealhippie
    unrealhippie What's a Dremel?
    24 Jul 2004
    nice, keep us updated!
