Over the half term holidays i decided that i would mod the top of my cases with top window. The Task: making the window was quite easy, Firstyly i drilled out the rivits and masked and marked the top, then i strated cutting hole with jigsaw. Secondly I cut the Arcylic to size and drilled the holes for the screws. Finally i put the arcylic in and attached it with screws. Final product
