RSS
Reply
Thread Tools View Mode
Old 6th Apr 2005, 21:57   #1
Sheyr
Multimodder
Sheyr's Avatar
Sheyr is on a distinguished road
FuG-01/ET - mod finnished, some new pictures
Hi everybody!
I finnished the case. I hope you will like it. Everything works well. The voltmeter indicates the critical voltages 3,3V, 5V and 12V and the fan voltages (case fan, CPU fan and PSU fan). The ampermeter indicates the total current consumption. Below you can find the complete worklog
Sheyr is offline   Reply With Quote
Old 6th Apr 2005, 22:12   #2
tm36usa
I *am* a Dremel
tm36usa's Avatar
tm36usa is an unknown quantity at this point
Ok First off, WELCOME TO THE FORUMS!!!
on another note, and because you new you didnt know, this should have been posted in the modding section. The project logs is for mods with pics and modding. Again, just letting you know, no ones mad but everyone must learn.
On a modding related not, you idea sounds really cool and I like the name too. Best of luck to you!
__________________
Project Double Helix
01110100011011010011001100110110011101010111001101 100001
tm36usa is offline   Reply With Quote
Old 6th Apr 2005, 22:13   #3
Sheyr
Multimodder
Sheyr's Avatar
hmmm...... i think i can not insert images ...
can anyone hepl me pls?
Old 6th Apr 2005, 22:19   #4
Sheyr
Multimodder
Sheyr's Avatar
thanks tm36usa, that's what I'm really going to do - i've already started the job and i'm giong to insert some images , but it seams to me that this function is disabled for new users?
Old 6th Apr 2005, 22:24   #5
tm36usa
I *am* a Dremel
tm36usa's Avatar
Weird about the images.. Cheat the system, put this - "[IMG]" before the url of the image (without the quotes) and put this at the end of the url "[/IMG]" again with out the quotes. Hope this helped you.
Oh are the images hosted? or are they on you computer?
__________________
Old 7th Apr 2005, 22:58   #6
Sheyr
Multimodder
Sheyr's Avatar
for my mod I used a standard used Compaq miditower case
(trying to insert first picture....)
Old 7th Apr 2005, 23:03   #7
Sheyr
Multimodder
Sheyr's Avatar
pictures are working
so the 2nd view of my Compaq - a 1mm steal , very hard to cut and drill !!
Old 7th Apr 2005, 23:10   #8
Sheyr
Multimodder
Sheyr's Avatar
After some first ideas i decided to cut out a crow in the side cover
so I've prepared a template
Old 7th Apr 2005, 23:14   #9
Sheyr
Multimodder
Sheyr's Avatar
this is a crow on a side cover
Old 7th Apr 2005, 23:16   #10
Sheyr
Multimodder
Sheyr's Avatar
the 2nd template is used to cut out the hole
Old 7th Apr 2005, 23:21   #11
Sheyr
Multimodder
Sheyr's Avatar
but before the crow-hole is done I drilled holes for rivets
(sory about my English!!)
Old 7th Apr 2005, 23:29   #12
Sheyr
Multimodder
Sheyr's Avatar
unfortunately that's all for today. Next updates on weekend I hope.
Old 8th Apr 2005, 00:25   #13
dubya01
Multimodder
dubya01's Avatar
dubya01 is on a distinguished road
wow thats gonna be alot of rivets
__________________
From Berlin | Germany
dubya01 is offline   Reply With Quote
Old 8th Apr 2005, 01:27   #14
tm36usa
I *am* a Dremel
tm36usa's Avatar
Looking Great!! Just a tip but you should make a entire update 1 post, not a post for each picture.
__________________
Old 8th Apr 2005, 08:39   #15
Axly
Multimodder
Axly's Avatar
Axly is on a distinguished road
Nice idea, and I'm looking forward to seeing the birdie once it's riveted.
I'm not sure the WWII Germans would be very happy when you call the two headed "Kaiseradler" (Emperor Eagle) a crow
__________________
|||||||||| ALUMINIUM
|||||||||| FIBREGLASS
|||||||||| POWERTOOLS - thirteenthirtysevenspthirtyfourk suxzerorz
Axly is offline   Reply With Quote
Old 8th Apr 2005, 10:55   #16
Blackfish23
Supermodder
Blackfish23 is on a distinguished road
looking good
Looking forward to see where this one goes
__________________
[FONT=System]Rig 1: A64 3200+ 90nm :: 1GB Patriot PC3200 XBLK :: 2 x XFX 6600GT 128MB PCI-E :: Asus A8N Deluxe:: WD 120GB SATA :: Tagan 480W :: Zalman Reserator ::DVD :: CD R/W :: Mountain Mods UFO (Modded)
2nd RIG: )-( ST20G5 )-( XFX 7800GTX )-(PQI 3200)-(120GB SATA )-(3200 Winnie)(X-Fi Extreme Music)[color=DarkRed])
Blackfish23 is offline   Reply With Quote
Old 9th Apr 2005, 21:01   #17
Sheyr
Multimodder
Sheyr's Avatar
Yes, you're right Axly - thanks for the remark. In fact I didn't know what kind of bird it was I'd like to say sorry to the German colleagues!
Old 9th Apr 2005, 21:08   #18
Sheyr
Multimodder
Sheyr's Avatar
And now some of today's work
the hole
and the EAGLE in the begining of cutting out
and after cutting out
And that's all for today.
Old 9th Apr 2005, 23:08   #19
Pitbull
Multimodder
Pitbull is on a distinguished road
funny looks
__________________
this sig was too long. and too annoying.
Pitbull is offline   Reply With Quote
Old 12th Apr 2005, 22:10   #20
Sheyr
Multimodder
Sheyr's Avatar
Some updates of Monday's and Tuesday's work......
drilled hols for rivets in the bird
painted with a grey primer
and with the red primer
i also painted a part of case cover with the primer
and with the first cover of green paint
first look at the case with the eagle
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
