RSS
Reply
Thread Tools View Mode
Old 8th Apr 2005, 22:46   #1
JavaDog
Hypermodder
JavaDog's Avatar
JavaDog is on a distinguished road
Project: Homebrew CNC Machine
Alternate Thread Title: "Why I haven't finished any mods in a while"
I have made another (complicated) project for myself. I am building a CNC Router!
For those not familiar - CNC is Computer Numeric Control. Through software, you PC controls Servo Motors to move a router in X- Y- and Z- axis (and more, but mine is only a three axis). This allows you to draw parts in CAD (Computer Aided Drafting) or CAM (Computer Aided Machining) and cut or machine those parts for a wide range of materials.
My machine will have a working range of 22in X-Axis by 22in Y-Axis and 5in Z-axis (Up/Down). I wll be using a Porter Cable Variable-Speed Router as my spindle. I should be able to cut Wood, Plastic, Aluminum (and case doors!).
I have some business uses that will generate income, and help offset the cost of the machine. Plus, I have thousands of fun ideas that I will now be able to build (including some kick ass case mods).
I will keep this thread updated with pictures, drawings and building photographs until completion, and a running cost tally:
Cost so far:
1) Two 26in Slide Assemblies: $130 (Ebay)
2) DeWalt DW618 Router: $168 (Check Froogle)
3) One IKO Linear-Rail (Z-Axis): $15 (Ebay)
4) Framing:
- - A) 80/20 Aluminum Structure - 47" 1515 x 2: $33 (Ebay)
- - B) 80/20 Aluminum Structure - 36" 1020 x 3: $36 (Ebay)
- - C) 80/20 Aluminum Structure - 36" 1530 x 4: $102 (Ebay)
- - D) 80/20 - Double T-Nut - #3279 - x 60pcs: $45 (Ebay)
- - - - I went a bit overboard on the T-Nuts.
5) 8in Ballscrew for Z-Axis: FREE!
6) CNC4PC Breakout Board, PSU, Charge Pump: $67 (CNC4PC Website)
7) Poly-Sci DC Servos with US-Digital Encoders x3: $321 (Ebay - HomeCNC)
8) Aluminum Plate - Assorted - For End-Plates and Z-Axis: $150 (Metal Supermarkets)
Total: $1067
Budget Max: $2000
Left to Spend: $933
__________________
Priority #1: Building a Homebrew CNC Machine!
All Non-CNC Projects ON HOLD
JavaDog is offline   Reply With Quote
Old 8th Apr 2005, 22:47   #2
JavaDog
Hypermodder
JavaDog's Avatar
As for the design, my machine is going to be VERY similar (with a few of my own tweaks) to the K2 KT-2514 in design. Although, it will be 22"x22"x5" (working area) in size.
the Frame will most likely be 80/20 or Similar extruded aluminum "industrial erector set".
The bed that the work material is clamped to will be MDF. When it gets cut up enough, I can just bolt down a new piece.
I already purchased some rail/slide assemblies from Ebay. These are about $2500 worth of parts new, I got them for $130 used. They are in perfect condition, almost no wear at all. Gotta love ebay.
Pictures:
These assemblies will be my X-Axis and my Y-Axis. They are approx 26in long, and will give me approx 22in of travel. They have a precision ball-screw will gives me excellent accuracy and very smooth motion.
__________________
Old 8th Apr 2005, 22:50   #3
JavaDog
Hypermodder
JavaDog's Avatar
I won an auction for a rail that I plan on using for my Z-Axis. It is wide enough and can handle a high-enough load that I won't need to use dual-rails. This will save me a few bucks...
I should get about 5" of travel with this. That means my router will be able to move 5" up/down. Generally, you want to set up the Z-Axis so that when it is all the way down the smallest bit you will be using will be touching the table.
Check it out:
Brandy new, not even opened. Not too shabby for $10.
Time for a wonderful MS-Paint "Cad" drawing (No access to my AutoCAD when I am at work!).
Now this is a very oversimplified drawing of how I am thinking of laying out my Z-Axis. Rail would be centered and the Ballscrew would be to the left or right of the rail. The plate the router is on (not shown) would have a block on the back for the ballscrew.
In case you are wondering where the servo driving the ballscrew would be:
__________________
Old 8th Apr 2005, 22:56   #4
JavaDog
Hypermodder
JavaDog's Avatar
That's it for now, build pictures coming soon!!
__________________
Old 8th Apr 2005, 23:00   #5
Valo
Hypermodder
Valo is on a distinguished road
wow...
now that's a hella cool project looking forward to this
Valo is online now   Reply With Quote
Old 9th Apr 2005, 01:59   #6
leviathan18
Multimodder
leviathan18 is on a distinguished road
you should give discount to bit tech ppl xD to use that nice cnc machine
__________________
sorry for my english
leviathan18 is offline   Reply With Quote
Old 9th Apr 2005, 03:09   #7
JavaDog
Hypermodder
JavaDog's Avatar
As a matter of fact...that is going to be one of my uses for this machine. A...side business...if you will.
I decided to play around and make a video of the THK Bearing/Screw assemblies being driven with my cordless drill. I'm such a dork, but I couldn't resist sending my camera along for a ride too.
Check it out. The jerkiness you see is an artifcact of shooting video on a digicam.
Nothing too amazing, but it sure is fun to watch them go back and forth!
__________________
Old 9th Apr 2005, 04:36   #8
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has a spectacular aura aboutFirehed has a spectacular aura aboutFirehed has a spectacular aura about
Cool Looks like it'll actually be CNC and not "poor man's CNC modded drill press" Nice work so far!
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Old 9th Apr 2005, 04:47   #9
appe
What's a Dremel?
appe is on a distinguished road
This is awsome, the numbers of homebrewed CNC's grows fattier everyday, its just awsome that so many is taking the step into infinite power..drilling. :E
__________________
leds 4 all!
appe is offline   Reply With Quote
Old 9th Apr 2005, 05:43   #10
jaguarking11
Peterbilt-strong
jaguarking11's Avatar
jaguarking11 is an unknown quantity at this point
Very nice java dog. I was wondering when you are done will you be doing work for others? of course I payed work so you can make a buck from it as well.
BTW sweet parts.
__________________
Cube PC -done
Hard Lined -Working
Feel free To discuss my projects.
jaguarking11 is offline   Reply With Quote
Old 9th Apr 2005, 06:48   #11
devenfore
LANCandy
devenfore's Avatar
devenfore is on a distinguished road
Wow. I have always wanted to build one of these, but I dont think I ever will. Make sure to post lots of pictures.
devenfore is offline   Reply With Quote
Old 9th Apr 2005, 14:49   #12
JavaDog
Hypermodder
JavaDog's Avatar
BTW sweet parts.
Thanks. Yeah, I plan on doing work for modders. I also have a TON of ideas for case-mods and other projects I want to do too. This machine will let me get the ideas from my brain...into something solid!
Don't say never, I said the same thing a while back - but I saw others doing it and said "Me too!". Biggest thing is learning to use tools and measurement correctly.
I love taking pictures (other hobby) so you can count on that!
__________________
Old 9th Apr 2005, 14:52   #13
dream caster
just lurking from out there
dream caster is on a distinguished road
Suppose you have read this thread CNC uber router - Yay, update!, in this same forum; but just in case. . .
dream caster is offline   Reply With Quote
Old 11th Apr 2005, 13:59   #14
JavaDog
Hypermodder
JavaDog's Avatar
Yeah, I had seen that. Too bad the guy doesn't do any case-modding anymore.
Well, due to some sickness in the family I didn't get a whole lot done this weekend (of anything). But, family comes first.
I did get my new Ballscrew for the Z-axis, as I said a few days back. Here it is in all its glory:
Ain't it sexy! The motion on it is tight, fast, and very smooth. Has approx 5.75in travel. Since my IKO rail for my Z-axis has 5.5in of travel, it is a perfect addition.
__________________
Old 11th Apr 2005, 18:38   #15
ZeroHerO
Multimodder
ZeroHerO is on a distinguished road
I soo want a project like that :-), I hope you post a very detailedlog, I wanna coppycat this project (If you donīt mind)
Cincerely ZeroHerO
__________________
Asus Rampage Extreme, Core 2 Duo 8500, 2x2Gb Corsair XMS1600 DDR3, Inno3D9800GTX+, watercooled and effecient ;-)
ZeroHerO is offline   Reply With Quote
Old 11th Apr 2005, 18:58   #16
TTmodder
Hammertime
TTmodder's Avatar
TTmodder is on a distinguished road
Cool project
__________________
Originally Posted by Nexxo View Post
I've said it once and I'll say it again: screen estate is like money. You can never have too much.
TTmodder is offline   Reply With Quote
Old 11th Apr 2005, 19:03   #17
HowY
Multimodder
HowY's Avatar
HowY is on a distinguished road
'Bout a roto zip?
Man you gotta keep up the progress on this one
I've been wanting to build a CNC machine for years
You might consider a Roto-Zip as opposed to the router you suggest
it's lighter and much faster (rpm) will cut metal as well....
Collets for 1/8-1/4 bits much better toll for this
What you doing for control software?
how you going from DesignCand/AutoCad into xyz
via DXF ....
Sooo many questions and very encouraging !
HowY is offline   Reply With Quote
Old 11th Apr 2005, 20:19   #18
JavaDog
Hypermodder
JavaDog's Avatar
via DXF ....
Well, many people are using the same router as me for plastic/aluminum. It works fine, and is more powerful than the Roto-Zip. The PC router I am using is rated at 2 1/4 HP and is variable speed (10,000 - 23,000 RPM). It also comes with 1/4" and 1/2" collets. Larger collet lets me use larger bits.
So, the Roto-Zip isn't a bad solution, but I was looking for something with a bit more "umpf".
Software wise, I use Autodesk Inventor 5 for some of my CAD work. I will probably be using Artsoft Mach3 software to start. I plan on eventuall moving up to OneCNC-XR (Amazing software). The OneCNC-XR software is everything I need, but at $1500 starting, will have to wait a bit.
__________________
Old 11th Apr 2005, 23:54   #19
Sanatarium
Modder
Sanatarium is on a distinguished road
Very cool work man, you have some serious skill to take and make a homebrew CNC! Thats hardcore.
Sanatarium is offline   Reply With Quote
Old 12th Apr 2005, 01:10   #20
padrejones2001
Puppy Love
padrejones2001's Avatar
padrejones2001 is on a distinguished road
Good choice on the router, Porter Cable is a pretty bulletproof, but something from DeWalt has a longer duty cycle (meaning it can take more abuse). Something like this would be more ideal. And you can even upgrade the motor in case you cook yours. Not my intention to criticize, just giving syou something to think about. The mod looks like it's coming along nicely. I can't wait to see where it goes from here. Oh, and I agree, the Roto-Zip is not the tool for the job because, quite frankly, it's a peice of s**t. I used to be a tool saleman at SEARS and we saw more burned out motors from basic stuff than any other tool.
__________________
Teh Signature | Teh Puppy
padrejones2001 is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
