Thread Tools | View Mode |
#1 |
Supermodder
Project Zak's Hevy Plex SLB. Finished
who's Zak?
Zak's my 8yr old son ![]() and i promised after i got thru with modding hpres2 and few other proggys id jazz up his Super Lan Boy case ![]() The idea will be to add plex panels and some sexy lighting with a industial look, keeping the whole mod basic but clean and sharp looking without loosing the SLB look he likes so much. Rather than pull down his current slb we decided a nice fresh case was the order of the day to start this mod with and some pre cut to side clear 4.5mm plex and 2 x defyant style full side mounted water res's. ![]() while zak pulls get a start and pulls down the case for cutting i get a start with the custom side res's These new models will have a "qick release" type mount. ![]() The end result after water testing. ![]() Next was to get a start on the plex side paneling. To give the case a hevy industrial look were attatching all the panels using hex head bolts and countersinking all the holes on the plex. a shaped hole is cut as to allow the Custom res's to "sit in" Holes are drilled and the side panel new plex panel and res's are bolted together.
__________________
Why you ask? Because we can! Last edited by DÈF¥âÑt¸.·´¯`¤; 26th Apr 2005 at 07:30. |
#2 |
Puppy Love
If this turns out as good as your HP cases, then this will be a damn good mod. I see you're going withe same kind of watercolling as the Resurrection. I shall be watchng this thread, and keep up the good work, sir.
| padrejones2001 |
| View Public Profile |
| Find More Posts by padrejones2001 |
#3 |
Multimodder
Already looking good Defyant, nice use of the keyboard guts
Do you just use normal acrylic cement when building your tanks? I am making a custom tank myself, obviously what your using works good
__________________
Get Overhauled |
#4 |
Modder
That's a lucky young man.
#5 |
Look out sugar, here it comes
A lucky kid and a lucky dad.
__________________
Starbuck's Wizard Designs Forum's #1 Semiretired Admin - Muh Flickr! - Muh Blog P5N32E-SLI Plus, E6750, 8800GTX, 2GB, 2.6TB, 2407FPW = Left Brain D80, SB600, 50mm f/1.4, 18-135mm f/3.5-5.6, 10-20mm f/4-5.6, assorted filters, POS $40 tripod = Right Brain |
#6 | |
Natural Born Chaos
![]() Good work Defyant
__________________
Steam: kev_fury New Frag Video- Gigabyte EP43-DS3L - E8200 - XFX 4870 1GB - 4GB Kingston - - Steel Series 7.1s - Logitech G11 - Razer Diamondback 3G - 2209WA - |
#7 |
Constructing since 1978
Looking awesome already. You're already showing that this is of similar standard to Resurection.
In the bottom left picture you have what looks like the guts of an old keyboard. What are they, and are they attached in that bottom right pic? (If so, how?)
__________________
Remember - for every silver lining there is a cloud. "Of course, overclocking doesn't normally involve a tank of acetylene large enough to blow a house off its foundation." - zackbass MAME Over - Custom built arcade cabinet. This season's mod - The New Black Also modded - "Got Milk?" |
| Constructacon |
| Find More Posts by Constructacon |
#8 |
Multimodder
you dont need another son???? i can be for free if you make mod cases for me xD
that is water cooling????
__________________
sorry for my english
#9 |
Ultramodder
i wish my dad was this cool
dude ADOPT ME!!!!!!! we can mod together LOL cool mod so far
__________________
Project: Chrome Dragon? Current PC [AMD Athlon XP 3000+ Barton@2.3ghz][Abit NF7-S V2][1GB PC3200 Mushkin RAM@432mhz][Saphire ATI Radeon 9800 Pro->XT@432/375.55][80GB 7200RPM Maxtor HDD][60GB 7200RPM Maxtor HDD][Thermalright SP-97 Heatsink w/AS5 and 90mm Enermax Fan][Raidmax Scorpio 868][Fortron Blue Storm AX-500] 30ºC Idle/40ºC Load |
#10 |
Supermodder
Ladies and gentalmen, HE IS AT IT AGAIN!!! SO you can bet where he is, so will I!! Looks nice so far, your one for the res on the side of the case, looks good, very nice, very clean!! Keep it up!!
| G4m3R_X3r0 |
| Find More Posts by G4m3R_X3r0 |
#11 |
Supermodder
thanx guys
![]() the KB guts is just placed uner the clear plex, the bolts sandwich it all together ![]() I'd love to adpot more but as it is i seem to have adapoted almost every kid in the neighbourhood! as well as 2 years worth of cases to mod :PHevy plex slb will be water cooled i think the Dual side res's will become my trade mark on all my watercooled pcs ![]() i cant promise another HPres2 i dont know if i have that detail of case in me again but i will do my best !Qiky update. Adding the top and new side window. The top was again counter sunk drilled to aloow for hex bolts. The same for the side window, the original was binned for a matching one. All edges were hand beveled and wet rubbed then polished by hand. ![]() ![]() Next was to install a modualar "plug and play" type bay bus @ the back of the pc. This will supply power to the rear mounted radiator fan as well as the "hot swappable plug and play" light setup!!!!! ![]() Again some Defyant style flex lights are made. these will plug into each of the 3 panels and supply the light show. ![]() Next a quick test! with and without the workshop lights on ![]()
__________________
Why you ask? Because we can! |
#12 |
Multimodder
lucky child I would have you as my dad
__________________
this sig was too long. and too annoying. |
#13 |
Multimodder
nice.....will you make a case for your new 18 y/o stalker
__________________
?AMD Athlon 64 3500+ Venice?Sapphire X800 XT PE ?Abit AV8?1 gig 3200 giel?160 GB Western Digital 7200 ? FRIED EVERYTHING... 3DMark05 = 6306? "Last week, Japanese scientists placed explosive detanators at the bottom of lake Loch Ness, to blow Nessie out of the water..." Napolean Dynamite |
#14 |
Licenced idiot.
acryl seems to glow very nicely even with only few leds on it
I wouldn't taught it works so nicely.
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01 |
#15 |
Licenced idiot.
I wouldn't've taught it works so nicely.
__________________
#16 |
Ultramodder
Can you adopt me? I'm only 22... lol
Looking good! I had the same idea with white
__________________
Top 5 Listening to Now - A Second To Last - Dying Against Your Will Rock Kills Kid - Paralyzed Zero State Reflex - I'm Splintering Hot Hot Heat - Middle of No Where ![]() - www.nerges.net |
#17 |
Multimodder
Naw, ef that man, adopt me, I'm still young and under 18!
Nice work ya got going on here, I love that plug&play LED idea for the plexi, very original, and you managed to mount that LED to that plug VERY nicely. Keep it up! ... And adopt me!
__________________
Chieftec Aluminum Mid-tower Dragon Series :: ABit AN9 FATAL1TY :: AMD Athlon 64 X2 Windsor 3000mhz 2MB L2 Cache :: nVidia GeForce 7800GTX SLI :: 3072MB DDR2 800 PC2 6400 :: Seagate 250GB SATA 3.0GB/s (x2) :: Creative Sound Blaster X-Fi Xtreme Gamer :: Creative GigaWorks S750 7.1 Speakers :: Samsung SyncMaster 226BW 22" Widescreen LCD Last edited by ginx; 21st Apr 2005 at 21:54. |
#18 |
Hammertime
DAMN a lucky kid
#19 |
Supermodder
Next was to sort out some lighting for the Res's. Another defyant style glext light was made this time with a clear plastic end clamp.This will attatch to the base of the re's.
A rubber grommet was also added to the side panel to hold the led light tight and in place. ![]() ![]() ![]() Last but least a full light test.
__________________
#20 |
Supermodder
::bow & worship:: Oh great god of mod, please teach me your ways!! I will forever serve you...
I wish to be as great and powerful as you my lord! ::/end bow & worship::Seriously Kick @$$, you have a very lucky kid, and i bet he's glad to have an awesome dad like you!! |
| G4m3R_X3r0 |
| Thread Tools | |
| View Mode | |
