Project AloX ::UPDATE:: January 12 2006 -=new plans=-
Discussion in 'Project Logs' started by Dries, 4 May 2005.
  1. Dries
    Dries What's a Dremel?
    24 Jun 2004
    Hi,
    I had been thinking about bringing to life a casemod concept which I thought would be very cool. It was only a few weeks ago that I took the courage to actually put my hands on the construction of the case...
    This is the original concept drawing of the case and this is what I want it to look like:
    I was thinking about doing this whole case in inox, but since that would make it way too heavy I'm making some parts of it in (much lighter) aluminium.
    A little background information of the concept:
    As you can see on the drawing, there is a sort of a cylinder on the corner of the case, which is to be found on any of the four corners actually.
    In these 'pillars' of stapled flat 'donuts' or rings there will be a plexi tube with a liquid neon ccfl in it. To cool them there will be mounted on top of the pillar a metal shower tube (with chrome finish :thumb: ).
    There will be 2 fans sucking away the air through the pillars and through the tubes to cool down the ccfl's.
    Following are some pictures of already completed work.
    If anyone of you has a question about something you don't understand or something you would like me to make clear or to give a suggestion ... don't hesitate and just reply! :clap:
    Also, if you want to know something extra about the production, just ask.
    More update will follow as work on this casemod will progress...
    greetz,
    Dries
  2. fla
    fla What's a Dremel?
    23 Oct 2004
    Can you give us larger pics?
  3. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    dude you should resize your pics they are way to big! cant really see stuff becouse have to scroll around.
  4. antiHero
    19 Jan 2005
    WTF?
  5. Brew
    Brew What's a Dremel?
    8 Apr 2004
    Yeah downsize those pics guy, those are beyond way too big. Dont expect anyone to do what you should have with View Image, and maybe read the forum rules while your at it.
    Anyways, thats a cool looking concept though, ar you going for a terminal/interface station kind of feel? It looks like something you would find on a wall in Half Life 2 :hip:
  6. Dries
    24 Jun 2004
    I'm working on downsizing them, just a sec...
  7. Dries
    24 Jun 2004
    sorry guys, when messing with the pictures in Photoshop I totally forgot the size of the pictures I was working with. I think at a resolution of 800*600 they're much better viewable. Sorry for the inconvenience... :D
  8. deadly-app
    deadly-app What's a Dremel?
    9 Mar 2004
    Ayeee yet another modder with access to a mill :(
    grr, but it looks fantastic so far, this will be one im going to keep my eye on :D
  9. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    Looks like it is a lathe... :thumb:
    This looks like it is going to be a very nice mod!! I echo the 'mounted on a wall' look to it...very cool!
  10. n0ll4k
    n0ll4k What's a Dremel?
    1 Jun 2003
    i lke the drawing a lot looks very nice
    und those neons too
  11. deadly-app
    9 Mar 2004
    mill is synonomous with uber metalworking machinery in my head :D
    hes got a fatty band saw there too...so im willing to bet he has access to a mill :)
  12. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Now that, my friend, is some sweet modding!!
  13. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    DIY stuff, neat :clap: .
  14. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    i want larger pics. got a 19" moniter but maybe the others with only 17" want smaller
  15. tsa cain
    tsa cain What's a Dremel?
    14 Mar 2005
    that looks pretty cool i wish i had access to those type of machines
  16. ehrnam45
    ehrnam45 What's a Dremel?
    5 Jul 2004
    Well, in a way you do: www.emachineshop.com
    If not, I'm sure there are hundreds of fabrication shops in the greater DC area that would be more than willing to help you prototype your design. It's pretty expensive to have someone else do it, but certainly cheaper than buying the equipment yourself :p
    As far as the case goes, I'm not really sure how the tubes relate to the original design. Perhaps a sketchup of the design would help? I do love to see custom millwork in cases though. Keep us posted!
  17. Dries
    24 Jun 2004
    As you have requested, here is a complete sketchup :thumb: :
  18. ReFredzRate
    2 Sep 2002
    Nice sketches :thumb:
  19. ehrnam45
    5 Jul 2004
    aha! almost looks like a sci-fi castle. I'm not sure that those hoses will really do much for air flow, but they sure look cool.
  20. Vito
    Vito What's a Dremel?
    19 Dec 2003
    Man, you know how to draw a sketch! I enjoy those sketches more than those 3d-generated. Subscribed. This mod could become one of the top mods of bit-tech. I wish you luck.
