#61 |
Hypermodder
A good day of work.
![]() Painted in black the modded parts of the joystick and reassembly started. You can see the now added military switch cap. ![]() The painted front!! I dissapointed with the flash pics, it kill the drybrushing effects. I`ll take some pics with natural lights. ![]() The LIS2 VFD mounted in place. The blue squares of the screen are almost invisible without the flash lightning, and the screen remains black when off. Maybe the front needs some more details, What do you think? More soon.
__________________
Ore wa Kumo Da! KNS-04: Cube - KNS-01 (Old) - KumoNoSuJou - LAN Raider - DarkWater - Intranquility - Chii-EDPC - LanMachineInterface www.knsweb.net |
#62 |
Hypermodder
The promised pic without flash:
![]() In this moment the front is being glued with Araldit to the chasis.... I would prefer screws, but they don`t match with the front. I hope it can hold together. The main work of today was about the joystic and its wiring... long wiring ![]() It isn`t easy to explain or follow... headache ![]() But the first test has been succcesful and the buttons fan controller and others works. ![]() You said wiring? The other half of the joystick is also plenty of wires. Thanks Mashie for the idea of the speed fan controller. A couple of pics of the end result. ![]() ![]() You can see also the keyholder with the keys for the locks. More tomorrow. It has been a long day.
__________________
#63 |
Hypermodder
I`m at the middle of the tunnel, the light at the end is closer, but still more work is needed. But for the LAN party of this weekend, i`ve done almost all work.
The system is up and running. ![]() Near, my new TFT screen ![]() Without lights. The ComDome (hehehe... its sounds... jajaja) works very well and the light from the power and hd leds is blocked in some way to pass thru directly. ![]() I had to make this with stand off pieces to attach the DVD cover. ![]() ![]() Painted cover, with and without flash. I`m happy with the overall look of the front. ![]() To finish the day i`ve cutted a rectangular hole in the hull and added some mesh to allow more cooling for the 6600GT and others. More soon.
__________________
#64 |
Supermodder
Front looks great! Perhaps you could make some spots darker and some lighter rather than just the same grey throughout, but otherwise, good effect.
#65 |
Modder
WICKED DRIVE STEALTH.
verry well done.
__________________
Technology Meltdown
#66 |
Hypermodder
Last week i gone to a LAN with this system.
Before derparture for the last week LAN i did some extra work. Anyway it was an unfinished project but i didn't want it looks a ugly teapot. ![]() I need a hole to pass the fillport... ![]() Put some mesh in the side vents. ![]() ![]() And painted it with a mix of black mat and dark grey blak mat as first coat, after began to adding some details. With that half pimped shell i could go to the party with less red color in my face... Today i've bought a new fan. Since the party, the temps are good (for this kind of mod/system) but i wanted to cool it a little more and i've tried with a bigger fan. My choose has been a TT Silent Cat 92mm (Mainly reason: the 80 to 92 adaptor included) with a good flow and low noise. Actually the system is only 1C cooler But 1C is 1C better than nothing. Anyway the loud is lesser.![]() Put the fan there is a hard duty. The desing looks good, althoug i have nothing against white color (its original for now) i would prefer a black one for this mod. ![]() No screws this time (almost not possible) so i used silentblocks. I hope, at least they avoid a little more noise also. ![]() Fits, but was hard. My first idea was to replace the funnel with the 80-92 adaptor, but the hoses make that impossible. More soon.
__________________
#67 |
Supermodder
Nice Shuttle, crazy faceplate. Its starting to become my favorite aside from this http://www.pc-max.de/forum/article.php?&a=262
__________________
-The 500w Shuttle-, SN95G5, AMD3500+, msi 6800gt, 2x512mb ballistix, 200gb Seagate (sata), audigy 2zs, 500w internal psu |
#68 |
Supermodder
the front looks great and the sleeving too.
what is the size of the case? |
#69 | ||
Hypermodder
Thanks both.
__________________
#70 |
Guest
Posts: n/a
wow! awesomeness! nothing like a well pulled off SFF mod!
#71 |
grunge modder
Awesome
Looks great! I see you hung the rad on the back. I think I will have to do the same on mine.
__________________
Don't Tread On Me! I suppose that makes me a radical now... Project: Perforated, a Grunge Mod - cut down Antec Dragon case, SciFi themed 'Aliens' mod - Maximum PC Rig of the Month Aug 2005 Project: Harlot 5, a Grunge Mod - SFF Scifi themed, Flight Data Recorder |
#72 | |
Hypermodder
Thanks. I hope you have some space more for a bigger rad. With the new fan the temps go down a little (and also the noise). Now i'm working in the hull. Maybe later i could upload some pic.
__________________
#73 |
Hypermodder
I'm slowly going head with the project. Now i'm messing with the decoration of the case. I have some ideas, but at this point i'm mind blocked or kind of. Tomorrow will be another day.
A couple of pics of the work. ![]() ![]() The big hole is for better cooling of the case. Will be covered with mesh for dust and a sort of shield to avoid direct line of sight. Some of the inner lights will pass thru the smaller holes, than act as "windows" More soon.
__________________
#74 |
Hypermodder
Today's main work. i've made the "shield" or "deflector", any name is valid
![]() ![]() I'm happy with the look, it makes the case less plain / flat. And the gap allow more cooling. ![]() Inside, i've glued some mesh for dust. More tomorrow, i hope.
__________________
#75 |
Supermodder
How strong is that wood? It sure would suck to have something bump the side and crack that pretty spaced out thing.
__________________
#76 |
Hypermodder
The plywood is stronger than it looks and it's solid fixed. It must be a strong bump to crack it.
__________________
#77 |
What's a Dremel?
ooOOOOOo a post from the future, just realised that you were in Spain, i was a little confused when i saw the post date of 8-26-05 .
neat mods, keep working on her and she'll be great |
#78 |
Hypermodder
Should be about 8hours from here to Michigan. I posted that yestarday (/today) late.
__________________
#79 |
Hypermodder
Slowly progress.
![]() One side "finished"... ...And the begining of the other one. ![]() ![]() It isn't the exact same patern that in the other side. More to come, soon.
__________________
#80 |
Look out sugar, here it comes
It's getting very detailed now... much better than I would have expected. Well done.
__________________
Starbuck's Wizard Designs Forum's #1 Semiretired Admin - Muh Flickr! - Muh Blog P5N32E-SLI Plus, E6750, 8800GTX, 2GB, 2.6TB, 2407FPW = Left Brain D80, SB600, 50mm f/1.4, 18-135mm f/3.5-5.6, 10-20mm f/4-5.6, assorted filters, POS $40 tripod = Right Brain |
| Thread Tools | |
| View Mode | |
