News ATI's partners slip Radeon X550 out
Discussion in 'Article Discussion' started by Tim S, 6 Jun 2005.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. bloodcar
    bloodcar Minimodder
    1 Sep 2002
    There are too many freaking video cards on the market. It's becoming a pain in the ass just to find the best budget card with 15 lines of budget cards.
  3. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    oh boy it's 9000/9100/9200/9500/9550/9600 all over again. Cut the **** please ATI.
  4. Tim S
    Tim S OG
    8 Nov 2001
    You missed the 9250 :duh:
  5. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    I dissagree. I like it that more new cards are in the market.
  6. Froggy
    10 Jun 2003
    None of those fit in a PCI-E slot.
  7. Tim S
    Tim S OG
    8 Nov 2001
    You're correct... but we've got the following parts, all have four pixel pipelines and two vertex shaders.
    X300 SE HyperMemory, X300 SE, X300, X550 SE, X550, X550 'Ultra', X600, X600 Pro...
    I think that is the point that Tulatin is trying to get across. :)
  8. bloodcar
    bloodcar Minimodder
    1 Sep 2002
    I don't think I'm going to buy another ATI card until they can get their lines straight. At least with nVidia I know what the hell I'm going to buy.
    There should be THREE cards per generation. High end, Mid range/budget, and low end and THAT'S IT.
  9. Froggy
    10 Jun 2003
    But when your compeditor releases there 3 cards, and they end up slightly faster than your 3 cards, the smart thing to do is release 3 more cards that beat your compeditors 3 cards. It goes back and forth like this. In the end, the consumer is the winner.
  10. bloodcar
    bloodcar Minimodder
    1 Sep 2002
    Not really, it's more of a bigger turnoff then anything. Most of these cards are at the same price range with a very small difference. I have a small buget especially when it comes to buying new computer parts atm, and it's a pain in the ass to go look for a new video card and there's 20 different cards that all cost the same.
  11. Froggy
    10 Jun 2003
    If they all cost the same, then its easy. Pick the best one.
  12. bloodcar
    bloodcar Minimodder
    1 Sep 2002
    And THERE lies the problem.
  13. Froggy
    10 Jun 2003
    You mean the problem is wich one is the best? Usually a quick look at the specs will tell you.
    Ok for example card A does 500mhz, card B does 525, and card C does 550. All the above have same memory and core. Easy to see that card C is most likely your best bet.
  14. dom_
    dom_ --->
    4 Jan 2004
    why would one manufacturer sell the same cards at different clocks for the same price?
    if your talking different manufacturers then you cant just compare specs like that.
  15. Tulatin
    16 Oct 2003
    that's it big-Z.
    cards of the same freaking core/budget family
    8500LE/8500/9000/9000PRO/9100SE/9100/9200SE/9200/9250/9500/9500 Pro/9550/9550 Ultra/9600SE/9600/9600PRO/9600XT.
    :D
  16. Guest-16
    Guest-16 Guest
    Doesnt the x300 have 2 pixel pipes? The IGP version does.
  17. Tulatin
    16 Oct 2003
    the real one has 4, the igp is just a gimped model. as if the card wasn't gimped enough as is...
  18. Guest-16
    Guest-16 Guest
    That's what i assumed after posting and thinking about it a little (as hard as it was). I mean, they've got to fit the controller for everything else in it and a teeny tiny heatsink too, so 4 was probably non-doable on the FAB process.
  19. Tim S
    Tim S OG
    8 Nov 2001
    yes, the IGP is fabbed on 0.13 micron, so ATI are pushed for die space on the northbridge.
  20. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    *head explodes*
Tags: Add Tags
