#1 |
Supermodder
iPod Mini problem
I have noticed two little oddities when using my iPod lately, and I want to know if anyone has any suggestions.
1. A couple songs will stop playing part way though and just skip to the next song. I've even tried erasing all the songs and reloading, but the same two songs always do that, though they work fine in iTunes. 2. Sometimes when I'm mowing, the iPod will just pause midsong, even though I have the 'hold' on so I didn't press the pause button. I figure that the hard-drive is just getting too much vibration and had to stop playing or somthing, but I'm not sure so I thought I'd ask. Thanks in advance. PEACE |
#2 | |
Big and Blue
Have you tried flashing the firmware?
__________________
AMD XP2000 l Gigabyte GA-7N400 Pro2 l Maxtor 80 GB PATA l 512Mb PC2100 l Nvidia 6600GT l Hiper Type-R 480w Chrome l Blue Chieftec Full Tower
SDMS .:. Project Big and Blue .:. Email |
#3 |
Supermodder
No, they have a 1" minidrive. I'll try the firmware, though.
PEACE |
#4 |
Gravity hates Bacon
RE: The two songs that stop playing halfway through -
I am guessing that the files a tiny bit corrupt. itunes probably has better error correction than the iPod. Try re-ripping the songs with error correction enabled. (If you don't still have the media, you could try converting them to another format and see if that fixes the problem. Oh, and for further clarification for kill_me_quick, it's the shuffle that has flash memory in it.
__________________
Srenob is deader than dead, so check out my new blog instead: http://i-have-a-blog-now.blogspot.com/ (Note - there's not much there yet, but maybe there will be someday.) |
#5 |
what is the cheesecake?
not corrupt. ipods have a pretty well documented problem with playing VBR MP3 files- it's happened to me too. there is a fix out there; and here it is:
http://txfx.net/2005/02/08/vbr-mp3-fix/ as for the other one.... not sure. |
#6 |
Supermodder
Actually, both files are iTunes AAC songs, so the VBR MP3 isn't it. I might be burning them all to audio CD and re-encoding into MP3 soon (to remove the DRM for my other MP3 player and because I forgot how to back up my AAC licenses). Hopefully that will work.
PEACE |
#7 |
Gravity hates Bacon
Good luck
__________________
#8 |
Supermodder
Thanks.
| Tags |
| apple |
| Thread Tools | |
