Old 15th Jun 2005, 13:54   #1
WilHarris
Just another nobody
WilHarris's Avatar
WilHarris has yet to learn the way of the Dremel
PowerColor X700 Bravo
http://www.bit-tech.net/hardware/200...r_bravo/1.html
WilHarris is offline   Reply With Quote
Old 15th Jun 2005, 14:21   #2
Da Dego
Brett Thomas
Da Dego's Avatar
Da Dego has yet to learn the way of the Dremel
Erm, Wil?
* XFX GeForce 6600 GT Std 128MB - operating at its default speeds of 300/600MHz using ForceWare 71.89.
Which is it, a 6600GT or a 6600 Std? I'm confused.
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo
Da Dego is offline   Reply With Quote
Old 15th Jun 2005, 14:52   #3
Tim S
I Mod, Therefore I Own
Tim S's Avatar
Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.
oops, sorry, my fault.... 6600 Std
Tim S is offline   Reply With Quote
Old 15th Jun 2005, 15:05   #4
Da Dego
Brett Thomas
Da Dego's Avatar
All good now, I was a bit confuzzled. I'd be mad if that passively cooled little thing beat out my 6600gt.
__________________
Old 16th Jun 2005, 21:22   #5
jezmck
jezmck's Avatar
jezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyan
There was me looking at it on Komplett, seriously considering it when I noticed it's PCI-E.
And yes you did say so - I just didn't see that.
And yes the photos do show it too.
Any suggestions for a similar grade card for ol' AGP?
__________________
Have you seen The SketchUp Components Collection's latest items?
jezmck is offline   Reply With Quote
Old 17th Jun 2005, 17:04   #6
Da Dego
Brett Thomas
Da Dego's Avatar
Hahaha...jazzle, better look out, Firehed the PCIe Police will show up at your door! And not to hand you a new PCIe motherboard, either.
(sorry Firehed if you read this, just had to say it...)
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
