Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 21st Jun 2005, 03:51   #1
ArtificialHero
We were just punking him sir!
ArtificialHero's Avatar
ArtificialHero has yet to learn the way of the DremelArtificialHero has yet to learn the way of the Dremel
Can I upgrade my PowerMac?
Hey all,
I've just been offered a B+W PowerMac G3 400MHz, with 128Mb ram. I wanna install Tiger on it, but i need to at least get another 128mb of ram before this is possible. Is this worthwhile, and is there anything else anyone would recommend to make tiger run a bit smoother? I've got a budget of about a hundred quid.
AH
__________________
ArtificialHero is offline   Reply With Quote
Old 21st Jun 2005, 03:53   #2
Lovah
Apple and Canon fanboy
Lovah's Avatar
Lovah should be considered for presidentLovah should be considered for presidentLovah should be considered for presidentLovah should be considered for presidentLovah should be considered for presidentLovah should be considered for presidentLovah should be considered for presidentLovah should be considered for presidentLovah should be considered for presidentLovah should be considered for presidentLovah should be considered for president
I assume you can easily expand the memory. Fairly cheap aswell.
Although I think Tiger will have a hard time running smoothly on it. 400Mhz G3 isn't that much of a powermachine.
Even if you don't get tiger on it. still keep it! Its nice to collect them!
GL
L
__________________
Canon 5D + Grip | Canon 5D mkII
EF 17-40mm F4 L | EF 35mm F1.4 L | EF 24-70mm F2.8 L | EF 50mm F1.4 | EF 85mm F1.8 | EF 135mm F2.0 L
Manfrotto 190ProB + 486RC2 | Canon 430EX + OC-E2
MacBook Pro 15" 2.2ghz | iMac 27" i7 | iPad 2 16GB WIFI
Lovah is offline   Reply With Quote
Old 21st Jun 2005, 06:30   #3
Go4t
i <3 bloodcar
Go4t's Avatar
Go4t has yet to learn the way of the Dremel
i think you can actually get a cpu upgrade to a g4 but i dont know how much it would cost
__________________
<kameleon> ~~~~~~~C====8d-_-b8====D~~~~~~~
<kameleon> EARGASM
Go4t is offline   Reply With Quote
Old 21st Jun 2005, 17:33   #4
TekMonkey
I enjoy cheese.
TekMonkey's Avatar
TekMonkey has yet to learn the way of the Dremel
Take a look at Accelerate Your Mac. It's a good resource for upgrading macs.
edit: this page specifically has lot's of g3 info.
__________________
ComputerKing: "Dude! I write my signatures by my self! do you think that I go store to make him write for me! you funny..."
TekMonkey is offline   Reply With Quote
Old 23rd Jun 2005, 02:26   #5
Rampax
Banned
Rampax has yet to learn the way of the Dremel
How much are you paying for it? Add the cost of ram and then make the decisions.
Rampax is offline   Reply With Quote
Old 23rd Jun 2005, 09:23   #6
ArtificialHero
Getting it for free, just need to buy the ram.
AH
__________________
Reply
Tags
apple
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
