#1 | |
Geoff Richards
Moderator
AMD Athlon 64 FX-57
#2 |
Geoff Richards
Moderator
Definitely one for those who *have* to have the best, at any cost. I have read about several clocking to 3.6Ghz with phase-change cooling...
#3 |
Modder
FX-55 has done 4.0ghz @ Xtremesystems, so it'll be interesting to see what the nutters around the globe get up to with these FX-57s
![]() More details on the processors used? afaik theres a 2.6ghz 512kb cache 4000+ and a 2.4ghz 1MB cache 4000+
__________________
no, your face. |
#4 |
Pewlius Caesar
bit-tech Staff
the 4000+ was a 2400MHz Sledgehammer, as reviewed back at the fx55 launch.
__________________
#5 |
Why not? I own a domain to match.
Sounds nice, but I think I'd rather go for an X2 setup. Especially as I multitask quite a bit, and the real-world gaming results are about the same across the line. A fun bench to throw in there would be xvid encoding while mp3 ripping (or something like that), just to see how the extra mhz compares to a second core in multitasking.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net 40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8 MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD |
#6 |
What's a Dremel?
You also should have made a test where you overclock FX-55 to FX-57 speeds and then we would see how much we benefit from 90nm process.
#7 |
Supermodder
The high resolution game benchies made me laugh... 0,1 fps gain compare to FX55... Its not as good as I expected
__________________
"I really donīt know what weapons will people use in WW3, but they will fight with clubs and stones in WW4..." A. Einstein ![]() -= | FX-55 at 2808Mhz - DFI LANParty SLI-DR - 1GB OCZ DDR3200 EL Rev. 2.0 - GainWard 7800GTX GS SLI 525/1330 - WD Raptor 74GB - 2* Maxtor 300GB - OCZ Powerstream 520W | =- |
#8 |
Hax.
looks pretty cr*p if you ask me didn't exactly clot well either value for money... nope ![]() edit: me thinks it more to do with GPU limitations
#9 |
sensational.
Sounds crappy...
__________________
█▓▒▒▓█▓▒▒▓█▓▒▒▓█▓▒▒▓ Originally Posted by Greeneyedguy advice to all u masturbators... its a good idea to keep a pringles can with the bottom cut out next to u so u can put it over ur wang when ur parents come and tell em u were enjoyong some delicious low-fat potato chips... |
#10 |
Geoff Richards
Moderator
It's only "crappy" at high resolution gaming, when you are heavily GPU limited - I'm sure Tim will be benching 7800GTX SLI on it at some point to test that theory. The X2 is arguably a better buy in terms of future-proofing, but let's just see how pricing settles down after the initial demand is satisfied
#11 |
Lazy Lurker
And while you're at it, why not check how high the FX-57 goes on aftermarket heatsinks like the Zalman 7700?
__________________
Technology Schmecnology |
| RotoSequence |
| View Public Profile |
| Find More Posts by RotoSequence |
#12 | |
Officious Bystander
__________________
Demand Naked DSL in the UK! |
#13 |
Pewlius Caesar
bit-tech Staff
the higher resolutions are there as they are more 'realistic' settings that you might use for real-world gaming... that is the theory behind including those results. surely you arent going to buy an X2 4800+ or FX57 and game at minimum detail.
![]() Re: coolers... I shall see what i can do.
__________________
#14 |
charl3s_fatal1ty
Guest
Posts: n/a
Have you/have you thought about comparing the fx4800 with the fx57 in some benchies?
| charl3s_fatal1ty |
#15 | |
The other Brett.
Moderator
__________________
The Rt. Hon. Alexander Boris de Pfeffel Johnson - "Ping Pong is coming home" www.yodasarmpit.com clickr my flickr |
#16 | |
Pewlius Caesar
bit-tech Staff
__________________
#17 |
Minimodder
I'm amused by the way you don't include any Intel processors _at all_, presumably on the assumption that they'll all be crap.
#18 | |
Pewlius Caesar
bit-tech Staff
__________________
#19 | |
Brett Thomas
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
#20 |
Puppy Love
Well, here's another review. The P4's aren't doing half bad these days, so I wouldn't go around parading that they're crap for losing by only a few frames a second.
| padrejones2001 |
| Find More Posts by padrejones2001 |
| Thread Tools | |
