Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 8th Jul 2005, 17:22   #21
Green Soda
Hypermodder
Green Soda's Avatar
Green Soda has yet to learn the way of the Dremel
Originally Posted by Haddy
Still pretty scary that NASA couldnt get a laptop to function properly, guess it wasnt in the budget to test it before hand eh?
Its not in the budget to test computer, but it IS in the budget to waste $300+ million on a satellite to crash into a rock...
>_<
*edit: 2nd page, w00t
__________________
Signature?
::kna::> And if you don’t agree with me, you know where you can stick it.
<Taganath> Mary had a little lamb. It bumped into a pylon. Ten thousand volts went up its arse and turned its wool to nylon!
Green Soda is offline   Reply With Quote
Reply
Tags
apple
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
