Old 28th Jun 2005, 10:22   #1
WilHarris
Just another nobody
WilHarris's Avatar
WilHarris has yet to learn the way of the Dremel
Ultra Ramsinks / Media Bay
http://www.bit-tech.net/modding/2005...heatsin/1.html
WilHarris is offline   Reply With Quote
Old 28th Jun 2005, 10:53   #2
Darkedge
Supermodder
Darkedge has yet to learn the way of the Dremel
not using thermal tape was very very dumb - could they even make your ram hotter??
Darkedge is offline   Reply With Quote
Old 28th Jun 2005, 11:16   #3
GuardianStorm
Ultramodder
GuardianStorm's Avatar
GuardianStorm has yet to learn the way of the Dremel
so the drive bay media extender is a set of extension cables? in a box? i guess if its what you need, then its cool, but i would much rather make my own
as for the RAM sinks, i think they work well for asthetics, even if they dont help o/c wise
__________________
Sites: My Site :: My blog
Tools: Project Log Previewer
Curent Projects: Dark Vortex
Finished Projects: Yarrrbox :: Laptop Stand :: Bench PSU MK2 :: FS2
Guides: How To Bend Metal
GuardianStorm is offline   Reply With Quote
Old 28th Jun 2005, 11:21   #4
TMM
Modder
TMM's Avatar
TMM has yet to learn the way of the Dremel
Probably. Even the heatspreaders that do use thermaltape tend to insulate the heat rather then get rid of it. They look cool though. Anyone ever thought of using thermalpaste on heatspreaders?.
__________________
no, your face.
TMM is offline   Reply With Quote
Old 28th Jun 2005, 12:40   #5
Jumeira_Johnny
16032 - High plains drifter
Jumeira_Johnny's Avatar
Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.
I have thought about the thermal paste idea. In fact, I assumed every one did, and that was why you needed the clips. Boy was I wrong.
__________________
Dachshund of War™|TerrierX™|Macbook Pro|1967 Pontiac Catalina|360# Anvil|2 Burner Gas Forge|135 Amp MIG Welder
Jumeira_Johnny is offline   Reply With Quote
Old 28th Jun 2005, 12:50   #6
frodo
Ultramodder
frodo's Avatar
frodo has yet to learn the way of the Dremel
so, in theory the heatspreaders on my crucial ballistix are actually keeping the heat in?
so, in theory it would be better for me to REMOVE the crappy sink's on the ballistix as then the huge amount of airflow i have around the ram would actually help? if so someone tell me! i really want to be able to get higher OC from this ram, and after seeing this article it concludes my thought that its just 3M tape, not thermal tape!
frodo is offline   Reply With Quote
Old 28th Jun 2005, 15:11   #7
tm36usa
I *am* a Dremel
tm36usa's Avatar
tm36usa has yet to learn the way of the Dremel
Nope, corsair uses thermal tape, the same kind that gpu ram sinks are adhered(sp) with. They also only use a tiny thin layer of it so more heat gets out. So while not really helping dissipate the heat, they are not holding them back and making them hotter. Hope that helped frodo, and if you did want to take them off, put them in the freezer for 10~20 min and then gently pry them off
As for solving the heat issue because of that crappy tape, I got a set of heavy copper mem sinks like OCZ uses here, im going to try ripping off the crappy 3m tape and just use arctic silver and see how it works. Maybe I'll keep a tiny strip of the tape, just to kep them on the ram.
__________________
Project Double Helix
01110100011011010011001100110110011101010111001101 100001
tm36usa is offline   Reply With Quote
Old 28th Jun 2005, 15:23   #8
Jhonbus
Multimodder
Jhonbus's Avatar
Jhonbus has yet to learn the way of the Dremel
Hmm, my Kingston HyperX looks like it's got a big thick (seriously, something like 0.5mm!) tape holding the sinks on. Maybe I'll take it apart and see if I can improve matters.
Oh I liked the second article... "Appalling beige". Is that in the Dulux catalog?
__________________
You must create.
Jhonbus is offline   Reply With Quote
Old 28th Jun 2005, 18:23   #9
frodo
Ultramodder
frodo's Avatar
Hmmm, i said crucial not corsair, by the looks of it the crucial ram uses EXACTLY the same heatsinks! no difference at all bar the "ultra" is "ballistix" on my ram
i had some REALLY good akasa memory heatspreaders, that used a like clay, that was a near solid thermal paste, which when the memory was against did a very good job of transmitting the heat, shame i cant find them any more
Old 28th Jun 2005, 19:30   #10
tm36usa
I *am* a Dremel
tm36usa's Avatar
Sorry, I meant crucial. I've built a couple of systems with the ballistx sticks but for some reason I always think that corsair makes them. Stupid me
__________________
Old 28th Jun 2005, 19:35   #11
frodo
Ultramodder
frodo's Avatar
Yeah, im kind of getting pissed @ this ram, as it gets SO bloody hot @ 250mhz (what its meant to run :S) like it gets so hot its giving errors in memtest86! dammit
ive got plans involving acrylic and either 2x 80mm's or a few 40mm's @ 5v over the ram! as that might help cool it a bit, and also give some airflow over the PWM area of my dfi, which gets a bit warm during hard work (gaming, folding, more gaming, etc etc)
Old 29th Jun 2005, 11:45   #12
monkeyville
Evilish Monkey ++;
monkeyville's Avatar
monkeyville has yet to learn the way of the Dremel
not much to do with the actual article but i want to know what mat with all the kids drawings is. Looks well cool expecially the stick men
__________________
|eBay| Because monkeys never hurt anyone. |Hexus|
-=|My Site|=-
"If crime fighters fight crime, and fire fighters fight fire, what do freedom fighters fight?"
monkeyville is offline   Reply With Quote
Old 29th Jun 2005, 13:07   #13
WilHarris
Just another nobody
WilHarris's Avatar
www.explodingdog.com
Old 1st Jul 2005, 05:20   #14
matu
What's a Dremel?
matu has yet to learn the way of the Dremel
I have heared and I have seen 3M thermal tape.It looks the same as the normal 3M double sided tape. I`m sure that those heatspreaders have the same thing or the guys/girls who made them are REALLY not so clever.
__________________
matu is offline   Reply With Quote
Old 1st Jul 2005, 09:12   #15
frodo
Ultramodder
frodo's Avatar
hmmm, would prefer say shin etsu
either they use thermal tape
or they are to designery/fancy pants to realise their product is about as useless as something useless (to tired to make a proper metaphor)
Old 15th Sep 2005, 06:00   #16
McFlyinCA
What's a Dremel?
McFlyinCA has yet to learn the way of the Dremel
Umm I would just like to give you a headups. First of all Arctic Silver by nature is NOT conductive. However in tiny places like inbetween pins on ram it is. I also thought it would be a good idea to put Arctic Silver on my ram before ram sinks and much to my surprise my system would NOT boot after I did this . I know it was my ram cause my Asus speech reporter told me so. So word to the wise either tape off the pins on each ram module before applying arctic silver or dont do it at all. Hope this helps.
McFlyinCA is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
