RSS
Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 4th Jul 2005, 02:37   #1
ZapWizard
Enter the Mod Matrix
ZapWizard's Avatar
ZapWizard is on a distinguished road
The Real Wood iPod -by ZapWizard
Ok this has been a fun side project for me.
I have had a 20GB 4th gen iPod since they came out, but I have never liked the white finish.
As part of Project Redwood (Check my website) I am also applying a wood finish to just about everything on my desk to have a matching set. And the iPod was not excluded.
To view a gallery of all these images click the link below:
http://www.flickr.com/photos/zapwiza...s/476089/show/
Please read the thread before posting questions.
ZapWizard is offline   Reply With Quote
Old 4th Jul 2005, 02:38   #2
ZapWizard
ZapWizard's Avatar
First off the original iPod:
Note the white click wheel that was made to replace the gray wheel.
The dock was painted black, as it will sit inside a wooden cover. (not yet made)
First the iPod was taken apart.
To do this; follow a guide on a battery replacement website.
Once I had the shell seperated I could start to work on the new faceplate.
I did not want to simply apply a wood veneer, or a fake finish to the iPod. I wanted to use real wood. To do this I needed to carefully carve out a duplicate faceplate out of a raw piece of wood.
The wood I am using is African Padauk. It is a high quality hardwood that is very easy to work with, and naturaly red in color.
Old 4th Jul 2005, 02:38   #3
ZapWizard
ZapWizard's Avatar
This entire project was done by hand using a Dremel rotary tool.
First the edges of the wood were curved using a router attachement.
Next, the wheel was traced out in the proper place and cut out.
Then the hole for the screen was measured and cut out.
I did this by first drilling holes to remove the bulk of the material.
An exact duplicate. (well as exact as can be done by hand)
By far the hardest part was carving out the back of the faceplate.
The final thickness was only 2mm thick.
During this process the wood split four times, and was glued back using gorilla glue.
The thick piece at the top of the wood is actualy just done drying in this photograph.
Old 4th Jul 2005, 02:39   #4
ZapWizard
ZapWizard's Avatar
Next a new screen has to be fabricated.
This was done using a piece of lexan plastic, and was hand cut by dremel to fit the hole in the wood.
It took two attempts to get a peice that fit well.
In order to get the glossy finish that would approximate the finish on a normal ipod I coated the wood with three coats of Envirotex Lite.
The dust cover in this photo touched the coating while it was setting and that area was sanded off before the final coat.
A click wheel and select button were then cut out of African Padauk Veneer and given the same treatment. They are different in color as the veneer came from a different peice of wood.
Old 4th Jul 2005, 02:40   #5
ZapWizard
ZapWizard's Avatar
The iPod was the carefully fitted back together. It is still fully functional.
Hot-glue was used to hold the LCD and Click-wheel PCB onto the wood.
The iPod fits together nearly as perfect as before.
A little hot-glue was used to fill any gaps.
I used a very thin and strong double-sided tape to hold the click wheel and select button in place.
Also a good air-less contact is nessicary to ensure that the touch-sensativity of the click wheel is preserved though the thicker coating on top.
Old 4th Jul 2005, 02:41   #6
ZapWizard
ZapWizard's Avatar
Some final eye candy:
Old 4th Jul 2005, 03:22   #7
Rocket733
Austerity - It's the only way
Rocket733's Avatar
Rocket733 will become famous soon enough
Wow, that's insane. I'm impressed, love the wood.
Rocket733 is offline   Reply With Quote
Old 4th Jul 2005, 03:26   #8
notatoad
pretty fing wonderful
notatoad's Avatar
notatoad is a name known to allnotatoad is a name known to allnotatoad is a name known to allnotatoad is a name known to allnotatoad is a name known to allnotatoad is a name known to all
that is incredible. does the top have plastic clips to hold it in place, or is it all wood?
__________________
the old: gigabyte P35, e4300@2.8GHz, 4GB DDR3-1333, 8800gts 512, win7
the new: DFI M3H5 Jr, phenom 810, 4GB DDR-1600, OCZ Vertex, debian
notatoad.net fdo eff
notatoad is offline   Reply With Quote
Old 4th Jul 2005, 03:28   #9
ZapWizard
ZapWizard's Avatar
Check out the image and you tell me.
http://photos17.flickr.com/20390457_1c4d5c7b43_o.jpg
About half of them broke off due to my poor planning on the first coat of envirotex, but they hold the face on. I did use a bit of hot-glue to fill in some gaps as it is hand-made and has a few nicks.
Old 4th Jul 2005, 03:40   #10
charl3s_fatal1ty
Guest
Posts: n/a
O*F*F
T*H*A
H*O*O*K
Sweeet work Zap
Old 4th Jul 2005, 03:50   #11
Gascan1888
Supermodder
Gascan1888's Avatar
Gascan1888 is on a distinguished road
By far the greatest I-pod mod EVER !!!
__________________
Nexxo - "S**t happens. We just don't have to sling it at the fan with both hands."
Gascan1888 is offline   Reply With Quote
Old 4th Jul 2005, 04:10   #12
Snood
Supermodder
Snood's Avatar
Snood is on a distinguished road
...... so mass production of these starts when!? i'll be first in the queue!!..... seriously though, this is amazing and i'm sure there would actually be a market for wooden modded iPods.
Snood
__________________
Proud Bit Tech member number 5000
Life is like a sewer..... What you get out of it depends on what you put into it!
Last edited by Snood; 4th Jul 2005 at 04:11. Reason: cos i'm a retard and can't spell
Snood is offline   Reply With Quote
Old 4th Jul 2005, 04:12   #13
CaseyBlackburn
Network Techie
CaseyBlackburn's Avatar
CaseyBlackburn is on a distinguished road
Very Awesome Zap.
__________________
Casey Blackburn
My art - CaseyBlackburn @ dA
Get Firefox - Take Back The Web
CaseyBlackburn is offline   Reply With Quote
Old 4th Jul 2005, 04:42   #14
guy
Multimodder
guy is on a distinguished road
thats awesome, as previously posted best ipod mod.
guy is offline   Reply With Quote
Old 4th Jul 2005, 04:50   #15
toidiochysp
Multimodder
toidiochysp's Avatar
toidiochysp is on a distinguished road
that is so sweet, words cant describe how cool that is.
__________________
www.compmodcentral.net
Xbox^PC
www.x-trememodz.com
toidiochysp is offline   Reply With Quote
Old 4th Jul 2005, 05:25   #16
woodshop
UnSeenly
woodshop's Avatar
woodshop is on a distinguished road
you know if you had plained the surface flat you wouldn't have gotten that bit in the corner from the beading bit.
sry just had to find something had to defend my name :P) Tis really nice though this project remined me i wanted to vineer my keyboard like you did with the other project. I must say i'm not all to crasy about the suttle color change for the buttons.. i would've went more drastic with maybe some Rosewood, Bolivian or Bocote if i was goin to be a bit on the crazy side.
woodshop is offline   Reply With Quote
Old 4th Jul 2005, 06:04   #17
Noot
Modder
Noot is on a distinguished road
Great work. It looks awesome.
__________________
Whoever appeals to the law against his fellow man is either a fool or a coward. Anyone who cannot take care of himself without that law is both. For a wounded man shall say to his assailant: "If I live, I will kill you. If I die, you are forgiven." Such is the rule of honor.
Noot is offline   Reply With Quote
Old 4th Jul 2005, 13:48   #18
frodo
Ultramodder
frodo's Avatar
frodo is on a distinguished road
Looks AMAZING, want do to that for my samsung yh-920 aka "the ipod killer" lol
im impressed that you did that all by hand! shows some real skillz!
frodo is offline   Reply With Quote
Old 4th Jul 2005, 16:18   #19
rewris
Modder
rewris is on a distinguished road
wow mang. Much respect to you. that was very, very well done
rewris is offline   Reply With Quote
Old 4th Jul 2005, 17:59   #20
TekMonkey
I enjoy cheese.
TekMonkey's Avatar
TekMonkey is on a distinguished road
That looks amazing.
I was actually going to link to this in the ipodlounge forums, but I see you already have.
__________________
ComputerKing: "Dude! I write my signatures by my self! do you think that I go store to make him write for me! you funny..."
TekMonkey is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
