#1 |
Minimodder
Project: Dur-Link
Now that My Sister's Computer is done, It is time to make to make one for My Dad. His
500 Mhz P3 can only do so much. I ran into this case at Frys, It was an open box so I got it for $ 10.00. The case is made by Linkworld ( ?? ?? ). It is quite an odd design. The side panels are only large enough to slip a Mobo into the case. There are small plastic covers in front of the others that cover the Cages, |
#2 |
Minimodder
This POS is going to be interesting and a challange to make look nice.
I am going for the industrial look. Lots of Metal . Stainless steel , Titanium look maybe? I am still planning it out, I picked up some mesh today. and had some washerfill hoses around that I am going to use. untill next time.
#3 |
Modder
cool case...is there another opening on the side panel for the drives...
#4 | |
Minimodder
On the other side? Yes. It has little Plastic cover for the Drive Bays. The good thing is that Once its done, My Dad wont be adding and Drives to it. I was thinking of Mesh Suicide Doors to access The screw area. |
#5 |
Modder
coool...looking forward for more updates...
cheers |
#6 |
Supermodder
i hope ur gonna keep the rippley bit on the front, i think that rocks. Extremely strange design tho. I can see how the little removable panels for the drive bays would be faster, but u still gotta take the side off the case to detach the cables
, dunno what they were thinking there hehe. Good luck tho
__________________
lian-li v1000b
700GB RAID 0 Array X2 4800+ 7800 GTX SLi X-Fi FPS 24" dell Aqua Watercooling |
#7 |
Multimodder
Looking Good, DR K13! Howdy to a fellow [H]er!
I really like that mesh, it looks alot better than turning chickenwire diagonally (my cheap azz way)! Good luck with that really odd and initially, rather ugly case!
__________________
[H]ard|Folding they're working on it. |
#8 | |
Minimodder
I dont know, It looks kind of cool. But I was thinking of 1) cutting it out and putting Mesh in place. or 2) cutting a 80mm hole in it and adding a fan with a mesh grille . . That ripple thing is the only cool part of the case IMO
#9 | |
Minimodder
Thanks my [H] Brother! |
#10 | |
Supermodder
__________________
lian-li v1000b
#11 |
Multimodder
I'll be watching
May I ask where you got that mesh? I've been looking for some like that. Thanks
__________________
#12 | |
Minimodder
I got the mash at HomeDepot. $13.00 for a big roll.
#13 |
Minimodder
Well, Its the 4th of July. All my Friends are out getting hammered. I dont Drink anymore so it gives me some time to work on the project. I stripped the Case down to the cage. And started cutting into the bezel. I put the Bezel down behind me and started to coat the case in paint stripper. I forgot where the Bezel was , stepped back and * SNAP!!! * stepped on the bezel and it broke into 3 bits :mad: . I was so pissed that I drove up to compusa to look for another cheap case. I got there and remembered the guy that made the case called The " O " for his son. I remember him making an all mesh front bezel, and I decided to do the same. So i am not going to give up on this thing . I picked up a new HSF and Case fan while I was there .
By the time I got home the paint stripper evaporated, so I threw on a new coat. Melt Damn it! While I let that set in and Fry, I sleeved the HSF and the Case fan. I got done with that and went outside to check on the the paint. I dryed so I started to scrape off the Crap. It only got about half the thickness off, so on goes another coat of paint stripper to let sit for an hour. I grabbed the plastic side panels that cover the Drive screws and decided to cut them out and put mesh in the center. Ye-Old Dremel will make short work of these. This is what it will basically look like. I am not going to put the mesh in place untill I paint. I am having a hard time finding a " Titanium " looking type paint. If you know of any, let me know Please! I am done for now. I need to take some measurements and research the design of my new front bezel. See you soon.
#14 |
Hammertime
will it be easier to find a paint thay looks like stainless steel
#15 | |
Minimodder
I was thinking about that. I am sanding the case in one direction. maybe I will just clear coat it. I wonder how that would look?
#17 |
Minimodder
Man, respect for not giving up when you snapped the bezel, i know i'd be pissed if it happened to me.
Still, every good modder knows it's 50% planning and 50% improvisation
__________________
psy^ .. :: Antec 500w SmartPower 2.0 :: Windows XP x64 ^ Litestep 0.24.7 RC3 :: DFI Lanparty nf3 ut250GB ^ 05-04 BETA BIOS :: 0512 CG Newcastle 3000+, xp-120 ^ 120mm SilenX :: 2x 512MB Corsair 3200XL rev1.2, Albatron 6800 (12v 6p) :: 1x 160GB PATA, 2x 200GB SATA HDDs, Pioneer 109-D DVDRW |
#18 |
Minimodder
agreed... i like where this looks to be heading, and like psynapse I know I'd've been pissed off if I snapped the bezel (although I'd probably end up frabricating it out of wood or plastic lol)
__________________
[De]Construction Kit: Multi Pro 395 Dremel, Assortment of Standard Drill Bits. On the 'to-get' list: Redline Drill Bis (80mm 92mm & 120mm). |
| Thread Tools | |
| View Mode | |
